Battery Recommendation
Discussion in 'Product Reviews' started by Sjroman68, Jun 4, 2014.
  1. Jun 4, 2014 at 7:03 PM
    Sjroman68
    Sjroman68 [OP] New Member
    Sacramento CA
    10 Tacoma SR5 LB
    3in TC lift front and back Body Armor bumpers XRC10
    Battery on my 2010 Toyota Tacoma died. I have a 10,000lb winch. What kind of battery does anyone recommend?
  2. Jun 5, 2014 at 7:17 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    IMHO, if you are not able to keep your starting battery fully recharged based on your driving habits and winching, you should upgrading your charging system. If you winch a lot and drain your starting battery, then you should consider adding an isolated deep cycle battery for winching, so you can restart your engine. Starting batteries are not designed for deep discharges that can occur with heavy electrical loads and OEM charging systems. For additional information, see Sections 7 and 5 in the Car and Deep Cycle Battery FAQ on www.batteryfaq.org. The November issue of Consumer Reports has ratings on wet Group 24F starting batteries. If you do extreme off-roading (heavy vibration), then a spiral would AGM will last longer than wet starting batteries.
  3. Jun 10, 2014 at 11:54 PM
    eivad1
    eivad1 Active Member
    dave
    canyon lake ca
    2007 toyota tacoma 2wd
    stock
    braille
  4. Jun 10, 2014 at 11:56 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
