Battle the water spots?
Discussion in 'Detailing' started by jrdbrn, Oct 8, 2011.
  1. Oct 8, 2011 at 1:15 PM
    jrdbrn
    jrdbrn [OP] Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    OK, first off... I am not lazy. Water tends to dry before I can wipe down my truck leaving water spots. We have some pretty hard water here and the water spots are brutal. The Mr. Clean AutoDry isn't easily found anymore and I was looking for alternatives.
    I seen this product on Amazon and was wondering if it would stop the water spots? It says it's for RVs, but a filter is a filter?
    http://www.amazon.com/Culligan-RV-6...ttings/dp/B000VQHRCC/ref=cm_cr_pr_product_top
    Anything else I should see?
  2. Oct 8, 2011 at 1:22 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I always dry my vehicles with a spray detailer. In the summer I pull into the garage before it drys and wipe it down there. Out of the sunlight.
  3. Oct 8, 2011 at 1:24 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    idk what you could do.
    but what i do is keep the hole truck wet till the hole truck is washed. like if i cleaned the roof i still spray water on it after i washed the soap of. even if i’m on my bumpers (i do roof first and tend to do bumpers last) but i keep the hole truck wet till i’m done washing. and dry it and move on to wheels and tires. and if i miss a little spot it’s not to bad on the silver. but windows you can really tell if i just let it air dry.
  4. Oct 8, 2011 at 1:25 PM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    I also use a TurtleWax spray detailer afterwards, but these water spots get bad.
  5. Oct 8, 2011 at 1:26 PM
    TacoDawgfan
    Georgia
    Yeah, keep it wet until ready to dry it off.
  6. Oct 8, 2011 at 1:27 PM
    TacoDawgfan
    Georgia
    Maybe because of the color? My wife's car is gray also but haven't had issues with that. It is a bit harder to detail though.
  7. Oct 8, 2011 at 1:31 PM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    I had silver and traded for MGM... HUGE DIFFERENCE
    Can't do that anymore
  8. Oct 8, 2011 at 1:36 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    oh yeah i bet!
    but yeah i just keep it wet till i’m done washing.
  9. Oct 9, 2011 at 3:41 PM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
  10. Oct 25, 2011 at 2:52 PM
    Opihiman10
    Opihiman10 Active Member
    Honolulu, Hawaii
    2011 double cab 4x4 TRD SR5
    Nerf bars
    wash at night....with my old black truck, that was the only way to keep from getting water spots from washing....in the end....mother nature will find a way.
    OPI
  11. Oct 25, 2011 at 3:00 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I usually keep misting the truck as a wash to keep it wet and then I dry the whole truck using a shammy cloth. As others have said, wash in the shade if you can, it helps!
  12. Oct 25, 2011 at 3:00 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Silver paint ftw. I don't have to worry about it on my Tacoma but all the other cars that belong to my household are dark colored(Red, Black, Blue). I just keep them wet all over until I'm done then go for a drive to dry everything off.
  13. Oct 25, 2011 at 9:37 PM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    ^This.
    I always wash the truck in the shade.
  14. Oct 25, 2011 at 9:43 PM
    Wolfrunner
    Wolfrunner Well-Known Member
    Graham, WA
    '04 Tacoma Double Cab SR5
    Grey wire mod, 17" tundra wheels powder coated
    As far as the spots on the paint it is what it is. but a guy that tints windows gave me a great idea for the glass. He used shower glass cleaner from the hardware store. Its almost like a really soft scrub for the windows. No hard water spots after that.
  15. Oct 27, 2011 at 4:04 PM
    Oat
    Oat Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    I wash it in the shade of my driveway, and at the end i re-spray the whole truck so its soaking wet. Then i pull it into the garage to dry.
  16. Dec 7, 2011 at 1:58 AM
    KevinG
    KevinG Member
    Kevin
    Chandler, AZ
    2010 TRD Offroad Double Cab
    Water spots are really easy to prevent.
    For anyone who doesn't know, water spots are simply mineral deposits that were disolved in the water. If you remove the minerals from the water (deionized water), you won't get any water spots. No need to dry your vehicle!
    Here's what I did...
    I got a Reverse Osmosis system from Lowes (I'm sure the brand doesn't matter, but I believe mine is a Whirlpool). I have it hooked up in my garage with a 1/4 turn ball valve on the output hose. I use normal tap water to wash the truck (like other people have said... keep it wet!), but I rinse with the RO water. I get everything set up to wash, then I stick a 5-gallon bucket under the RO hose and open the valve. I wash the truck, and about the time I'm done, the bucket is about full (The output pressure is really low). I pour about a third of it over the roof, then some on the hood, each side, and the tailgate.
    I've been doing it for years. The RO systems are relatively cheap (I think I paid $70 dollars for mine... though I don't really remember).
  17. Dec 7, 2011 at 2:10 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    be glad you guys dont have to drive by hotels and irrigation that uses recycled water.
    that stuff....
    goodbye, clear coat.
  18. Dec 7, 2011 at 1:46 PM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    +1
  19. Jan 1, 2012 at 9:18 AM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    use a leaf blower..like me
  20. Jan 21, 2012 at 3:07 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    +1 on keeping the whole vehicle wetted down until you're ready to start drying... i use a nice big microfiber cloth to dry.
