Batter Light On??
Discussion in '1st Gen. Tacomas (1995-2004)' started by rab89, Mar 5, 2009.
  1. Mar 5, 2009 at 10:25 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    OK,
    So my engine was looking kind of oily, so i decided to spray some degreaser in there. after letting it soak a bit and then thuroughly washing my engine down, i went for a drive and my battery light, brake light are on, and my volt battery meter thing is reading lower than usual.. what is going on??
  2. Mar 6, 2009 at 2:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I saw your other post about this.....
    I would have the alternator checked. Perhaps it's not charging the battery.
    In the process of washing the truck - you could've dislodged some dirt/mud that relocated itself inside the alternator. You might wanna have the alternator brushes checked also (I think they still have brushes).
    If the alternator is dirty inside - they don't work well.
  3. Mar 6, 2009 at 8:39 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    I say both the above posters are right.
    But i wiould try the cleaning the battery and Alternator thing first.
    See if that helps.
    then go for the test.
  4. Mar 6, 2009 at 9:39 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    nope, alternator was fried, water did it in.
    $500 installed with new belt, from mechanic
  5. Mar 6, 2009 at 9:42 AM
    it's in coma
    it's in coma Well-Known Member
    in the desert
    06 trd off road
    intake and exhaust
    is this because of the wash?
  6. Mar 6, 2009 at 10:02 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    allegedly
    but it did happen the first time i started it after the wash
  7. Mar 6, 2009 at 10:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Once again, always avoid the alternator when washing the engine. Also, keep the engine running when doing so.
  8. Mar 6, 2009 at 12:45 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    btw that was my buddies 90 not my truck. he used me account for some reason...
  9. Mar 6, 2009 at 1:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear. :)
  10. Mar 6, 2009 at 4:21 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    That's news to me...why do you keep the engine running?
  11. Mar 6, 2009 at 4:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There are tons of reasons....If water gets into the alternator, the Alt. fan/cooling fins, will help to blow the water out. I just avoid the alt with any water. Never had an issue when washing the engine with the engine running, and avoiding the alt.
  12. Mar 6, 2009 at 4:34 PM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Works for me, thanks. I had washed off engines in the past, never had any issues, but that makes sense. Good to know that one can still learn stuff at a ripe old age...
  13. Mar 6, 2009 at 5:55 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    the only thing with the engine on is if the water does get to it, it can short circuit. thats what happened the my buddy(the guy who started this thread). if you wash it when it's off and give ti time to dry, there may be less chance of a short circuit. my .02
  14. Mar 6, 2009 at 5:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The enignes and electronics are mostly sealed. Just have to stay away from the fuse box, and alternator.
  15. Mar 7, 2009 at 4:25 AM
    Janster
    Jandy
    Lancaster, PA
    Wiring & connections aren't sealed. You have to be careful around anything that's electrical.
  16. Mar 7, 2009 at 5:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok. Perhaps I was being vague...and a little tired...They are water resistant. Many of the conectors (I have found) have an dielectric (or whatever it is) grease to help maintain a good contact and to keep moisture out. Maony conectors have a rubber seal to aid in keeping moisture out as well. Plugs are (for the most part) sealed. One of the reasons your engine doesnt short out if driven thru a puddle.
  17. Mar 7, 2009 at 7:15 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    I prefer to keep the engine running when I wash the engine bay also. But if you insist on washing it with the vehicle off, wrap a plastic bag around the alternator, just for some added security.
