Bed AC Outlet Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pster, Sep 15, 2011.
  1. Sep 15, 2011 at 6:47 AM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Does anyone know if my 2006 Double Cab SR5 4x4 has wiring in place behind the bed box on the passenger side to accept an AC outlet? The AC outlet was not available on my truck when I bought it but I was wondering if I bought the box with the AC outlet from a salvage yard, could I just "plug it in" on my truck?
  2. Sep 15, 2011 at 7:00 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I think you need the inverter too which is located under the center console. When I removed the console in my '07 SR5 to install my CB, I didn't see any sort of existing harness there.
  3. Oct 11, 2011 at 1:05 PM
    CalgaryRider
    CalgaryRider Well-Known Member
    Shayne
    Cranbrook, BC
    09 Access Cab SR5
    2009 Tacoma SR5 Too many to list, but its a SR5 with a TRD Sport Heart
    You will need the inverter which goes between the seats on an Access cab, the wiring front the inverter to the rear plug.
    If memory serves me correctly there is already the wiring under the center console to power the inverter. Alteast it was on my 09.
    I am in the process of doing this mod too!
  4. Oct 11, 2011 at 1:28 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Its more than the inverter, harness and plug. You also need the button, harness from inverter to fuse box, harness from inverter to button, relay, etc.. Its much easier to wire in aftermarket inverter.
  5. Oct 11, 2011 at 1:35 PM
    CalgaryRider
    Shayne
    Cranbrook, BC
    09 Access Cab SR5
    Sorry forgot to add the button, but it is pre-wired in my 09, I just pulled the cap for where the switch was and its all pre-wired.
    I can always compare the harness out of the 2006 TRD Sport with my SR5 harness in the truck.
    Honestly from what I have found Toyota uses the same harnesses and just doesn't include the accessories or fuses to make them work. Ever put factory fog lights onto an SR5, it takes about 5 minutes to add the fuse/relay, pop out the light covers, plug in the lights (That are PRE-wired), pop the cap off and plug in the switch.
    The only change that I have found is on the rear harness (the inverter is no way connected to this harness) for the towing package vs. the SR5 package.
