Bed is loose.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Noswar5, Feb 23, 2021.
  1. Feb 23, 2021 at 4:59 PM
    Noswar5
    Noswar5 [OP] Member
    Macedonia Ohio
    2017 inferno Tacoma TRD
    My 2017 trd bed is loose on the passenger side. Thought at 1st it was the Tonneau cover but after further investigation I noticed the bed moves off the frame a little just on the passenger side. Any ideas for a good quick fix and how?
    Mattynokes likes this.
  2. Feb 23, 2021 at 5:07 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Tighten the bolts. Did you recently have the fuel pump recall done?
  3. Feb 23, 2021 at 5:43 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Tighten the bolts.
  4. Feb 23, 2021 at 5:54 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    T55 torx bit and a breaker bar!
  5. Feb 23, 2021 at 5:59 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Problem: Bolt is loose.
    Solution: Tighten bolt.
    pt314159, Losi-5iveT, MadKatt and 7 others like this.
  6. Feb 23, 2021 at 6:02 PM
    Marley&Me
    Marley&Me Well-Known Member
    2021 Voodoo Blue Tacoma AC MT
    Interesting solution ^^^^^ I like this!
    CaptainBart45, Skydvrr, hiPSI and 2 others like this.
  7. Feb 23, 2021 at 6:04 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Jeeze u guys could be nicer
  8. Feb 23, 2021 at 6:08 PM
    Marley&Me
    You're right. I suppose a little more information would help. Are the bolts loose? Like what was asked earlier, was any work done recently that the bed was removed for?
  9. Feb 23, 2021 at 6:11 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Which way is tight?!
  10. Feb 23, 2021 at 6:13 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Use the power of elimination. Turn one way. Check bed movement. Improved? Yes, good job you turned the right way. No? Reverse direction.
    I like this thread. :D
  11. Feb 23, 2021 at 6:17 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Please tighten the bolts . Thank you .
    HP11, The hammer, Skydvrr and 5 others like this.
  12. Feb 23, 2021 at 6:20 PM
    Mattynokes
    Mattynokes Well-Known Member
    Madison, WI
    18' BLACK Off Road DCSB
    Prinsu Toprac TRD Beadlocks Century Shell
    Let me guess, passenger side/ front of bed?
    Noswar5[QUOTED][OP] and jcmotr like this.
  13. Feb 23, 2021 at 6:24 PM
    Mattynokes
    Madison, WI
    If in fact the bolt is tight but it rattles anyway, this is a known issue. More predominant with 2nd Gens.
    https://www.tacomaworld.com/threads/tacoma-loose-bed-design-flaw-explanation.388873/
  14. Feb 23, 2021 at 7:10 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Righty! I'm a lefty so I made sure to marry a righty because... righty is tighty! Yea!
    Unless...(dark clouds and general gloom) it is a spinner. Sometimes things that spin get the lefty tight treatment. A circular saw blade bolt for example.
    tcjacado likes this.
  15. Feb 23, 2021 at 7:12 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Get a humor bone man! The OP got it you can too...
  16. Feb 23, 2021 at 7:34 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    hiPSI likes this.
  17. Feb 23, 2021 at 7:35 PM
    Mattynokes
    Madison, WI
    :amen:
  18. Feb 23, 2021 at 7:52 PM
    Noswar5
    Noswar5 [OP] Member
    Macedonia Ohio
    Yes it is passenger front side.no work was done. It is 3rd Gen as you know. I will look at the like you sent.
    Mattynokes and hiPSI like this.
  19. Feb 23, 2021 at 8:00 PM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    Bolt is likely tight. There’s a sleeve in there so tightening it doesn’t do anything, assuming they are the same as 2nd gen beds. Check out the link posted above, I had the same issue with my 2015, jammed a piece or rubber between the bed support and frame and it didn’t make another sound for a couple years.
    Noswar5[OP] likes this.
  20. Feb 23, 2021 at 8:00 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    My 2017's bed was mounted crooked when I got it. I loosened those 6 torx bolts on the bottom inside of the bed, holding it to the frame, aligned the bed and retightened the bolts. It's amazing how easy the bed moves with the bolts loose.
    Noswar5[OP] and Koolbreeze7 like this.
