bed outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by marathon, Jan 5, 2007.
  1. Jan 5, 2007 at 2:41 PM
    marathon
    marathon [OP] Member
    So i just drove my 07 tacoma trd sport access cab v6 prerunner home form the dealership. I have a question regarding the outlet found in the bed. I thought it was a really cool idea but after reading a bit you can only use 400 watt max (only 100 watt when driving). I think it's still a 120v but the low power really restricts what you can and can't use with it. Most power tools won't work, or will they? I'm a bit scared to just plug up a drill with the possibility to burn the motor out in it.
    Anyone have any experience with thiers?
    Bad stories good stories?
    What do you use most with it?
    Also any other restrictions I'm not mentioning like resistance?
  2. Jan 5, 2007 at 2:58 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Remember a little formula
    PIE. Power=Current(I) x Voltage(E) The outlet provides 120V at a max 400W so 120volts/400watts=3.3amps and 120volts/100watts=.83amps
    Example. Dewalt drill has a current draw of 5amps. 5amps x 120volts = 600watts. To much for the inverter/deck outlet
    So look at your tool's/equipment you want to run and see what the current draw is and if it exceeds the 3.3amps it won't work or if it does it won't work that well.
    Hope this helps
  3. Jan 5, 2007 at 3:49 PM
    natrlyst
    natrlyst Well-Known Member
    Nice response, could not have answered it better myself, can't get anymore clear than that. If, marathon, you have any questions about the stuff you can power, send me a pm and I will figure it out for you. You will find that it isn't useless as most "plug-iners" will be fine as long as it isn't power tools lol
  4. Jan 5, 2007 at 3:55 PM
    ImInLoveWithMyTruck
    ImInLoveWithMyTruck Well-Known Member
    Great question and great answer!
  5. Jan 5, 2007 at 8:33 PM
    tcboss
    tcboss Well-Known Member
    Wilmington, NC
    Black Mamba
    3 in. Revtek Lift, 33 in. M/T Open Country's,
    where is the bed outlet exactly?
  6. Jan 5, 2007 at 8:49 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    The outlet only comes on the 2005 and up TRD Offroad or TRD Sport packages option code's OC and PY (according to Toyota)
    If you wanted an inverter you could probably find one and install it fairly easily, might want to upgrade the alternator also.
    I found these
  7. Jan 5, 2007 at 8:52 PM
    kwe1560
    kwe1560 Active Member
    Yes the power seems low, but I have used a weed-eater with a power cord and it worked fine. However, the leaf blower worked but did not run at normal speed, While camping I did use a coffee purculator(whats That), and it worked fine, I have charged a cell phone off of it, and was fine, also I had to use a small heater to keep warm, when the Colorado snow knocked out power and it did fine but wasn't much heat. I check the appliance label for the output rating . My only experience with improper voltage is the appliance will either not run correctly, or not at all. I was told that if the appliance wattage is incorrect. You might simply blow a fuse, However neither has happened yet.
  8. Jan 6, 2007 at 12:57 PM
    marathon
    Thanks for everyone's input. I now kinda remembered using that formula from high school physics. I'll keep a close eye on the tools I use. Again thanks.
  9. Jul 6, 2012 at 9:56 AM
    ohmyitstrucktime
    ohmyitstrucktime Active Member
    Calgary
    trd
    just to make sure you calculate properly its watts / voltage =amps not v/w=a
    (400watts/ 120v=3.33333)
  10. Jul 6, 2012 at 10:08 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    Holy thread revival ohmyitstrucktime
    Yeah V*A=Watts
    Divide the watts by either to get the other
  11. Jul 6, 2012 at 8:59 PM
    jprovence
    jprovence Well-Known Member
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    Cordless tools and let it charge batteries. Thats what I let it do when I'm driving somewhere. I charge camera batteries. Most chargers won't draw more then 3 amps or so. My brother has a small craftsman air compressor that will run on it. Nail gun size 3 gallon. Some shop lights will run on it. 250watts usually.
  12. Nov 30, 2015 at 5:27 PM
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    Only works while truck is running correct? Or also during aux mode.
    The dealer told me both when i bought it, i thought ok great for drive inn movies, i can bring a radio instead trying to listen through the small rear window.
    He was wrong :(
  13. Nov 30, 2015 at 7:05 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    400w anytime mod works great.
