Bebop’s Texas summer A/C thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bebop, Jun 29, 2018.
  1. Jun 29, 2018 at 8:23 PM
    Bebop
    Bebop [OP] Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Why not just wire up a window unit to run through the beer window?
  2. Jun 29, 2018 at 8:32 PM
    Bebop
    Nick
    Part number 2 is the thermosistor. Less than 10 bucks. May order one for a prototype and see what I can do.
    12TRDTacoma likes this.
  3. Jun 29, 2018 at 8:32 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
  4. Jun 30, 2018 at 1:37 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    This would do it. Problem solved.
  5. Jun 30, 2018 at 5:52 AM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Even better
  6. Jun 30, 2018 at 5:53 AM
    jross20
    Georgia
    On a more serious note though, has anyone ever thought about dumping the Tundra's system in? If possible, I presume it's made for a larger cab and as such would easily cool the taco
    12TRDTacoma and PzTank like this.
  7. Jun 30, 2018 at 7:05 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    I get 44-45 at the vent, driving or at idle all day long....BUT I'm in N. Cali, with almost ZERO Humidity and only about 6-8 weeks of HOT weather, upper 90's to the 105 range.
    Bebop[QUOTED][OP] likes this.
  8. Jun 30, 2018 at 7:30 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Subd for “ @Bebop ‘s Big Arctic Chill Upgrade Kit”! Aka Bebop’s BACUK :thumbsup:
    It’ll be interesting to see if there’s off the shelf super sized components that’ll bolt right up...
    hoverlover, 12TRDTacoma and Bebop[OP] like this.
  9. Jun 30, 2018 at 10:24 AM
    CMD-KY
    CMD-KY Well-Known Member
    South Central Kentucky
    2104 Tacoma AC SR5 4wd
    I am enjoying the heck out of this thread. I know nothing about AC but reading this is learning.
    EatSleepTacos likes this.
  10. Jun 30, 2018 at 10:33 AM
    TexasWhiteIce
    Texas
    Problem is, it’s california....
    cosmicfires likes this.
  11. Jun 30, 2018 at 11:07 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Also this info may be helpful to the cause.
    Notice how when your motor is warmed up, with the temp selector on the coldest setting with out the AC, notice the air is much warmer than the outside air? I believe this is because of the heat from the motor is making its way to the fresh air intakr under the cowling. I wonder if more sealing/weather stripping could help with this. My 2005 tundra with the same motor as the taco does not suffer from this.
  12. Jun 30, 2018 at 11:11 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    One thing that may help OPs overall comfort in the truck (slightly) is insulating. Full insulation means doors and roof possibly floor as well. Much like insulating a house, if you make the cab more efficient at maintaining temp, your AC doesn’t have to work as hard to cool the cab. The biggest flaw I’ve seen at pursuing full insulation has always been the glass. There’s no way that I’ve found to insulate glass effectively enough to make a “holy cow” difference without completely covering it with insulation. You’ll still have heat penetration even with ceramic tint. Although from my experience, insulation will make a noticeable difference, however slight. I know this isn’t what OP is after but it may help reach his goal.
    Good luck with your original project, OP.
  13. Jun 30, 2018 at 2:14 PM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    What about mounting a larger/thicker condenser with more surface area over the fins and tubes? Might have more efficient cooling especially with a pusher fan?
  14. Jun 30, 2018 at 2:21 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I always did feel like our system took a bitch amount of refrigerant and always had my suspicions of the condenser unit being whimpy due to how thin it is.
    If we could find a larger condenser, not only would we be able to utilize more refrigerant space, but we would be able to have better cooling power.
    Btw, I write this as I am sweating my balls off in the cab of my truck, WITH the AC on. I'm super pissed off about how trash this system performs at idle.
  15. Jun 30, 2018 at 2:26 PM
    #35
    Beretta4x4
    Josh
    Temple, TX
    I didn't think about the increased internal volume of the system, that would also provide additional cooling just using more refrigerant to carry the heat off...
  16. Jun 30, 2018 at 2:59 PM
    #36
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    I was thinking along the lines of installing a small water reservoir and windshield washer pump and spraying a mist on the condenser when needed.
  17. Jun 30, 2018 at 3:04 PM
    #37
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes but that would only help for so long and would require frequent maintenance as well as consistent button pressing to mist it. Lol.
  18. Jun 30, 2018 at 3:13 PM
    #38
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    TRDSport10 likes this.
  19. Jun 30, 2018 at 3:31 PM
    #39
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    For information, most ac systems are designed for the 42~45° range. Any colder and the evaporator will freeze. Reason is that the coil is 10~20° colder than the air temp.
    To get 33~35° air you need a low temp system and the A/C's in our Tacos are high temp systems.
    Also since the auto industry went with R134a refrigerant the performance went down. R12 systems were better handling humidity.
  20. Jun 30, 2018 at 3:48 PM
    #40
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Actually, this would help. You'd be limited by how much water you can carry but it would help.
