Batteries Plus X2Power 27F Battery Install and Review
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pc3coyote, Apr 5, 2020.
  1. Apr 5, 2020 at 6:11 PM
    pc3coyote
    pc3coyote [OP] www.pc3coyote.com
    Paul
    SoCal
    17 BBP Sport DCSB 4x4
    I was looking for a new battery because my stock one was leaking after three years and to have more capability to comfortable run 12V accessories off the grid.
    I went with a Batteries Plus X2Power 27F Battery (rebranded Northstar) which was $288.15 out the door after black friday with a core refund, 20% off, and $30 rebate. Batteries Plus has a 60 month warranty which is nice bonus.
    This battery has 930A CCA, 92Ah, and 195min RC.
    I installed it with an off-grid engineering tie down, generic battery tray (WirthCo 210877), and generic 10" j-hooks. A new tray and j-hooks are needed because the new battery is larger than the stock one.
    The stock tray sits on the fender with little plastic nubs that rest in holes. The new battery tray doesn't have the nubs so I needed a new way to secure it since the battery is larger and heavier at 68 lbs. I used 5/16" bolts, fender washers, and well nuts which require drilling 5/8" holes.
    To remove stock battery:
    1. Remove battery terminals with a socket wrench
    2. Remove nut on front of j-hook with a socket wrench
    3. Remove battery tie down with rear attached j-hook
    4. Lift out battery
    5. Remove plastic tray resting on fender
    To install new battery:
    1. Lay tray down
    2. Mark locations for well nuts, I used three (two wasn't secure enough). Remove tray
    3. Drill 5/8" holes working your way up in size
    4. Clean up edges and touch up paint
    5. Drop in well nuts
    6. Reinstall tray and install bolts with fender washers
    7. Install battery
    8. Install tie down with j-books
    9. Connect battery terminals
    So far, I'm really happy with the battery. It's survived a few offroad trips without any issues. I'll continue assessing if additional securing is required for the tray. There's plenty of clearance to the oil fill neck.
    Thanks to @jediwebdude for the part suggestions and help with questions!
  2. Apr 5, 2020 at 10:09 PM
    GladiatorNOT
    GladiatorNOT Well-Known Member
    2017 TRD OR
    Old Man BP51 coilovers Dakar HD leaf springs Icon Delta control arms TRD Pro rims with Kenda Klever RT 33x10.5 tires Exhaust mod TRD front skid, RCI tranny and transfer case skids Southern Style Slimline front bumper Baja Designs S8 bumper light Warn Zeon Platinum 10s winch 4.88 Nitro gears ARB front locking differential ARB twin air compressor X2 Power 27 battery RCI rear bumper with Rigid SRQ lights RCI rock sliders RLD canopy Dometic CFX3 55 refrigerator TRD Pro grill Front & Rear anytime camera Seat Jackers Diode Dynamics Pro fogs
    Got the same battery last summer. Great battery but could never get the $30 rebate. I would send it in then they would send it back and say they needed some more info. Went back and forth three times before I gave up. Seemed like they were trying hard not to give me the rebate. But love the battery! I just removed the factory tray and dropped the battery in. Didn’t see a reason to install a tray. Also used the factory hold down. Just have to mount it under the grab handle. Great battery!
    MountainManGuy and pc3coyote[OP] like this.
  3. Apr 5, 2020 at 10:17 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Same battery but I used the stock tie down. A small indent needs to be filled in the plastic swivel handle for it to work. That's it.
    pc3coyote[OP] likes this.
  4. Apr 5, 2020 at 10:39 PM
    pc3coyote
    Paul
    SoCal
    Hmm sorry to hear about that. I paid 11/21, picked up the battery 12/7, check was written 1/29, and I received it a few days later in the mail.
    Maybe getting a replacement battery tray and j-hooks wasn't necessary after all of the work haha but I'm still happy with how it all came out.
    Skydvrr[QUOTED] likes this.
  5. Apr 6, 2020 at 4:53 AM
    TacomaTRDman
    TacomaTRDman Member
    2016 Blazing Blue Pearl Tacoma TRD Sport Access Cab MT
    None
    I am considering the same battery, There is a minor issue with the Northstar and X2 which is a rebranded Northstar. I spoke with Northstar tech support and here is what I discovered. The Northstar/X2 requires a charging voltage of between 14.1 and 14.8 volt to charge to 100%. The tacoma charging volts are between 13.4 and 13.8 which will only charge the Northstar to approximately 80%. The solution is to occasionally place the battery on a trickle charge from an AGM smart charger such as the NOCO Genius5.
    JustMeMyselfAndI and SR-71A like this.
  6. Apr 6, 2020 at 5:43 AM
    Outdoorsy_Yota
    Outdoorsy_Yota Hella-Known Member
    duhbondo JIW Local 378
    Bay Area
    17 DCLB TRD OR LOL
    How lame... Im running two Northstar batt's in my truck... I need to look in to this... thx
  7. Apr 6, 2020 at 6:23 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    U still need the tray. I just made a quick shity one out of aluminum.
  8. Apr 6, 2020 at 6:48 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Nice write-up. Looks good
    @TacomaTRDman is correct about the charging issue. Its well discussed in other threads on here - basically the only good solution for 3rd gen trucks is to put an AGM rated charger on them once a month or more. As far as I know there is still no solution to boosting the voltage in the 3rd gen trucks
  9. Apr 6, 2020 at 8:35 AM
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    You don't. I installed this same battery without a tray, and have been off-roading a few times on some rugged terrain since. Battery doesn't budge.
    I think a proper tie down is more important. Have you seen the factory tray? It's a super thin plastic that doesn't do anything.
    Check out the off-grid engineering install around the 17 min mark. His ML-ACR tray just rests on top of the factory plastic tray that he trimmed back. It's not bolted to the truck or anything.
    https://www.youtube.com/watch?v=rNLhx8dm8Gs&t=1715s
  10. Apr 6, 2020 at 9:11 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    You can also use a battery tray from a 2nd Gen with towing package.
  11. Apr 6, 2020 at 9:59 AM
    GladiatorNOT
    2017 TRD OR
    This is what I use:
    https://4xspower.com/shop/charging/intelli-chargers/1005-121416v-battery-intellicharger-5a-15a-25a/
  12. Apr 6, 2020 at 10:00 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
  13. Apr 6, 2020 at 10:09 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I thought the genius 5 was 12v?
  14. Apr 6, 2020 at 10:23 AM
    GladiatorNOT
    2017 TRD OR
    It’s been a little while but I think I paid right around $250 for it from a dealer off eBay.
  15. Apr 7, 2020 at 10:33 AM
    jediwebdude
    jediwebdude Well-Known Member
    Frisco, TX
    2019 TRD Pro Tacoma
    Looks good!
    I finally got a shot of the battery tray with the battery removed....
    [​IMG]batt-tray
    pc3coyote[OP] and shakerhood like this.
  16. Apr 7, 2020 at 10:50 AM
    Outdoorsy_Yota
    Bay Area
    17 DCLB TRD OR LOL
  17. Apr 7, 2020 at 4:15 PM
    TacomaTRDman
    TacomaTRDman Member
    None
    The NOCO Genius 5 charges AGM batteries at 14.8 volts.
    SR-71A likes this.
  18. Apr 7, 2020 at 6:51 PM
    GladiatorNOT
    2017 TRD OR
    A
    A 5 amp charger isn’t enough for these batteries.
  19. Apr 7, 2020 at 11:52 PM
    MountainManGuy
    Colorado
    External chargers are not hard to find. I use a basic one from black and decker and it works great.
    https://www.amazon.com/BLACK-DECKER...&sprefix=black+and+decker+25+a,aps,191&sr=8-2
    25 amp, charges agm just fine.
    What I'm more interested is onboard chargers and someone coming up with a way to raise our alt's voltage. I've gotten a quote from another alternator company for a custom built alt, but surely there's another way to do this without having to replace the whole alt
  20. Apr 7, 2020 at 11:56 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    the third gens use the ECM to regulate the regulator. no matter how many amps your alt will put out the computer will make the regulator put out around 13.8. if you trick the Lin line into thinking its output voltage is too low then you will get a higher charge voltage.
    in the 2nd and first gens the alt fuse controlled the regulator so a simple diode would raise our voltage.
    EagleUSMCRet, SR-71A and thedriza like this.
