Battery stock cable gauge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeachBoy, Jun 12, 2018.
  1. Jun 12, 2018 at 4:48 PM
    BeachBoy
    BeachBoy [OP] Well-Known Member
    VT & QC
    '09 DC LB Sport+Leather
    Icon Extended COs / Camburg UCA / ATX Predator Teflon / Mickey Thompson MTZ / Color-Matched emblems / All-Pro Bumper & skids / Stubbs HD-SKO / Alcans custom leafs / U-Bolt flip / Icon rear resi shocks / Rear Bumper
    I want to replace my battery terminals with the military style. For that, I need to crimp ring terminals to the stock cables that run to/from the battery.
    What's the gauge of those? Looks like there are two wires from the positive and one from the negative.
    Also, I saw a thread about upgrading the electrical wires to get higher voltage or chwrge level or something but cants find it, any clue?
    Thanks!
  2. Jun 13, 2018 at 2:10 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Lots of good info here: https://www.tacomaworld.com/threads...ts-see-them-multiple-batteries-thread.295653/
    OEM gauge for the ground cable and the positive to starter cable is 2 gauge. The battery to fuse box to alternator cable is 4 gauge. Upgrading the cables is a must if you will be putting a high output alternator, or relocating the battery. The only upgrade I would recommend for the OEM wiring is increasing the gauge of the ground battery to body cable. Otherwise, I wouldn't mess with the stock wiring. If I recall, you should be able to keep the OEM cables and adapt them to the military style terminals. You may have to do a little drilling connector bending, but it's doable.
  3. Jun 13, 2018 at 8:40 AM
    BeachBoy
    VT & QC
    I checked again today and the + cable going to the fuse box has already a ring terminal on it. So basically it's the large pos and neg cables that are currently crimped to the connectors that I want to change.
    Thanks for the link and info, I'll buy a cheap chinese hydraulic crimper and terminals!
  4. Jun 13, 2018 at 9:19 AM
    Sandyman
    Sandyman Well-Known Member
    Sandy
    Los Anchorage
    '12 DC Sport Limo
    Just me
    FYI, you can go to a Welding Supply store and get the flexible welding cable in your preferred gauge and it's fairly inexpensive considering the quality. It has really fine strands for lots of surface area to conduct.
    I also made my jumper cables out of 2 gauge when replacing battery cable in my Audi (battery under back seat).
    MTopp likes this.
