Battery replacement on a 2015
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jake1530, Oct 8, 2019.
  1. Oct 8, 2019 at 6:40 PM
    Jake1530
    Jake1530 [OP] Well-Known Member
    2015 Tacoma TRD
    Yes I already did a search. The Original battery reads 165 reserve? but the one I got is 130. BUT original 160 cranking amps, and the new one is 175. It's not the same number, I got the Gold model I figured it was batter? Will it be ok? Thank you in advance folks
  2. Oct 8, 2019 at 6:59 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It will be fine. It means your new battery has less capacity, that is 35 minutes less run time capacity at a specified draw when not supported by the alternator. However your new battery has more cranking power. Think of it kind of like the new battery has a bigger motor but smaller fuel tank.
  3. Oct 8, 2019 at 7:41 PM
    Jake1530
    2015 Tacoma TRD
    Thank you crash for taking the time to explain that in a way I could understand
  4. Oct 9, 2019 at 10:05 AM
    Jake1530
    2015 Tacoma TRD
    Crash, again thank you for your time. I’m a bit obsessive compulsive and your answer was perfectly explained. Of course now I have something that’s bugging me. I have no intention of going back to Advanced Auto and looking to swap it out, but if you’re inclined to indulge my curiosity. When I was at the store last night my factory battery was a 27F and I mentioned the specs earlier. Advanced had the battery as their silver model, I chose the gold. There was also a platinum. Each progressively have LESS reserve minutes. I think the platinum even had less CCA’s. To me that seems backwards. Plus my gold is an 1 1/2 less in length but more money? I figured spend more for a better battery
  5. Oct 9, 2019 at 10:16 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I'm not familiar with their battery line. It could be build quality and warranty that you are paying more for, not necessarily better performance, but I agree that it would seem odd to pay more for less performance. For the best battery, check out my battery thread: https://www.tacomaworld.com/threads/the-northstar-agm-battery-voltage-booster-upgrade.604478/
    Jake1530[QUOTED][OP] likes this.
  6. Oct 9, 2019 at 10:24 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Is the new battery 27f or 24f? Either way you are fine. The specs of the new battery are more then sufficent and will serve your truck well.
  7. Oct 9, 2019 at 10:31 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    As stated - either 24F or 27F will work. If you have a 27F and want to stay with it - the NAPA 27F fits. I have one in my 2015 4.0L Pre Runner with the Tow Pkg.
    Lots of complaints here about certain brands of 27Fs being too tall for the stock hold-down hardware.
  8. Oct 9, 2019 at 12:34 PM
    Jake1530
    2015 Tacoma TRD
    Crash you’re a gentleman, thank you for your patience.
    TacomaMike the new one is a 24F CCA 750 CA@32* 935 RC 130
    Lester like poor Crash has learned I’m a bit obsessive. I measured both this morning before retuning the core both are 7 7/8 H 6 3/4 W the 24F is 10 1/4 L the old 27 F is 11 7/8 L
    Thank you again Crash I’ll take a look at your page. It was last night at 7 pm my wife drove me down to Advanced Auto and I figured I was getting a better one spending the extra $30 on the gold one as opposed to the silver 27F OEM specs. Gentleman can’t thank you enough for your time and patience
  9. Oct 9, 2019 at 1:20 PM
    TacomaMike37
    13' DCLB MGM
    The new tacomas use the 24F if that gives you piece of mind.
  10. Oct 9, 2019 at 1:25 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Our 2nd gens only came with the 27F if you had a tow package. I moved "down" to a 24F when mine died as that was what Walmart had readily available. No issues what so ever
    Jake1530[OP] and TacomaMike37 like this.
  11. Oct 9, 2019 at 1:28 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  12. Oct 9, 2019 at 1:31 PM
    13tacosport
    13tacosport Well-Known Member
    Arbi
    818
    13 Trd Sport
    I was actually going to post a similar battery question for my 2013, but thanks to you guys, no need to post, got my answer. 27F since i got two package also. Beers all around!
  13. Oct 9, 2019 at 2:15 PM
    nd4spdbh
    SoCal
    24F will fit just fine and likely will have more CCA's. 27F just has more capacity (so you can run accessories longer). Like stated I happily moved to the 24F as availability is way better, they are cheaper, have more CCA's than a stock 27F ANNNND less weight to rip an inner fender out.
  14. Oct 9, 2019 at 2:21 PM
    13tacosport
    Arbi
    818
    13 Trd Sport
    sounds great to me. 24 or 27. thanks my so cal brotha
    nd4spdbh[QUOTED] likes this.
