Battery size?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ted383, Oct 2, 2022.
  1. Oct 2, 2022 at 12:02 PM
    Ted383
    Ted383 [OP] Tin Man
    Ted
    NC
    2017 TRD sport access cab magnetic grey
    OE battery in truck is 24F. Many posts hear say 27F. Auto Zone.com says BOTH battery's fit despite the 27F being over 1in. longer.
    Sorry if this has been covered here but I need a replacement ASAP.
    2017 TRD Sport
  2. Oct 2, 2022 at 12:06 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I think people were buying battery tie down clamp and /or kit from gen2s to hold the larger battery. I’m not 100% sure though, just answering to get your search started, as it sounds like you’re replacing now.
  3. Oct 2, 2022 at 3:46 PM
    gForceDude
    gForceDude Well-Known Member
    A 27F Battery will fit in your 2017, but you will need the larger battery tray from a 2nd Gen Off Road (the tow package came with a 27F and the larger tray), e.g. get the tray from a 2015 Off Road.
    Example:
    https://www.amazon.com/dp/B00FZSDHGG
    shakerhood likes this.
  4. Oct 3, 2022 at 2:55 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I did the 2nd gen battery tray when I upgraded to the 27F Toyota True Start. My battery I replaced was 4 years old @22k miles and not an issue. I did this because I knew the battery was on borrowed time so to me it was worth it. Bigger more capable and better specs was the win. I think my struck starts a litter faster and easier, idk but maybe my battery was going bad.
  5. Oct 3, 2022 at 3:02 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Did the original battery hold down work or did you have to replace that too?
  6. Oct 3, 2022 at 3:12 AM
    VaToy
    Parts Unknown
    Yes it worked just fine. All I did was the OEM tray for a 2015 Tacoma with a the tow package. I think the tray was like 30 bucks however some people have cut the end of the 24f tray and it works as well. It was a clean,simple install. The new tray drops right in to the holes, lines up perfect.
    FL_TRD Sport likes this.
  7. Oct 3, 2022 at 3:21 AM
    Ted383
    Ted383 [OP] Tin Man
    Ted
    NC
    Got it. Thanks guys!
    VaToy likes this.
  8. Oct 3, 2022 at 4:52 AM
    VaToy
    Parts Unknown
    Glad to help. It's a great little mod. I was in for a tire rotation and they check the truck over, the tech was kinda stumped when he saw it.
