Beach Driving
Discussion in 'Off-Roading & Trails' started by Tommo, May 29, 2011.
  1. May 29, 2011 at 11:40 AM
    Tommo
    Tommo [OP] Well-Known Member
    Fairfax, VA
    base 4X4
    I have a 1990 Toyota standard 4X4 with Yokohama 31x10.5x15R Geolander AT/S tires. How much air pressure should be let out of the tires for driving on the beach? Thank you very much in advance for any information.
  2. May 29, 2011 at 11:45 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
  3. May 29, 2011 at 11:47 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    20 PSI
  4. May 29, 2011 at 11:48 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I'm usually about 15-20 psi for sand. If you are comfortable that you have good traction and a wide contact patch-That's probably enuf.
  5. May 29, 2011 at 11:48 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    ^^^ what he said. I've vacationed at the N.C. Outer Banks and used to air down to 15 psi for beach driving.
  6. May 29, 2011 at 11:50 AM
    Tommo
    Fairfax, VA
    base 4X4
    Thanks very much again for the quick responses!
  7. May 29, 2011 at 8:03 PM
    Fire Force
    Fire Force Well-Known Member
    Ian
    Houston, TX
    2010 4x4 SR5 TRD Offroad (mostly stock)
    Bull bar, UWS toolbox, Yaesu FT-8800R dual band ham radio
    I have no experience with airing down for offroad -- what are some (if any) considerations you have to think about?
    Do I need to stay under a certain speed? Things like that. Speaking from a total newbie's standpoint!
  8. May 30, 2011 at 4:50 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If you take the pressure too low your tire can lose the bead. So I have never gone below 10PSI for anything. If you have beadlock rims you can think about it...but I wouldn't get beadlocks on your rig quite yet.
    You shouldn't drive on the pavement more than a couple miles at low speeds or you risk damage the tires...so depending on where you wheel you'll want to get a compressor.
    Anyone else got anything to add??
  9. May 30, 2011 at 8:21 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I air down to about 18-20 psi when driving at the OBX, that way I can drive on the street without having to air the tires back up. It's just a little cushy on the road and you can't corner hard when the tires are at 20 psi.
    Most of my street driving there is to and from the beach anyways so it's not that far.
  10. May 30, 2011 at 11:27 AM
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    VA country, your running at 30 in sand? what tires?
  11. May 30, 2011 at 11:46 AM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    Make sure you rinse as soon as you get off the beach.
  12. May 30, 2011 at 5:44 PM
    s7racing
    s7racing Well-Known Member
    I run full pressure at the beach 44psi with no problems. If it's pretty flat you can prob get away with it at full pressure, which saves you the hassle of having to air back up. With that said though it is amazing what a difference dropping down will do, when I'm at 14 psi I can dune in 2wd no problem!
    I suggest your first time you def go down to at least 25 though and get a feel for how things handle, and if you start to sink dont bury yourself, let more air out and be real easy on the gas when starting from a dead stop. If at all possible stop on an incline so you take off down hill
  13. May 30, 2011 at 6:21 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    If the sand is wet and I might get traction I start at 12-15, if its soft I run 8-10. Michigan sand is very soft in many years of wheeling never spun a bead.
  14. Jun 2, 2011 at 6:18 PM
    dpak
    dpak Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Toytec/Eibach coils w/ 5100's set at 0, Toytec 2.0 Aluma Rear Shocks, Toytec Boss Leaf Springs, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, Elusive Elements Mesh Grill
    when driving on the sand, are yall in 4wd or in 2wd and if you get stuck, then switch it to 4wd?
  15. Jun 2, 2011 at 6:27 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    It's generally not encouraged to try to switch into 4WD AFTER you get stuck, it's not very effective that way. If you're in soft stuff and there is any question, you should be in 4hi.
  16. Jun 2, 2011 at 8:33 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Depends on the type of sand and weather/ moisture... Soft, dry sand may need to be done at 10-15 psi. Firm, flat sand may be done at full pressure. The floatation effect doesn't begin really until you are down to at least 15 psi... Put in in H4 before you get into the deep stuff... don't be stupid... We are supposed to use it for 10 miles a month, anyway... so use it! See my sig. link below about beach driving at 15 psi vs. 32 psi. When delflated, avoid sudden turns, braking hard, and high speed... Always have a good battery connected air pump to inflate when off the sand. I was on the beach over Memorial Day weekend, in Baja... Trip report with photos coming soon!
  17. Jun 3, 2011 at 7:26 AM
    Tommo
    Fairfax, VA
    base 4X4
    Does anyone have a portable power source for jump starting or inflating tires? If yes, what kind, thanks?
  18. Jun 3, 2011 at 7:30 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    smart man.
  19. Jun 3, 2011 at 7:31 AM
    97yota4wd
    Eric
    Mesa, AZ
    you can get a air pump that can connect to your battery or plug into your cigarett lighter
  20. Jun 3, 2011 at 8:35 AM
    David K
    Here are my Dynapros on the beach in Baja last weekend... 14 psi:
