Battery Dead from Lights On for 20-30 Minutes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kremtok, Nov 15, 2017.
  1. Nov 15, 2017 at 8:13 PM
    HerculesRockefeller
    HerculesRockefeller Well-Known Member
    2018 Cement Tundra Double Cab TRD Off Road
    I've accidentally left interior lights on for upwards of 12 hours and had no issue starting the truck, I'd guess it depends on the battery you're using.
    Kremtok[OP] likes this.
  2. Nov 15, 2017 at 8:14 PM
    Kremtok
    Kremtok [OP] Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    Good point. This is the stock battery that came with the truck. I haven’t looked at it to get specs; I’m laid up for a bit recovering from back surgery.
  3. Nov 15, 2017 at 8:19 PM
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    i like interstate batteries but.....AAA has installed their "Interstate" battery in my Lexus and it lasted only 40k miles and less than 3 yrs.......I really like interstate but quality seems to be declining.......same thing happened to my wife Lexus with AAA "Interstate" battery.....What other batter would be a good choice
  4. Nov 15, 2017 at 8:23 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Group 31 Odyssey FTW :benchpress:
    Stock battery is lame, I wouldn't trust it for 10min.
    shakerhood and Kremtok[OP] like this.
  5. Nov 15, 2017 at 8:25 PM
    r1200gs4ok
    O. K.
    Irvine, Ca
    thanks....will Grp 31 fit
  6. Nov 15, 2017 at 8:27 PM
    Lunabird
    Lunabird Well-Known Member
    Doesn’t your truck shut off the lights after 15 min? Mine does. I would check your ground wire
  7. Nov 15, 2017 at 8:30 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
  8. Nov 15, 2017 at 8:30 PM
    Kremtok
    Gary
    Houston, TX
    I’m actually not certain. I’ve never turned the truck off and sat in it for that long. Like I said, we usually rely on the 30 second follow me home or whatever it’s called.
  9. Nov 15, 2017 at 8:35 PM
    Kremtok
    Gary
    Houston, TX
    Diablo169[QUOTED] likes this.
  10. Nov 15, 2017 at 8:40 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    If you have 3a, call and ask for a battery truck.have tech do a full test and get the printout. And maybe have him install a battery. 6yr warranty.
  11. Nov 15, 2017 at 8:42 PM
    Kremtok
    Gary
    Houston, TX
    Sadly there is no AAA in Alaska. But I do have a friend who works at O’Reilly and they do battery tests for free. I’m sure he will hook me up with whatever printouts and things that he can. I know for sure that if I buy a battery from him that he will install it.
    lucky13don[QUOTED] likes this.
  12. Nov 15, 2017 at 9:07 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I think it’s a 27F if you have the tow package.
    Kremtok[QUOTED][OP] likes this.
  13. Nov 15, 2017 at 9:10 PM
    NMTrailRider
    New Mexico
  14. Nov 16, 2017 at 5:52 AM
    rdjr17
    rdjr17 Well-Known Member
    Ron
    Nepa
    2019 voodoo blue Trd pro
    My second gen battery lasted 14 months 17,000 miles cell went bad , replaced with a interstate megatron never had a issue after .
  15. Nov 16, 2017 at 5:57 AM
    #35
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    I had an issue with mine after about a year...not to mention a group 24 battery is IMO way undersized for our trucks. I replaced it with a group 27 Northstar. See how long that lasts.
  16. Nov 16, 2017 at 6:24 AM
    #36
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    You're right. I don't have the specs, but with the tow package there is a higher amp battery and alternator. Someone will chime in certainly.
  17. Nov 16, 2017 at 6:29 AM
    #37
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Interior lights are probably around 3~5w, headlights taillights are closer to 160~180w. It's not even close to comparable in terms of power drain.
  18. Nov 16, 2017 at 7:48 AM
    #38
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    That, IMO, is a big part of the problem. These are not the greatest batteries to start with. So, depending on how short your short trips are, you most likely are not charging the battery to the fullest that the alternator should. You need a good saturation charge to bring it back up to full charge. After that, a voltage and load test will give you a good idea of the condition of your battery.
  19. Nov 16, 2017 at 8:26 AM
    #39
    Kremtok
    Gary
    Houston, TX
    Thanks again for the insight, folks.
    Yes I’m sure you’re right there. I’ll get a charger at the very least and throw it on once every couple of weeks. Either that, or take a bit of a drive once a week.
  20. Nov 16, 2017 at 8:54 AM
    #40
    Adventure Ready
    Adventure Ready Adventure Ready
    Seattle, WA
    Tow package gets you an alternator that puts out about 130 amps vs. the standard which I believe is around 100 amps.
    The tow package gets you a group 24 Battery. There aren't many upgrade options in a group 24 size battery outside of a deep cycle, which isn't ideal for a starting battery but will work just fine in warmer climates. The best upgrade is to an Odyssey Extreme group 34 which is the same footprint as the group 24 but is about 1" shorter. This battery puts out significantly more power than the stock flooded battery though, and will add longevity as well.
    Hope that helps! Let me know if you have any other Tacoma electrical questions, we work on them every single day.
    Kremtok[OP] and Spare Parts like this.
