Battery disconnect?
Discussion in '3rd Gen. Tacomas (2016+)' started by AZDuck97, Apr 8, 2016.
  1. Apr 8, 2016 at 8:46 PM
    AZDuck97
    AZDuck97 [OP] Active Member
    Jon
    Phoenix, AZ
    2016 Tacoma TRD OR DCLB Inferno
    Does disconnecting the battery wipe all the settings on the stereo or is there some sort of secondary battery backup that will retain them for awhile? Just curious if I need to document my preferred settings and such. Thanks!
  2. Apr 8, 2016 at 8:49 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Removal of the battery cables will indeed wipe the radio presets and EQ settings.
    If you have access to jumper cables and another vehicle or a jumper box you can keep power to the electronics so you don't lose your settings.
  3. Apr 8, 2016 at 8:54 PM
    AZDuck97
    Jon
    Phoenix, AZ
    Ok, thanks!
  4. Apr 8, 2016 at 9:00 PM
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
    There is a 9V battery device that plugs into the lighter socket. Turn the ignition key to acc. before unplugging the battery and it'll save the settings. It's only a few bucks. Check your local auto parts store.
  5. Apr 8, 2016 at 9:51 PM
    MoQS
    MoQS Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
  6. Apr 8, 2016 at 9:55 PM
    Markc1024
    Markc1024 Well-Known Member
    Mark
    Colorado
    2016 White DCLB TRD Sport
    Icon Front & Rear AAL
    I've pulled the unit out and disconnected the battery. Only thing lost was the time.
  7. Apr 9, 2016 at 4:29 AM
    Lawfarin
    Lawfarin Well-Known Member
    Larry
    NY
    2017 Tacoma OR DCSB 4x4
    If you even need to change a battery and want to retain your settings if they didn't wipe from the battery dying simple start or jumpstart the vehicle, and disconnect the battery and replace it with it running.
  8. Apr 9, 2016 at 5:13 AM
    13mgm4X4
    13mgm4X4 Well-Known Member
    Disconnecting the battery does not erase anything on the radio. I just disconnected my battery for a half hour and when I hooked it back up everything preset on the radio was still there.
  9. Apr 9, 2016 at 5:29 AM
    motomaster132003
    motomaster132003 Well-Known Member
    2016 Tacoma TRD OR DCSB
    Just resets your trips, and fuel economy. Doesn't reset anything on the radio.
  10. Apr 10, 2016 at 10:44 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    ^^^^This...
    Pinche_tacos likes this.
  11. Apr 10, 2016 at 10:46 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Good way to fry an ECM
  12. Apr 10, 2016 at 3:13 PM
    Lawfarin
    Larry
    NY
    Explain that one
  13. Apr 10, 2016 at 3:15 PM
    Aussiek2000
    2016 Offroad AC
    Battery acts as a buffer for charging voltage. It's common to have a voltage spike if you unhook then battery while an engine is running and fry one or multiple computers.
    I've put quite a few computers that customers did this to
  14. Apr 10, 2016 at 3:19 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Why would it fry the ecm? You're still feeding 12v through the battery leads from another source.
    I think you're confusing the source to be a 'charge' vs. a 'power supply'.
    Lawfarin likes this.
  15. Apr 10, 2016 at 3:21 PM
    File IFR
    Central MA
    So, quite a few of your customers changed their batteries while the engine is running? Where in the USA is this happening?
  16. Apr 10, 2016 at 3:24 PM
    Aussiek2000
    2016 Offroad AC
    I'm just telling you what can happen. Not really in the mood to argue. My truck runs
  17. Apr 10, 2016 at 11:31 PM
    2016BBP
    2016BBP Well-Known Member
    Southeast
    SR5 V6 Auto
    Method Wheels, WxTechGuards, TowPkg, KNDropn, 3M-Tint
    When I added a 2nd battery I disconnected the existing battery for about an hour, I did not lose anything.
  18. Apr 11, 2016 at 3:22 AM
    Shaunsquatch
    Shaunsquatch Well-Known Member
    Shaun
    Louisville, KY
    2016 DCSB TRD Sport
    Its called "load dump"
  19. Apr 11, 2016 at 4:23 AM
    Lawfarin
    Larry
    NY
    I've never seen or heard of an ECM, ECU, BCM, ect frying because of that. Seen a lot of guys change batteries at our dealerships like that so the customers settings aren't lost. Plus almost every person at auto zone and other parts stores tell their customers that's how you test for a bad alternator. Do you know how many tow ins you would have if that was true? Voltage spikes can happen any time and will happen if you have a battery or not. When Stators start going bad in the alternator the voltage increases. This can be dangerous but I still haven't seen that fry a computer. Seen some that were putting out around 18v
  20. Apr 11, 2016 at 3:10 PM
    File IFR
    Central MA
    You confused my question with an argument. I just asked you to confirm that you had quite a few customers change their batteries with the engine running.... as a result they needed a new ECU installed by you.
    I'm sure your truck runs too. :thumbsup:
