Bed lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wv mountaineer, Dec 23, 2020.
  1. Dec 23, 2020 at 3:59 PM
    Wv mountaineer
    Wv mountaineer [OP] New Member
    Michael
    2017 Toyota Tacoma
    Does anyone know if there is a constant 12 volt wire in the rear of a 2017 Tacoma? I want to install bed light and not have to run to battery. I like to just install switch in bed. I purchased small leds from Harbor Freight.
    Thank you
  2. Dec 23, 2020 at 4:21 PM
    Mastertoytec
    Mastertoytec Member
    02 taco
    Not that I can think of. I know the toyota factory accessory bed lights wire up to the drivers side kick pannel inside the cab. Sending a + wire from the battery sounds like the easiest route
    Wv mountaineer[OP] likes this.
  3. Dec 23, 2020 at 4:33 PM
    Wv mountaineer
    Michael
    2017 Toyota Tacoma
    Okay thank you. I just hate to have to route a wire to the front. Do you know anything about bed, are they easy to drill. I was thinking about mounting them at back right behind brake lights.
  4. Dec 23, 2020 at 4:35 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Toyota has some OEM bed lights you can get that mount where ypu are thinking.
    Also I had to route 12v back and ran the line down the frame to the main harness. The biggest challenge is the gas tank but otherwise wasn’t terrible.
  5. Dec 23, 2020 at 4:35 PM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
  6. Dec 23, 2020 at 4:51 PM
    Mastertoytec
    Mastertoytec Member
    02 taco
    I would put them here (where the paper is in the picture) so they are protected from you loading stuff in the bed. Very easy to drill its just thick plastic
  7. Dec 23, 2020 at 4:55 PM
    caribe makaira
    Caribbean, Puerto Rico
    If OP doesn't tow using the 7 pin, he could jumper the towing brake connector in the cab, then he'd have an always hot fused wire to tap.
    Mating connector to T7
    upload_2020-12-23_21-4-6.jpg090/2.3 II terminals. 12AWG terminals needed.
  8. Dec 23, 2020 at 4:59 PM
    su.b.rat
    su.b.rat broken truck
    GST bedlight install pdf if that's helpful..
  9. Dec 23, 2020 at 5:06 PM
    Wv mountaineer
    Michael
    2017 Toyota Tacoma
    Thank you all for your input!! I’ll post pictures when I complete project.
  10. Dec 23, 2020 at 5:07 PM
    minium
    minium Well-Known Member
    2017 Inferno Tacoma TRD Off Road
  11. Dec 23, 2020 at 5:09 PM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    I ran some wires to the bed when I added my aux fuse panel and accessories. I wired up rear facing LEDs on my bedrack and ran an extra for bed lights for later. Running the wire really isn't too bad, just get enough wire and some wire loom/wrap.
    I brought mine up to the bed in the little corner by the bed/tail light/tailgate. There was enough gap to accomadate my ground, and the other three 12 or 10 gauge wires. (I also brought power over from the brake light for a third brake light)
    Edited for spelling, sorry beer
  12. Dec 23, 2020 at 5:14 PM
    caribe makaira
  13. Dec 23, 2020 at 5:43 PM
    Wv mountaineer
    Michael
    2017 Toyota Tacoma
    Would you guys use 10 or 12 gauge and would you install fuse.
  14. Dec 23, 2020 at 5:47 PM
    caribe makaira
    For LED? 16awg, and fuse, yes.
  15. Dec 23, 2020 at 6:32 PM
    VirusCage
    Bruce
    Allison Park, PA
    I always go over kill on wiring and fuses, but for leds 16 ga should be just fine
  16. Dec 23, 2020 at 7:33 PM
    JoeCOVA
    Joe
    Colorado Springs
    For just LEDs? something smaller, not a lot of amps.
    I ran 10guage but thats because I hooked it up to a 4 switch breaker for LED lights and a fridge.
