bed electrical outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Va Bowhunter, Feb 7, 2015.
  1. Feb 7, 2015 at 8:54 AM
    Va Bowhunter
    Va Bowhunter [OP] Well-Known Member
    Shawn
    VA
    05 Tacoma TRD
    ABS winch bumper, 8,500 smitty built winch
    the button on the dash lights up but there is no power at the outlet.
    any idea's
  2. Feb 7, 2015 at 9:00 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  3. Feb 7, 2015 at 9:04 AM
    Va Bowhunter
    Shawn
    VA
    05 Tacoma TRD
    yes. i started the truck.
    i wanted to use the wifes hair dryer to remove the dealers sticker.
    but no luck.
    i guess i will try to find and trace the wirering
  4. Feb 7, 2015 at 9:12 AM
    Janster
    Jandy
    Lancaster, PA
    Read thru the link I gave you above.....
  5. Feb 7, 2015 at 9:14 AM
    maju
    maju Well-Known Member
    Davenport Fl
    2010 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
    A hairdryer might be to much of a current draw.
    Check the UL sticker listing the voltage & amperage required for what you are using.
    Voltage X Amperage = Wattage required.
  6. Feb 7, 2015 at 9:23 AM
    Va Bowhunter
    Shawn
    VA
    05 Tacoma TRD
    i will try it again with something that draws less amps.
  7. Feb 7, 2015 at 9:29 AM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    I can confirm that a hairdryer won't work. In my case it powered on for about 3 secs and then shut off. I tried the same thing when removing the badges on my tailgate.
  8. Feb 7, 2015 at 9:41 AM
    Janster
    Jandy
    Lancaster, PA
    Hairdryer would work if its blowing cold air.......(no heat)
    But that certainly won't help you remove stickers. :p
  9. Feb 7, 2015 at 10:08 AM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Yeah that bed plug is almost useless.
  10. Feb 7, 2015 at 10:17 AM
    Va Bowhunter
    Shawn
    VA
    05 Tacoma TRD
    found the problem.
    removed the four bolts and removed the outlet.
    found that the wire had came unplugged and was laying in the
    inner fender. plugged it back in and added a zip tie so it will
    not happen again.
    plugged in a drill and it worked great!! wish every fix was this simple.
  11. Feb 7, 2015 at 11:06 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I totally used my bed outlet to run a hair dryer when I took of my bedside stickers
  12. Feb 7, 2015 at 11:19 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    The bed outlet is 400watts max. You can plug stuff in over and it may work. Not to full capacity, but it will work. Do not use it for long over the max or it will burn out the inverter. Then it truly will be useless. I use if to charge my cordless drill batteries from job to job.
