bass tube vs boxed subs
Discussion in 'Audio & Video' started by whiteyota, Jan 12, 2011.
  1. Jan 12, 2011 at 5:09 PM
    whiteyota
    whiteyota [OP] Well-Known Member
    Zachary
    virginia,caroline
    tacoma 97 4cyl spraypainting
    KC high lighters,K&N CAI,smoked tail light,corner,and3rd brake lights, clear turn signels, blackchrome headlights, blistien 5100s and aal, 800w soney amp with 1 kicker comp.10 custom box. pioneer door speakers and cd player, spray painted grill,door handels,wheel trim,tool box.
    can someone please explain to me what a bass tube is and how it works, is it better than boxed subs, because i have a 1997 single cab and need somthing to fit behind the seat (i have a bench seat) could i put a bass tube behind the seat.:confused: thanks
  2. Jan 12, 2011 at 7:57 PM
    btuner
    btuner <<<<>>>>
    Brandon
    Hendersonville NC
    09 PreRunner SR5
    Stage III TRD Badge
    Bass tubes suck there were 2 already installed in a car that I bought back in high school and they were weak. One properly boxed sub would blow away a or even two bass tubes.
  3. Jan 13, 2011 at 5:00 PM
    DevL
    DevL Well-Known Member
    Bass tubes are integrally amplified boxed speakers in a tube form factor instead of a box. They have small, low quality subs with under powered amps. You could use one but why would you?
  4. Jan 13, 2011 at 5:50 PM
    sam_i02
    sam_i02 Well-Known Member
    Samir
    Kanata, Ontario
    05 PreRunner AccessCab
    BHLM, Satoshi grill, D-rings, Relentless Fab recovery shackle, DRL, Firestone RideRite airbags, WO seatcovers, added temp gauge, custom interior lights.
    I would recommend building your own box.
    I previously owned a 93 pre-taco standard cab with bench seats and actually had a 10" sub and box tucked away behind the seat. The seat could be pushed back the whole way and it sounded much better than stock.
    I still have that sub and box somewhere in storage and if you like I can dig it up this wknd and get you the dims + a pic or two. It is ugly as sin, but got the job done hooked up to a Rockford amp.
  5. Jan 16, 2011 at 5:10 PM
    whiteyota
    Zachary
    virginia,caroline
    thanks guys. after reasearch on bass tube i decide to go with the boxed sub. i got a kicker comp 10in in a slim truck box this weekend and i hooked it to my amp and it sonds realy great. i just had to slide my seat up two clicks. but thanks anyways
