Battery upgrade?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrArtixx, Aug 5, 2022.
  1. Aug 7, 2022 at 8:06 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i'm planning on running the stock battery group. only change i'm making is the battery terminals to the knuconcepts version for easier additional wiring lugs. current plans are distro block, winch up front, sound system in the order of around 1500w rms. i'm still playing with the idea of 4 winches out back for fun, and some additional emergency lighting. but my day-to-day load will be close to oem, so no need to upgrade to a larger capacity battery
  2. Aug 7, 2022 at 9:13 AM
    MrArtixx
    MrArtixx [OP] Well-Known Member
    2022 Lunar Rock OR Manual
    Maybe I just wanna have the biggest baddest bestest battery at the monthly mall crawl meet.. gosh.
  3. Aug 7, 2022 at 10:48 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    My Group 31 CBI battery tray install can be found over here. :thumbsup:
    Dfpftw likes this.
  4. Aug 7, 2022 at 1:17 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Only if you get the best, baddest lift with the biggest bad ass tires.
    soundman98 likes this.
  5. Aug 7, 2022 at 1:31 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    You can't Mall Crawl with 5100s, you need some Fox shocks. Now if your crazy as Hell, you can do some serious off roading on a spacer lift and some AT tires in a 4cyl. SR. Just saying.
  6. Aug 7, 2022 at 5:27 PM
    Sunsetsearider
    Sunsetsearider Well-Known Member
    San Francisco
    2017 DCLB OR/1998 5 Lug
    If you don't get the charging voltage up with your AGM, you can put it on a trickle charger to keep it from dying prematurely.
  7. Aug 7, 2022 at 5:47 PM
    MrArtixx
    Reading through I saw you changed out the oil filler spout. Why did you use the one you did? Different angles or what?
  8. Aug 7, 2022 at 8:44 PM
    RyanDCLB
    4/19 DCLBOR
    The group 31 has cracked many a stock oil filler spouts if the battery shifts. Changing it out is more of a failsafe maneuver :thumbsup:
