battery recommendation?
Discussion in '1st Gen. Tacomas (1995-2004)' started by allian04, Nov 26, 2012.
  1. Nov 26, 2012 at 8:38 AM
    allian04
    allian04 [OP] Well-Known Member
    breckenridge, co
    03 trd tacoma 4x4
    arb bull bar, B.A.M.F. rock sliders w/kickout, factory steelies 255/85r16 km2, 3" ome 881 coils, dakars 5150s, deck plate, snugtop, viair on-board air,
    i have the oppurtunity to purchase an optima battery at a discounted price and was what would be the best for my setup.
    i currently have a 2003 trd tacoma with an viair onboard air system but am looking to get a winch and two hella ralleye 1000 lights
  2. Nov 26, 2012 at 9:04 AM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    After researching the hell out of this myself... I went with a Sears Die Hard Platinum.
    I heard too many stories of inconsistency to go with a Yellow Top and just couldn't pull the trigger on it for its price and limited warranty.
    I went with the Sears brand because apparently the platinum series is still made by Johnson. It's a deep cycle battery and has that glass mat technology too. But it was the 48 month free replacement and 100 month pro rated warranty that triggered my decision to buy it.
    I feel like all batteries are hit or miss so the warranty was important to me.
    And son of a bitch... they're on sale right now for $197. I paid $238.
  3. Nov 26, 2012 at 9:17 AM
    allian04
    breckenridge, co
    03 trd tacoma 4x4
    i can get 40% off on an optima right now so that is why im going with one just need to figure out what series
  4. Nov 26, 2012 at 9:24 AM
    Madjik_Man
    Boulder, CO
    If you can get 40% off and are set on Optima, then get a yellow top :notsure:
  5. Nov 26, 2012 at 10:43 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    single battery ?
    grp 31 YT (heavy/big)
    but the best choice for a single battery
    if yer planning to use it for winching
    or heavy loads.
    I run dual 34/78 YT's
    best performance to weight/size ratio IMO
    only issue with the YT's...
    they don't have the correct terminal placement
    for the Tacoma...
    so... the fitment, tho' minor, requires some altercations.
    Optima makes a 34 redtop with reverse terminals
    that are correct for the Tacoma...
    Had one... but I wouldn't buy another.
    The redtops are ok for a dd and as a system battery...
    but I wouldn't recommend those for winching or heavy loads.
    The redtop does not like to be drained too low...
    in fact if it goes below 10.4 volts...
    you will likely need to do a recovery charge method to save it.
    ^ but that's no guarantee it will save it.
    For Optima... stick with the Yellow Top
  6. Nov 26, 2012 at 6:35 PM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    aberdeen, nj
    09 Doublecab TRD Off-Road! Magnetic Grey!
    im looking into on buying a die hard platinum... what;s the group size on urs?
    do you have TRD? thx
  7. Nov 26, 2012 at 6:39 PM
    Madjik_Man
    Boulder, CO
    I believe it was a 35. I'll have to go check the receipt.
    Yes, it's a TRD.
  8. Nov 26, 2012 at 6:45 PM
    linkfeeney
    link the stink!
    aberdeen, nj
    my battery is over 4 yrs old... I think its time for a change soon. I saw that sear is having a sale on the battery... Im going to ask for some money for the battery this chrstmas... I also think sear charges $13 to put it on??
  9. Nov 26, 2012 at 6:48 PM
    Madjik_Man
    Boulder, CO
    They're on sale for $45 less than what I just paid a month ago :mad:
    And bring a 10mm wrench or socket (for your terminal connections) and a 12mm(?) (for your hold down) change it yourself in their parking lot.
  10. Nov 26, 2012 at 6:54 PM
    linkfeeney
    link the stink!
    aberdeen, nj
    i really dont think i want to change anything myself when the temp outside is in the 30's... hehe :D
  11. Nov 26, 2012 at 6:55 PM
    Madjik_Man
    Boulder, CO
    it takes about 2 minutes tops.
    but I hear ya.
  12. Nov 26, 2012 at 7:41 PM
    RAT PRODUCTS
    RAT PRODUCTS RAT Products
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Don't you need a different hold down rod though?
  13. Nov 26, 2012 at 7:50 PM
    Madjik_Man
    Boulder, CO
    I only did because I went full ruhtard (don't ask)
    The diehard platinum will fit fine under the stock hold down set up.
    I'm pretty sure you need a longer rod for the yellow top
  14. Nov 26, 2012 at 8:05 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    I just replaced my 6 year old Red Top 34r with a DieHard Platinum 35. The only reason I didn't get another Red Top is because no one had them in stock. I'm very happy with the DieHard, though. Plus, it comes with a 4 year warranty. We'll see how long it lasts...
  15. Nov 27, 2012 at 6:58 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    05 SR5 Double Cab 4X4
    There are only a handful of battery manufacturers these days. The last 4 I've bought have been from the local Advance Auto parts. I had one go bad under warranty from my plow truck. But it's an electric plow and whenever I use it the blower is on high, wipers are going, lights are on, low RPM, original 50 amp alternator, etc. About the worst situation you can put a battery in. The replacement has been in it for 4 years.
  16. Nov 27, 2012 at 8:35 AM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    you don't need tie down rods, my truck came with a bungee cord!:D
  17. Nov 27, 2012 at 9:12 AM
    ALawrence
    ALawrence Well-Known Member
    Andrew
    Oklahoma City
    03 Tacoma Sr5 Double cab 4x4
    i've had a yellow top in my jeep for the last 4 years, i got it used from a friend, manufacture date was 06. just this weekend i left the electric fan on all night, came out and it still cranked.
  18. Nov 27, 2012 at 6:57 PM
    linkfeeney
    link the stink!
    aberdeen, nj
    I guess die hard group 35 works ok?
  19. Nov 27, 2012 at 7:11 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    Sears vs optima....not sure what to go with. Hard to find a sears around here. Hard to find optima too lol. I do a lot of winching and use the batteries a lot. Optima yellow sounds what I need. I'm worried about the questionable quality.
  20. Nov 27, 2012 at 8:20 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    So far, yeah. Only had the battery for four days...
    One thing I did notice is that my lights don't dim anymore with loud bass. I always had a slight dim with the Optima, even when it was brand new.
