battery draining
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kielio, Nov 9, 2014.
  1. Nov 9, 2014 at 5:13 PM
    kielio
    kielio [OP] New Member
    Kyle
    Saskatoon, Saskatchewan
    07 dc 4x4 trd off road
    Hello everyone this is my first post. i have a 2007 tacoma double cab 4x4 having some issues with battery draining in two weeks of not driving it.I took the neg side off the battery and was getting about 80ma with the key off which i guess is a little high when I unplug the fuse for the radio it drops to 40ma.I have an aftermarket alarm/starter and aftermarket alpine double din screen, what should i start looking for ?
  2. Nov 9, 2014 at 5:48 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    A new battery.
  3. Nov 9, 2014 at 6:00 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    How old is the battery?
  4. Nov 9, 2014 at 7:40 PM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    I experienced a similar issue on a Tundra and mine was the remote start. I ended up installing a switch on the remote starts constant 12v in the cab. That way when it would sit for more than a few days I could just kill the power to the remote start. Mine was over 80ma though...by the way your meter said .080 and .040 right? Just making sure of the amp draw because a normal draw is usually less than .050. Also you might find that if you meter the radio for a long enough duration, the draw might drop once it goes to sleep.
  5. Nov 9, 2014 at 9:55 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Original battery? If so get a new one.
  6. Nov 10, 2014 at 6:24 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Check milliamp draw across all fuses. That way you will isolate the circuit.
  7. Nov 12, 2014 at 5:14 AM
    kielio
    Kyle
    the battery is only a year old so i can't see it being the battery,either the alarm/starter or the the alpine double din I'm thinking but the question is what to look for when checking these devices, shorted wires , stuff like that ?
  8. Nov 12, 2014 at 5:16 AM
    kielio
    Kyle
    yes its .080ma then i pull the fuse for the radio and drops to .040ma, which fuse would the alarm circuit be on ?
  9. Nov 12, 2014 at 5:50 AM
    jessandjamie
    Arizona
    Since the alarm is aftermarket I couldn't tell you what fuse it would be. You would have to either find the alarm module and start tracing wires to find it or start pulling fuses. On mine nothing was shorted you could see. I soldered all the connections myself and after about three years the module started having this issue. I've read elsewhere that my issue is more common than it should be, and short of replacing the module, not much you can do.
    Are you repacing the fuses with the amp probes and reading the draw that way? I would bet that if you tried the radio one again, and walked away for 15 min, it would drop less than the 40ma your seeing (unless the alarm is tied to the radio circuit). If it doesn't, I feel thats way to much by itself. You should be able to find the amp draw for your radio on the web somewhere or a manual maybe.
