Bed lighting question
Discussion in 'Lighting' started by tacomathunder, Feb 17, 2012.
  1. Mar 6, 2012 at 8:32 PM
    #61
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    This does what exactly? The same thing just the power for the indicator lamp comes from the second set of switched terminals? Looking at it closely it seems that this would light the bottom light in the switch regardless of position...
  2. Mar 6, 2012 at 8:59 PM
    #62
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    Right, but since its a on/ on rocker if the switch is up closing the contacts between 1&2 then 4&5 will be closed as well, making the lower lamp on. If it was down then contacts 2&3 and 5&6 would be closed so the light would still be on. Right?
  3. Mar 6, 2012 at 9:12 PM
    #63
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    Oh OK that makes sense. Didn't know it said on/off/on. I'll have to fix that.
    Edit: if you were talking about the SPDT switch pdf it shows three positions in the drawing but lists position 2 as none in the side bar. With positions 1 and 3 as on. Couldn't find anything in the DPDT pdf that talked about what kind of switch it was. Did I miss something?
  4. Mar 7, 2012 at 11:53 AM
    #64
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    OK thanks for the heads up. The DPDT switch I'm ordering is listed as on/on so hopefully it is just a two position switch.
  5. Mar 7, 2012 at 12:14 PM
    #65
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    x2 although maybe the OP has gotten info for his lighting project he wouldn't have gotten otherwise. :notsure:
  6. Mar 8, 2012 at 6:02 AM
    #66
    tacomathunder
    tacomathunder [OP] Well-Known Member
    Florida
    07 4 cyl reg cab
    pop-a-lock on tailgate, tailgate damper by ez down, extang platinum snap tonneau cover, rampage LED light bar, etrailer wiring harness, black led tail lights, tsi clutter catcher center console, griffin itrip ipod player,BHLM,35W DDM Tuning hid's 5000K, Day Time Running Light Mod, New Sony Stereo
    yeah its completely fine, got a lot of different info i otherwise wouldn't have got if you guys didn't discuss it in detail, so Thanks! :D
  7. Mar 15, 2012 at 9:46 AM
    #67
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
  8. Mar 29, 2012 at 5:53 PM
    #68
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    I don't know what stage of this you are at, nor did I read all of the posts, but personally, I don't feel you should run power through switches, only signals. Here's an image I sketched up for someone else doing the same thing, only using relays to flip the lights on and off...
  9. Mar 29, 2012 at 9:14 PM
    #69
    joes06tacoma
    Joe
    Central Coast, CA
    Yeah, that's the way to go if you are running large lights. A couple of led strips isn't going to be a problem with just switches. The main reason this thread got long is someone other than the OP jumped in and wanted to wire his truck to have two switches like a three way light switch setup in a house. Walk in the front door, turn on the lights, walk across the living room, turn the same lights off with a second switch. It got complicated quick. Read it if you get bored sometime.
  10. Aug 7, 2014 at 7:56 PM
    #70
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    So I know this thread is over 2 years old and inactive but through all my searching it seems to be the best source for the type of wiring set-up I would like accomplish. I can follow pretty much everything that has been posted but I am left with two questions. The first is which switches were used, what was the source of the switches and which two were used? And two, did it all work as expected? Was the final wiring set-up correct and the bed lights were able to be turned on and off from the cab and/or bed with the cab switch lighted when the running lights were turned on and an indicator light comes on the dash switch when the bed lights are on?
