Battery Upgrade Qs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by microsnook, Dec 31, 2023.
  1. Dec 31, 2023 at 8:25 AM
    microsnook
    microsnook [OP] Well-Known Member
    '20 TRD OR MGM MT
    I’ve been thinking about upgrading my battery. I’ve seen some lithium options which are lighter and longer lasting but also read that they can’t charge and discharge properly with the alternator.
    I really just want a battery that’ll last a while.
    I have a bunch of lights and accessories but aren’t using them that often so it’s basically just for starting the truck and powering a fridge sometimes.
    does anyone have any recommendations ?
    thanks
  2. Dec 31, 2023 at 8:31 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Spend (way) more if you desire fancy "designer" volts. Otherwise buy a plain old Wally World battery and call it a day.
    grogorat, usmc2msu, wilcam47 and 7 others like this.
  3. Dec 31, 2023 at 8:31 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Don't overthink this ( like I did ).
    Go to Walmart. Buy the NeverStart ( haha: EverStart ) I think it's the 24F.
    I get the 36-month version and replace it every 2 years and fogettabout it.
    I power my Dometic via a 12-port ignition-only dongle rigged to the back and continue to power it
    with a Jackery 1000 Pro when we park for long periods of time.
    soundman98 likes this.
  4. Dec 31, 2023 at 8:34 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I put a Deka battery in my 2006 to replace a very good Interstate. the Deka is having a rough life since I don't drive that truck very often anymore. but it keeps on starting and on a multimeter, it holds the charge after a long hiatus.
    I loved that Interstate. it took me all over the country, with extreme tempuratures on both ends of the spectrum repeatedly. I only changed it after 8-9 years of service just because I was going into Idaho in a blizzard..and wanted the peace of mind.
    RIX TUX likes this.
  5. Dec 31, 2023 at 8:52 AM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Last a while? Are you talking about battery life time (years) or run time (hours) for your fridge?
    In my experience, most car batteries last about 4-5 years. This probably falls into the “don’t over-think it” category.
    If you’re talking about accessory run-time, then this does fall into the “you need to think about it” category. How much amp-hour capacity do you need to run “X” load for “?” hours. Also, you may want a dual battery set-up (starter/house batteries) so you don’t accidentally drain your only battery (even if it’s lithium) while enjoying a cold one out in the boonies.
    Lost of threads here. I’ve not installed extra batteries yet, so I’ll let the other experts assist.
    Chew and soundman98 like this.
  6. Dec 31, 2023 at 9:03 AM
    TacoTuesday1
    SD CA
    Dealer batteries are generally the best of a regular kind of battery without getting into other different kinds.
    previous local dealer only sold bigger than stock OE battery option. Had that for a while now without issue. Used to have a fridge.
  7. Dec 31, 2023 at 10:06 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    All batteries are made by less than a handful of manufacturers. They just put different cases and labels on them for the seller. Suggest just getting the proper size lead core from a store with a good warranty and price. Costco, Sams are examples. As others have said replace every 4-5 years. Use a battery maintainer.
    RIX TUX likes this.
  8. Dec 31, 2023 at 11:47 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    This!
    quality or capacity?
    Quality? there is little difference, buy a name brand from a local store that can and will support.
    Capacity for doodads? Get your manuals and calculator out.
    CB350G[QUOTED] likes this.
  9. Dec 31, 2023 at 11:56 AM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    Unless you need an extended reserve capacity. I suggest Walmart/Sams or Costco. Whatever is cheapest and has the best warranty.
    wilcam47 and RIX TUX like this.
  10. Dec 31, 2023 at 12:06 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Northstar. 6th year stock OEM charge system.
  11. Dec 31, 2023 at 12:10 PM
    TacoTuesday1
    SD CA
    Costco sells Interstate. Interstate sucks. Probably not something to do.
    wilcam47 and MannyS like this.
  12. Dec 31, 2023 at 12:43 PM
    canuck guy
    Alberta
    23TRDOR
    Not my experience in many very cold Canadian winters as well as others in various places.
    TacoManOne and BMH like this.
  13. Dec 31, 2023 at 6:28 PM
    microsnook
    '20 TRD OR MGM MT
    Great assessment and answers, thanks everyone.
    I just use my fridge when transporting food, so the truck is on the entire time = I don't really need larger capacity.
    When I get to camp, I have a bluetti for maintaining the fridge while parked.
    That NorthStar battery looks good.
    I am on year 4 I think with my battery without replacement. But sometimes it seems to have a hard time starting my truck and Im thinking its on its way out. Planning ahead.
    Cheers
    Chew likes this.
  14. Dec 31, 2023 at 6:31 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    4 years and slow starts? It’s past done, in my book, go get one when the store opens. I carry a jump pack, but still not trying to eke out another two dollars of life, at the risk of getting stuck or trying to jump it late at night in single digit temps.
    microsnook[OP] and RIX TUX like this.
  15. Dec 31, 2023 at 8:17 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    I’m in the minority on this but my stock battery gave up the ghost around 7800 miles in a ton of rough stuff in Saskatchewan. Started leaking.
    As I’m running starlink, a fridge, and about 2 million chargers for gps, iridium phone, and everything else known to man, and don’t want any more leaks, I went with a yellow top Optima. Has worked awesome in all temps and has good reserve with a lot of stuff running. Bought it in May. Only need it to last till I get back home in April.
    microsnook[OP] likes this.
  16. Dec 31, 2023 at 8:32 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I'm amazed that I'm the first to recommend this thread. All of the advice you seek is spelled out clearly within...
    Credit @crashnburn80
    https://www.tacomaworld.com/threads/the-northstar-agm-battery-voltage-booster-upgrade.604478/
    crashnburn80 likes this.
  17. Dec 31, 2023 at 8:33 PM
    uncle ed
    uncle ed Well-Known Member
    Ed
    CA Eastern Sierra
    2007 & 2019
    CCA
    Pick one based on highest CCA per $ amount that you can afford or want to pay
  18. Dec 31, 2023 at 9:28 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    My Group 31 AGM write up is over here :thumbsup: I may have gone with the Dakota Lithium battery, but I don't think it was out yet. :notsure:
  19. Dec 31, 2023 at 10:43 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    4 years and acting up? hope you have the phone number of a tow truck in your wallet
    Chew likes this.
  20. Jan 1, 2024 at 4:37 PM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    Same here.... I've bought nothing but Interstates for the last 30 years and never had a bad one once.
    mic_sierra and microsnook[OP] like this.
