Beating the dead horse: Taco Lean
Discussion in 'Suspension' started by malander, Sep 8, 2011.
  1. Sep 8, 2011 at 9:54 AM
    malander
    malander [OP] Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I have bilstein 5100s set at 0" with OME 883 coils. After about a week with this set up I threw in a top plate spacer for the driver side...that was about a year ago. As I measure (on level ground) I'm still sitting 0.5"-0.75" lower on the driver side. Have I done everything I can do besides get adjustable coilovers? Should I just do donuts everyday for an hour? Anyone?
  2. Sep 8, 2011 at 10:22 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Keep turning left :D
    Sorry, I don't have an answer for ya, sounds like your coils have settled.
  3. Sep 8, 2011 at 10:26 AM
    malander
    max
    01 limited trd 4x4
    At least the drivers side has. I drove around with 200lbs in the passenger seat footwell but it got old having passengers with their knees to their chest and I always got questioned about it
  4. Sep 8, 2011 at 10:33 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Take out the 1/4" taco lean spacer and put in a 1" top plate spacer or buy coils that have 1" more lift than the ones on the truck now and put one of them on the driver's side or just quit looking and measuring? Sorry, that's all I got.
  5. Sep 8, 2011 at 10:40 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Throw a slightly longer shackle on the driver's side?
  6. Sep 8, 2011 at 10:52 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Aw, shit wasn't thinkin right. You have 5100s so just set the driver's side spring perch on the .85 preload setting and call it good..........no need to purchase any additional stuff. It may ride weird having stiffer coil on one side but hey, it'll be level.
  7. Sep 8, 2011 at 11:52 AM
    malander
    max
    01 limited trd 4x4
    The rear end is pretty new actually so the lean isn't that bad in the rear. I don't want to add lift since the cv angles are already pretty bad. I guess I'm just looking for ideas to lower my pass side
  8. Sep 8, 2011 at 1:20 PM
    malander
    max
    01 limited trd 4x4
    It's noticeable to me and it kinda pisses me off that I buy new parts and they settle unevenly when the coils that had 110xxx miles on them were dead even
  9. Sep 8, 2011 at 1:23 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    I have ome's too sand they settled but it was even...
    Edit: wait a minute, you have a spacer on your driver side and the passenger is still Almost an inch higher?
    did you check before you installed if one coil was longer or driver side specific?
    i can't remember if mine were but that is a large difference...
  10. Sep 8, 2011 at 3:39 PM
    malander
    max
    01 limited trd 4x4
    The lean isn't very noticeable from the rear end, just a little bit and im running allpro expos...but I really am not worried about the lean out back. I'll try stacking some wood or something but I don't know how much that will help
  11. Sep 8, 2011 at 3:41 PM
    malander
    max
    01 limited trd 4x4
    That is correct. Coils are the same 883s
  12. Sep 8, 2011 at 4:07 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Try pulling out the coils/struts and switching sides and see what happens! It's free right.
  13. Sep 8, 2011 at 6:16 PM
    malander
    max
    01 limited trd 4x4
    Oh shit don't even get me started on my frame :(. It's going to rust out before I reach 150,000
  14. Sep 8, 2011 at 7:05 PM
    malander
    max
    01 limited trd 4x4
    That about explains it. I doubt many people would think it was the same suspension set up if they saw pictures of each side individually.
  15. Sep 8, 2011 at 7:58 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    I would try it at least before spending money on anything, whether it does anything or not,
    process of elimination by buying new things can get expensive.
    Good point I didn't even think about the frame.
  16. Oct 22, 2011 at 10:22 PM
    CurboCycles
    CurboCycles Well-Known Member
    Curtis
    Phoenix, AZ
    BLACOMA
    AFE CAI, Flowmaster muffler, Donahoe Racing 2.5" Coilovers, all-pro 3" leaf springs, 5100s, 17" Method wheels, 285 Terra Grapplers, Avid step bars, scooped hood, painted bumper, debadged, black grill and Toy symbol.
    Installed some 3" all-pro leaf springs today and passenger side is 1.25" higher! What gives?
