Battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Oct 17, 2010.
  1. Nov 14, 2010 at 9:21 AM
    #41
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Well.. I decided to go for the Optima at Costco..
    However, it ended up being a Optima Red Top 75/35 series, I guess I didn't study up on this enough because this battery wouldn't fit in my truck. The cables wouldn't reach. I wasn't about to mess with trying to make it work, so I returned.
    I started researching and found that consumer reports rated the Duralast Gold very high. I went with it. It dropped right in with no issues. The cost was only $89, so I guess I saved myself a little money. We will see how it lasts.
  2. Nov 14, 2010 at 10:32 AM
    #42
    jg7
    jg7 Active Member
    I usually start to see some corrosion on the battery terminals when they are about to go bad at about 5 yrs.
  3. Nov 14, 2010 at 10:48 AM
    #43
    l_prettyman
    l_prettyman Well-Known Member
    Logan
    Maryland
    18 TRD Offroad
    my truck is an 06 and just changed it in july 2010. drove it from maryland to tennessee and when i got there, it died. had to pay almost twice as much for it than i should have, but i needed the battery cause i was a ways from home haha
  4. Nov 14, 2010 at 11:47 AM
    #44
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I have seen a lot of post about problems putting the Optima Red Top in a Tacoma. Is there a Optima Red Top part # that makes it a no brainier like if you just went to Sears and got their better battery ? Thanks.
  5. Nov 14, 2010 at 10:00 PM
    #45
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    yes was asking tooo
  6. Dec 9, 2010 at 9:49 AM
    #46
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    I have an 05' and it just failed me today before a final. my luck :(
  7. Feb 7, 2011 at 10:57 AM
    #47
    SurfnWolf
    SurfnWolf Well-Known Member
    Fayetteville NC
    2006 Tacoma Prerunner Double Cab
    I have an 06 with 75,000 and mine is just showing signs of giving out. For one..the little eye was black, meaning low or discharge, it was really low on water..so i added some..then just the cranking was slow...So I went with the Toyota Brand...True2 or something, which i understand is an interstate , just $78.00 at your TOYO dealer.
  8. Feb 7, 2011 at 11:06 AM
    #48
    07taco09
    07taco09 Active Member
    matt
    charleston s.c.
    07 prerunner sr5
    Debadged, tinted windows, tinted tail lights, BHLM, Satoshi grill, Fog light mod, yellow fogs, paint center valance, 265/75/16 at's. TRD cold air intake. borla exhaust
    mine crapped out about a month ago. I bought it new in 07
  9. Feb 7, 2011 at 2:04 PM
    #49
    TheProphet
    TheProphet Active Member
    Canada,Quebec
    trd
    westin pull bar/off-road light Bf goodrich All-terrains for winter with oem mag wheels moto metal 16*9 / hankook dynapro MT for summer 2500k nokya hyper yellow narva h4 headlight diff breather mod inverter 400w mod l.e.d for the cab 4*4 illuminated switch mod l.e.d bed light mod
    I have an 09' and it just failed me last week at minus -31°F. The dealership tow my truck and changed it for a better battery...no cost to me!
  10. Feb 8, 2012 at 6:22 PM
    #50
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    mine just died today... 3 1/2 years of service with no abuse:mad:
  11. Feb 8, 2012 at 7:03 PM
    #51
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I still have the original 2006 battery in mine and it "kicks ass" when I hit the key.... I guess I should be looking for another one....from what you guys are saying: however, it looks like the southern (hot climates) seem to be harder on the batteries than the "Great White North".... Go figgure..... So then why do they measure the "cold cranking abilities" of the battery...???... Maybe they should measure the "hot cranking abilities" instead.... (down south, of course).... hehe
    Over....??
  12. Feb 9, 2012 at 1:26 PM
    #52
    george3
    New Jersey
    Battery should last 5 years. You have a right 2 B [​IMG]. Do you thing it's the Florida heat ?
  13. Feb 9, 2012 at 2:29 PM
    #53
    TerryS
    TerryS Well-Known Member
    Terry
    Cape Cod, Mass.
    '24 Celestial Silver DCLB SR5
    OEM cast aluminum running boards & tonneau cover.
    My dealership found that the battery on my 2010 had failed when they tested it at 15k miles. They replaced it under warranty.
  14. Feb 11, 2012 at 5:29 PM
    #54
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Do you know what the particulars about warranty coverage is?
  15. Apr 7, 2012 at 1:00 PM
    #55
    Tacoma333
    Tacoma333 Active Member
    NV
    Tacoma doublecab 4wd SR5
    3" lift
    Mine lasted almost 5 years (2 months short)
    I bought a XL battery for it, see how long that one last
  16. Apr 7, 2012 at 1:03 PM
    #56
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    My 06 went out December 2011. About 50k miles. Replaced with optima.
  17. Apr 7, 2012 at 1:38 PM
    #57
    george3
    New Jersey
    A guy I work with has a optima yellow top. Been working for 10 years. I know the average battery last about 5 years like yours did. I wonder what the average life of a yellow top is:confused:
  18. Apr 7, 2012 at 1:58 PM
    #58
    dYL0n
    Dyl0n
    New Orleans, LA
    I hope to get a good amount of years out of it. Expensive ass battery.
  19. Apr 7, 2012 at 2:08 PM
    #59
    george3
    New Jersey
    Yes it is that is why I hope some TW members with experience will chime in. Mine is 4 years old so I'm due within the the next year or less. I'd just as soon buy a battery before I get stuck and maybe have to pay for a jump.
  20. Apr 7, 2012 at 2:19 PM
    #60
    TastyHuman
    TastyHuman Oh. Bummer.
    Bought mine in January of 07 and it's still cranking fine. I have been thinking about replacing it (the truck, not the battery).
