bed extender help!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dpascual1986, Mar 30, 2011.
  1. Mar 30, 2011 at 9:43 AM
    dpascual1986
    dpascual1986 [OP] Well-Known Member
    i have an 06 double cab short bed, i found a dude selling his bed extender for 130 and I want to get it. however i have a pace edwards rolling tonneau cover and the rails extend inward a little bit and I am concerned about fitment.
    will someone please help me out and post pics of the way the extender is mounted and a picture of the extender swiveled in the UP position. Thanks in advance.
  2. Mar 30, 2011 at 9:46 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    there are a lot of bed extender threads out. do a search for some images. as for the extender being 'up' I'm not sure what you mean. It shouldn't ever be 'up'. Either foward making a box with the tailagate up like this:
    C=extender and I = gate-----CI
    that is the extender in the 'stored' position which works great for keeping groceries or a gas can from sliding around the bed.
  3. Mar 30, 2011 at 9:49 AM
    gooch14
    Kyle
    Michigan
    Out
    In
  4. Mar 30, 2011 at 9:54 AM
    dpascual1986
    @ gooch14 -thanks for the amazingly quick reply, i wanted a pic of it in the up position to see if it will clear the sides of the bed with my tonneau cover's rails in place. I know it shouldn't be up, just wanted to see it.
    your pic is not a tacoma though, looks like a tundra. I have done multiple searches, none of them has the angle i need. the angle in your picture is great and would be beneficial if it were closer so i can estimate measurements and if it was a tacoma.
  5. Mar 30, 2011 at 9:58 AM
    BryWi
    BryWi Psalm 109:8
    Earth
    2011 TRD off-road DC SB w/JBL
    5100s, black valance
    Will this help?
    2011 SB
    The gap between is 2.5"
  6. Mar 30, 2011 at 10:02 AM
    gooch14
    Kyle
    Michigan
    I have a besttop on my truck, which uses the normal Truck Cap Style clamps intergrated into the rail system in my '11. I can flip my extender forward and they don't hit. If my phone wasn't so damn slow for internet i'd snap a pic and post it on TW live but you'll probably be buying a new truck by the time it uploads.
    huge picture so here is just the link:
    http://image.automotive.com/f/tech/..._cover_testfit_2006_dodge_ram_2500+clamps.jpg
    the clamps for the bestop set out a good ways and I clear. Good Luck
  7. Mar 30, 2011 at 10:05 AM
    dpascual1986
    that is the shot im looking for!! you and this forum are awesome. is that scratched out line the gap youre talking about? perfect, im going to buy it. BTW, is that the OEM extender?
  8. Mar 30, 2011 at 10:07 AM
    BryWi
    BryWi Psalm 109:8
    Earth
    Cool. Yeah, the half-ass line is the gap. :D
    Yes, mine is an OEM extender...
  9. Mar 30, 2011 at 10:07 AM
    justin144
    justin144 Well-Known Member
    justin
    Las Cruces, New Mexico
    2011 Taco 4X4 Dbl cab Long Bed
    I'll post pics of mine in a little bit.
  10. Mar 30, 2011 at 10:15 AM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    If you can wait till after 4 o'clock, (iowa time)I will post pics for ya. Its pretty easy.
  11. Mar 30, 2011 at 10:26 AM
    dpascual1986
    yeah ill wait, please take some of different angles and pls have some reference so i can measure. thanks a million.
    a pic of the mounting bracket would also be great.
  12. Mar 30, 2011 at 2:44 PM
    Superx2
    Joey
    Iowa
  13. Mar 30, 2011 at 2:45 PM
    Superx2
    Joey
    Iowa
    have more coming
  14. Mar 30, 2011 at 2:46 PM
    Superx2
    Joey
    Iowa
  15. Mar 30, 2011 at 2:52 PM
    Superx2
    Joey
    Iowa
    make sure you can shut your tailgate before you drill your holes. another thing you need to keep in mind is you want it level. you should be fine if you put your hindges in the exact same spot on the oppisite sides. make sense? i put mine together, got it level, and double checked before i drilled holes. good luck dude hope this helps and if you need any more pics, let me know.
  16. Mar 30, 2011 at 3:01 PM
    dpascual1986
    so they must be drilled on and do not have factory holes i can just screw on? ok, i can live with that, thanks for the pictures, it looks like it will fit my tonneau cover.
  17. Mar 30, 2011 at 3:18 PM
    Superx2
    Joey
    Iowa
    Just remember to make sure they are mirror image. Ya you will need to pre drill holes. 15/16 bit. Wondering if you got all the hardware. You should have bolts and nuts rite? You could probably use self tappers also.
