Battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Oct 17, 2010.
  1. Oct 17, 2010 at 10:15 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    how long after did you guys change yours???? mine is a 06 never changed yet
  2. Oct 17, 2010 at 10:18 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    My 05 battery lasted 5 years. The date on the battery was from 04. There wasn't any sign of my battery failing. I stopped at a store, came out & nothing. No clicking sound, no dash lights, nothing, just dead.
  3. Oct 17, 2010 at 10:19 PM
    Series1000
    Series1000 Well-Known Member
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    Lots
    I have an 07, Just swapped it out for a red top. nothing wrong with the stocker though.
    I think 5-ish years is normal but some see 10 years before failing
  4. Oct 17, 2010 at 11:08 PM
    pinktaco808
    nahhh, ok which optima should i get for my truck the red or the yellow????
  5. Oct 17, 2010 at 11:11 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    X2, My truck is an 05 and I just changed it a couple weeks ago. Exact same thing.
  6. Oct 18, 2010 at 7:10 AM
    Series1000
    Vancouver Canada
    Lots
    The red top is marketed as a starting battery, the yellow top it marketed as a deepcell heavy electrical load battery. If you are going to run a winch and a big stereo and a buncha lights, get the yellow top. Im going to run a dual set up as I have a extra yellow top.
  7. Oct 18, 2010 at 7:22 AM
    Jcannon
    Jcannon Well-Known Member
    Jay
    OKC, OK
    05 DC 4x4 TRD OR
    Just swapped out stock battery out of my 05 this weekend. Started at the house, the gas station, then nothing at the next stop. No warning signs at all. Had the battery tested and tested bad.
  8. Oct 18, 2010 at 7:34 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Still running the stock battery in my '07 and getting nervous about all the sudden failures... I'm starting to wonder when I'm going to be stranded, or more importantly where I'll be.
  9. Oct 18, 2010 at 7:56 AM
    06redtacoma
    06redtacoma Well-Known Member
    Alabama
    06 Trd Offroad
    Lifted, Slider, stock rack, rear mounted winch in stock bumper, brush guard, Sound system, ipod to car, tint, wheel spacers, 285 bfg AT,
    my 06 got replaced earlier this year, but i have a sub and winch and lights so im really happy with how long it lasted i am a gluten for punishment so i didn't upgrade it, lets see how fast 2 winches can kill a battery!
  10. Oct 19, 2010 at 6:43 AM
    pinktaco808
    here another question though, how hard is the install??? i seen where they had to mod the terminals for the yellow, any help???
  11. Oct 19, 2010 at 8:30 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    This is scary shite. When did batteries start to just die instantaneously ? They use to warn you by cranking slowly. What would be the best way to protect yourself ? Carry a spare battery after 4 year or just replace it after 4 years, lose a year of service and be safe.
  12. Oct 19, 2010 at 8:59 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    had my '05 battery in for 4 years before I got an Optima Red Top 75 series...no signs of failing and I had to get a jump just to get it started...
    but I blame it on the heat of Vegas especially during the summer...105*F+ temps kill the batteries really quickly...
  13. Oct 19, 2010 at 9:30 AM
    Navigator
    Navigator Well-Known Member
    Ontario, Canada
    05 DC Sport 6spd
    17" American Racing Assaults on 265/70/17 Goodyear AT/S, TRD Exhaust, TRD CAI, Toyota Roof Rack, XM install with antenna out 3rd brake light, Red LED Map Lights, AUX Amber LED rocker switch for LED footwell lights, LUND Bug Screen, EXTANG Tri-Fold Tonneau, Hertz Component Speakers w/ TacoTunes Mounts, Infinity Kappa 4 amp, Image Dynamics 10" sub in TacoTunes enclosure, Pop n' Lock, Toyota Aluminum Wedge Running Boards, BHLM, Self Performed '05 Cowl Leak TSB, E-Z Cool Insulation/Sound Deadener applied to floorboard, headliner, and cab bulkhead, 896 Foglight bulbs as backup lights, Weathertechs, Pioneer Double Din, Scan Gauge, AutoSoft Remote Start, 2010 4Runner Heated/Signal/Puddle Mirrors.
    Still running the original battery dated 11th month of '04. No issues yet....I hope I get another winter out of it. I may use the load tester on it before the snow flies, just to be sure.
  14. Oct 19, 2010 at 9:49 AM
    george3
    New Jersey
    I think we have a load tester at work. It that a sure thing ? If it passes you're good to go for the winter ?
  15. Oct 19, 2010 at 10:28 AM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    mine took a shit last year. now i have an optima
  16. Oct 19, 2010 at 1:07 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i have an 06. stock battery. i had the battery load tested and it is still kicking arse. it isnt perfectly healthy, but it is still showing strong life.
    i bet the moment i take it into some harsh enviornment (hot or cold) it will die.
  17. Oct 19, 2010 at 1:45 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Mine just went.....Put a die hard platinum in.
  18. Oct 19, 2010 at 2:30 PM
    george3
    New Jersey
    So it only lasted 3 years. :eek: 2 years less then the 5 people are saying they go after.
  19. Oct 19, 2010 at 3:08 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT Well-Known Member
    Colin
    Fort Wayne Indiana
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    mine battery called it quits about 2 months ago and bought an optima, was sold the wrong size so i returned it and put a toyota battery in...mines an 06
  20. Oct 19, 2010 at 3:50 PM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    Where I live if a battery lasts three (3) years I am lucky...:(
    The heat kills batteries, and they might start in the morning and by noon not even crank! :eek:
    I check the water level (distilled) every month and top off the charge every couple of months just to be safe! :pray:
    Yuma Taco,
