BayAreaTaco's Expo Crawler. Custom 1 ton SAS!
Discussion in '1st Gen. Builds (1995-2004)' started by bayareataco, Jul 21, 2013.
  1. Mar 8, 2015 at 8:58 PM
    #481
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Mm gotcha, looks kinda like cheap alternative to neon lights haha. But yea I bet, that'd be amazing! Love to wheel in the desert some day
  2. Mar 8, 2015 at 8:59 PM
    #482
    PatriotOfAmerica
    PatriotOfAmerica Well-Known Member
    Reed
    Good Ole' Kentucky
    03 Jade Mica DC TRD 4x4
    33'' kanati mud hogz arb front bumper are camper shell 42'' cree light bar color match fender flares
    Lol would do me no good...wish it would but kentucky just ain't the wheelin/crawling state
  3. Mar 8, 2015 at 9:00 PM
    #483
    bayareataco
    bayareataco [OP] Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
  4. Mar 8, 2015 at 9:59 PM
    #484
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Rock lights are also good when you need to work on anything under the truck and it's dark outside ;)
  5. Mar 8, 2015 at 10:17 PM
    #485
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Yessir!!
  6. Mar 8, 2015 at 10:42 PM
    #486
    PatriotOfAmerica
    Reed
    Good Ole' Kentucky
    Hey jimmy what re-gear did you go with to run those 35''s?
  7. Mar 8, 2015 at 10:43 PM
    #487
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    5.29 Nitro gears
  8. Mar 8, 2015 at 10:47 PM
    #488
    PatriotOfAmerica
    Reed
    Good Ole' Kentucky
    Oh ok cool, can't decide for the future to go with 35'' or stay with 33''...not sure what all you would need in order to run 35'' tires...and I'd assume It would bog the truck down substantially
  9. Mar 8, 2015 at 10:48 PM
    #489
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Yeah, gears also depend on auto or manual.
    I believe for 33" tires if your manual you want 4.56 while auto needs 4.88
  10. Mar 8, 2015 at 10:50 PM
    #490
    PatriotOfAmerica
    Reed
    Good Ole' Kentucky
    I'm auto and i run 33" right now..not a clue if i'm running 4.88 or not...I would assume what came with it from the factory
  11. Mar 8, 2015 at 10:50 PM
    #491
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    I believe 4.10 came factory
  12. Mar 8, 2015 at 10:53 PM
    #492
    PatriotOfAmerica
    Reed
    Good Ole' Kentucky
    Is it rough on the truck to run 4.10 with 33''? And what would be the benefits swapping to 4.88?
  13. Mar 8, 2015 at 10:56 PM
    #493
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Not that i know of.
    This is still stuff im doing research on so i cant really comment on it maybe someone else will step in.
  14. Mar 8, 2015 at 11:07 PM
    #494
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    The benefits of doing a re gear are to gain your power back mainly. You loose a lot of power when you put bigger tires on, especially with an auto tranny. With the 35s and the stock 4.10s my truck was a bit of a dog. I probably would have gone with 4.88s had I not gotten a deal on a used front diff with 5.29s.
    It's not terrible on the truck and you are fine with stock gears on 33s. I would say most don't re gear with 33s, but if you feel like you are lacking power with the bigger tires than go for it.
    I think what stops most people is the price, front and rear gears will run you anywhere from $1000-1500
  15. Mar 8, 2015 at 11:08 PM
    #495
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Running 35s you will need coilovers, most likely wheel spacers, and you will need to tub the firewall, meaning cut a huge hole and weld in new metal because the tires will rub so much, you will also most likely need to cut the fenders
  16. Mar 8, 2015 at 11:11 PM
    #496
    PatriotOfAmerica
    Reed
    Good Ole' Kentucky
    Ok cool thanks man for the info
  17. Mar 8, 2015 at 11:25 PM
    #497
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Anytime, ask anything you need to!
  18. Mar 9, 2015 at 5:20 AM
    #498
    cynicalrider
    cynicalrider #NFG
    Jersey
    Don't forget the offroad benefits too. When you are on stock 4.10's and on larger tires your crawling speed in 4low is much faster than stock. Messing with the gearing brings that back in check.
    Also the rock lights look damn good!
  19. Mar 9, 2015 at 8:42 PM
    #499
    PatriotOfAmerica
    Reed
    Good Ole' Kentucky
    Yeah, unfortunately not a lot of places to go wheelin around here
  20. Mar 15, 2015 at 8:02 PM
    #500
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Busy day today, re did my under hood lights. I replaced the shitty led rope light that wouldn't stay attached with a single led rock light, made the wiring clean this time. Moved my ammo cans and got to use to new riv nut tool, love It! If you don't know what it is, it rivets a nut into place, basically like welding a nut onto the backside of a panel without all that work. Added a low range off road locker skid, took a little bit of grinding to get it to fit perfect, and lastly I installed a few more rock lights in the rear but they wouldn't turn on so no pics until I figure that out.
    Riv nuts
    If anyone is interested this is the kit I bought, it's really nice! Well made.
    http://www.amazon.com/Astro-Pneumat...e=UTF8&qid=1426474931&sr=8-1&keywords=Riv+nut
