Bed mount for tools (axe, shovel, etc) (PDF files)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sparky2, Jan 30, 2017.
  1. Jan 30, 2017 at 8:40 AM
    Sparky2
    Sparky2 [OP] Well-Known Member
    Keith
    2016 Tacoma TRD
    Had someone ask for this stuff, so I thought I'd dump it here. It isn't exactly a tutorial, but you never know, someone may want it. Don't expect anything too professional on the drawings though. I just slapped it together right quick for use in the shop.
    The result
    They are spaced out for the shovel head, otherwise, I'd have made them closer to the bed side.
    PDF's are attached. They are cut from a sheet of 10 ga steel, but for some of you that have a welder, but no plasma... just buy some 1" and 1.75" bar stock (or strap as some call it) (fairly thin stuff, 1/8" or a little less is good) and have at it. The template still works there also. The indentations in the sides are to show where to bend and aren't really needed. Just makes locating the bends easier.
    In hindsight, I think the 90 degree bend on the top flange is a bit much. Stop this bend early and test fit.
    Some stuff you'll need:
    https://www.amazon.com/Quick-Fist-P..._QL65&qid=1485753655&ref_=mp_s_a_1_12&sr=8-12
    Cheapo unistrut nuts work fine here, or get this:
    https://www.amazon.com/T-Slot-Finis...=1485753944&ref=plSrch&ref_=mp_s_a_1_5&sr=8-5
    Pirhett, Max74, jmauvais and 3 others like this.
  2. Jan 30, 2017 at 9:29 AM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    brilliant! thank you.
    what bolts match with the t-slots you linked in Amazon?
  3. Jan 30, 2017 at 9:32 AM
    vuTron
    SF Bay Area
    nevermind, I think I found it... "3/8"-16 Threads"
  4. Jan 30, 2017 at 8:48 PM
    WhiteDogTRD
    WhiteDogTRD Well-Known Member
    A-aron
    Speedwell, TN
    2016 TRD Off-Road
    CaliRaised 31.5 LED grill mount Sasquatch light, Coverking ballistic nylon seat covers, BakFlip F1 bed cover, bed/cargo LED strip lights, dog platform, Pro grill, RCI Sliders, Mobtown Skid, Total Chaos Bed stiffeners, Bronze 16x8 Ray10's, KO2's, OVTune
    Thanks for the share. Looks great. I was wanting to do this. Now I don't have an excuse.
  5. Feb 6, 2017 at 9:33 AM
    jake slatnick
    jake slatnick Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    Can you share the link?
  6. Feb 6, 2017 at 9:35 AM
    vuTron
    SF Bay Area
    @jake slatnick
    If you click on the Amazon link for the unistrut nut, just read the description... that's where I got it.
  7. Feb 6, 2017 at 9:43 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Cool thanks, let me know how this set up goes for you!
  8. Feb 6, 2017 at 11:30 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
  9. Feb 6, 2017 at 12:17 PM
    Sparky2
    Keith
    2016 Tacoma TRD
    Allpro, relentless, 4xinnovations... There are many. I just like to build stuff.
    tarandus likes this.
  10. Mar 11, 2020 at 1:22 PM
    Ekuhl
    Ekuhl Well-Known Member
    Eric
    Southern Illinois
    2017 Quicksand TRD OR
    Sorry to revive an old thread. But I'm considering building similar. Have you had any issues with the bottom mounts rubbing thru the bed side. Seems like those might move around a bit
