BeachBurner OVRLND racks
Discussion in 'Tonneau Covers, Caps and Shells' started by BeachBoy, Feb 4, 2019.
  1. Feb 6, 2019 at 1:27 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Can't wait! I want cab and shell racks, as close to the roof as I can get them!
    tundraconvert likes this.
  2. Feb 6, 2019 at 7:59 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    I, too already have a roof rack made by another member and it sits close to the roof. Would really like to have a matching shell rack and adjustable height is so clutch! Can't wait.
  3. Feb 8, 2019 at 6:35 PM
    Barnburner
    Barnburner Well-Known Member
    2015 Tacoma SR
    Broke out my real camera to snag some shots of the rack.
  4. Feb 9, 2019 at 12:49 PM
    BeachBoy
    BeachBoy [OP] Well-Known Member
    VT & QC
    '09 DC LB Sport+Leather
    Icon Extended COs / Camburg UCA / ATX Predator Teflon / Mickey Thompson MTZ / Color-Matched emblems / All-Pro Bumper & skids / Stubbs HD-SKO / Alcans custom leafs / U-Bolt flip / Icon rear resi shocks / Rear Bumper
    Prints in.
    I need to buy files and cutting pliers to clean up the parts
  5. Feb 12, 2019 at 2:50 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Very cool.
  6. Feb 25, 2019 at 5:13 AM
    BeachBoy
    VT & QC
    This is the end of the sidebar in 1:10, meaning we're close to getting a real prototype cut.
    Allows for basket mode, regular mode with "hoops" up, flush mount with hoops up, and the added vertical front and/or rear crossbar when using standard mode.
    The diamonds in the center are not 100% final yet but they hold a big surprise. And the blank area is for the logo, that we need to make readable upside down and from both sides of the truck (not an easy task to design)
  7. Feb 25, 2019 at 5:37 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    I'm assuming "basket mode" means it can be mounted using the lower set of slots, making the rails sit up higher, like side walls? If so, that is EXACTLY what I've been wanting!
    outxider likes this.
  8. Feb 25, 2019 at 5:54 AM
    Barnburner
    2015 Tacoma SR
    @destin_meeks that's exactly it. You can mount in the lower slots with hoops up - or for max height, you can flip the plates and mount your crossbars in the hoops too.
    Here's a mockup with hoops up.
  9. Feb 25, 2019 at 5:56 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Nice! I want solar panels mounted up there but they stand up too high on most racks and people can see them. I like that I could sink them down below the side rails keeping them hidden
  10. Feb 25, 2019 at 6:28 AM
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    Interested
    ready6delta likes this.
  11. Feb 28, 2019 at 6:02 PM
    Mac1owry
    Mac1owry Well-Known Member
    Corpus Christi TX
    2012 Baja TX
    Following, want to get both cab/cap racks
  12. Feb 28, 2019 at 8:54 PM
    outxider
    Sang
    East Bay, CA
    06 DCSB 4x4
    Received my short bed side plates and with a quick mock up, it'll look great mated to the Martin off road roof rack. Finish is off so i might just shoot it with bed liner to match. Anxiously waiting for your adjustable mounts. :spending:
    Barnburner likes this.
  13. Mar 1, 2019 at 1:53 PM
    BeachBoy
    VT & QC
    I redesigned slightly the adjustable mounts V1 (we are working in parallel with 2 versions), printing tomorrow for a real prototype soon.
    We were able to make them even more compact by using tubing instead of bent plate, removing the radius constraints. They are incredibly compact compared to anything else like my smilttybilt.
  14. Mar 2, 2019 at 10:20 AM
    Gtboosted
    Gtboosted Well-Known Member
    Beto
    2019 DCSB SR5
    I'm in for updates.
    Was doing research for a rack and glad I came across this thread.
  15. Mar 2, 2019 at 1:23 PM
    #35
    BeachBoy
    VT & QC
    Some updates
    - Square brackets do work, I need to widen a little to clear the screws holding the bottom and top together.
    - it's getting together nicely. I will buy real hardware as the 3D prints do not allow screwing together (nylon jam nuts cannot fit as when printed they are hard plastic)
    Pictures
  16. Mar 3, 2019 at 10:57 AM
    #36
    Boltgun
    Boltgun Member
    Ontario, Canada
    don't have one......yet
    Beachboy,
    will you be doing side plates for the cab? DCLB....also do you have provision to ship to Canada?
    Boltgun
  17. Mar 3, 2019 at 5:42 PM
    #37
    BeachBoy
    VT & QC
    Of course on both, my truck is dclb.. and I am Canadian
    YMMPRO, tundraconvert and elmontemike like this.
  18. Mar 4, 2019 at 9:58 AM
    #38
    BeachBoy
    VT & QC
    More prints.. updated lower bracket that is also used for fairing (less different parts), now wider for more clearance and full ±90 degrees adjustment (to use in the bed rails if you need). 3/8 hardware w/ nylon lock washers
    That's the fairing attachment when you don't have a full width vertical crossbar. This allows to use and adjust the fairing for angle and height for any setup.
    It means you should be able to rest the bottom of the fairing on the truck with a seal and block wind noise as much as possible.
  19. Mar 15, 2019 at 10:26 AM
    #39
    97duc748
    97duc748 Well-Known Member
    07 Tacoma
    Snugtop, lift, Prinsu Rack and lead foot.
    This looks awesome. I really like the modular design of the side rails. Do you have any assembled dimesions? I have a PrinsuDesign rack on my 07 DBCB and want to get something to match now on the canopy.
  20. Mar 15, 2019 at 3:37 PM
    #40
    ovrlandfam
    ovrlandfam Well-Known Member
    10' dbl cab TRD sport
    Trail gear tube rear bumper, Westin brush guard,
    Any updates?? Anticipation is killing me! All joking aside, great work so far!
    2 questions for those that may know:
    What’s the bolt/thread size of the mounting holes on our roof?
    Any 2nd & 3rd GEN owners know if the bolt hole locations on the two vehicles are the same? Will GEN 2 rack bolt onto a GEN 3 roof??
