Bed Ammo Can Mount Write-Up
Discussion in 'Garage / Workshop' started by CanisLupus, May 27, 2012.
  1. May 27, 2012 at 3:54 PM
    CanisLupus
    CanisLupus [OP] Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Hi all, I decided to do a write up of my ammo can mount. Credit for the idea goes to member "GTABurnout," who I first saw the mount from. I believe he has a small write up in his build but I figured I might do a specific thread about it with my experience on the project. I used my father's old 7.62mm army ammunition can and bedlined it using Rustoleum Truck Bed Liner Paint. I also stole GTABurnout's idea and put an 1/4'' eye bolt through the handle and put a padlock on it to keep my belongings secure. I decided to not drill through the center of the handle since that was where the can was held together from and I didn't want to compromise the strength of the can, so I drilled off-center and used a second washer for the eye bolt on the outside to space the eye bolt out from the handle so I could put the padlock through. You guys can experiment with different size hardware and such but I will posting my specifications from what I used.
    Tools Needed/Preferred:
    (1) Ammo Can
    (3) 1/2'' Hex Bolts
    (3) 1/2'' Hex Nuts
    (3) 1/2'' Neoprene Washers
    (1) 1/4'' Eye Bolt
    (2) 1/4'' Nuts
    (1) 1/4'' Neoprene Washer
    (1) Rustoleum Truck Bed Liner Paint Can
    (1) Cordless Drill
    (1) 1/2'' Drill Bit (capable of drilling light-grade metal)
    (1) 1/4'' Drill Bit (capable of drilling light-grade metal)
    (1) Padlock
    Write Up
    • Paint (can be done after drilling if preferred)
    • Measure holes to fit rail system and drill
    • Slide bolts through rail system
    • Attach bolts through can holes
    • Attach hardware
    • Enjoy!
    Finished Project Driver's Side:
    Recovery Strap and Inside View (can also see the D-Rings I mounted in the front of the bed recently):
    Inside View w/ no Recovery Strap:
    The door will not hit rear glass or paint (rest on rubber seal)
    *EDIT* (Added twin ammo can on passenger side)
    Finished Project Passenger Side:
    Inside View with no ratchet straps/rope:
    Inside view w/ ratchet straps/rope:
    Top hits rubber seal on passenger side as well:
    Final Finished Project:
    Hope it was a good read, and good luck!
    02Duck likes this.
  2. Jun 4, 2012 at 8:56 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    How long are the 1/2" bolts you used? And they are the hex heads? I was going to use rounded head carriage bolts, because I figured its the only thing that would fit into the rails.
  3. Jun 4, 2012 at 9:09 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Looks good. You could also get some t-slot nuts that fit in the rails and run the bolt into them. I'll get the mcmaster carr part number that I got that fit in the rails tomorrow.
    :thumbsup:
  4. Jun 4, 2012 at 9:41 PM
    Rhino
    Rhino Well-Known Member
    Laurel, Mississippi
    03 TRD SR5 4x4
    gray wire mod, blacked out, debadged, toolbox foglights, cb in dash, system, bilstein 5100's in front wrapped in eibach coils, 5125's in the rear with 2 inch aal and 1 inch shackle, diff drop kit, extended rear brake line, 8000 lb smittybuilt winch on a custom winch bumper, 2 4 inch 100 watt kc's and 2 6 inch 100 watt kc's on the bumper, sometimes a ladder rack,much more to come
    great idea gonna do somethin similar to my first gen now
  5. Jun 4, 2012 at 9:42 PM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Stickers. Lots of stickers.
    Subbed for later. Got the ammo cans, just need time to put it all together.
  6. Jun 4, 2012 at 10:01 PM
    Nick701
    Nick701 Well-Known Member
    17 TRD OR DC 4X4
  7. Jun 4, 2012 at 10:24 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    looks good! i like the black rugged finish, matches bed ;)
  8. Jun 5, 2012 at 7:52 AM
    CanisLupus
    Stokesdale | NC
    I believe the bolts I used were 1/2'' by 1.5''. I looked for shorter bolts so they wouldn't stick out so much but unfortunately those were the shortest Home Depot carried. And yes they are hex bolts but some of the other people on TW that have done this mod have used rounded head bolts. (Hex bolts obviously fit but it's whatever you want to do.)
  9. Jun 5, 2012 at 10:12 AM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    The Mcmaster Carr part number for the t slot nuts I bought is 90526A592.
  10. Jun 5, 2012 at 10:58 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    Will these lock into the notches in the bed rails?
  11. Jun 5, 2012 at 11:10 AM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    Sure will! :thumbsup:
  12. Jun 5, 2012 at 11:20 AM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    Another question for the OP. Does the can sit on the fender? Or is it suspended? I think from the pics it looks suspended.
  13. Jun 5, 2012 at 11:27 AM
    CanisLupus
    Stokesdale | NC
    Are you talking about the top of the can touching the rubber seal on the rear window? If you are, then yes, it touches the rubber seal, which is the best part because you don't have to worry about it hitting your rear window or cab paint.
  14. Jun 5, 2012 at 11:29 AM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    I am actually talking about the bottom of the can. Does the bottom of the can rest in the bed?
  15. Jun 5, 2012 at 11:31 AM
    TacoDaTugBoat
    Goshen, Ct
    13 DCLB TRD Sport
    I recently had my cap broken into and all my tools stolen from inside my cap. I am thinking of putting in maybe 4 of these with cam locks installed on the tops to store straps and stuff in. Am adding a tailgate lock this afternoon, so that and some locking boxes will provide multiple layers of deterrent.
  16. Jun 5, 2012 at 11:32 AM
    CanisLupus
    Stokesdale | NC
    No, it is suspended a couple of inches above the wheel well. There are different sizes of ammo cans, so you may be able to get a .50 Caliber can or other that could rest on the wheel well if you looked around enough.
    Also, where did you get these and what size are they? I'm putting in another ammo can on my passenger side bed and may even think about re-mounting my driver's side can with these if they secure better.
  17. Jun 5, 2012 at 11:35 AM
    TacoDaTugBoat
    Goshen, Ct
    13 DCLB TRD Sport
  18. Jun 5, 2012 at 11:37 AM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    I got these from McMaster Carr. There are other places to get them, I cant remember where I first saw them...
  19. Jun 5, 2012 at 11:41 AM
    TacoDaTugBoat
    Goshen, Ct
    13 DCLB TRD Sport
  20. Jun 5, 2012 at 11:42 AM
    TacoDaTugBoat
    Goshen, Ct
    13 DCLB TRD Sport
    I think you can get something similar from Uni-Strut
