Bed rail bar/light bar group buy.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by w8n4mud, Feb 21, 2010.
  1. Feb 21, 2010 at 8:36 PM
    w8n4mud
    w8n4mud [OP] I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    For sale: “Bed Rail Bars/Light Bars.”
    This bolt on application will fit any 2nd generation Tacoma with the standard track system each truck comes equipped with. This group buy will only be available for 30 days from the date posted or until entire stock has been depleted. Only a limited number of "Bed Rail Bars" are available.
    So why this design…
    I didn’t want to lose any bed space or use any cleats to attach a light bar. This design would allow you to slide your cargo against the back wall. The “L” brackets are high enough that you can still use your cleats under the bed rail bar OR you can turn the “L” brackets around and give yourself additional space should your off-road light(s) or bed light(s) be a little larger than normal.
    Advantage: You can attach a CB antenna and still have the wire from the stud run under the bar with no interference.
    Disadvantage: Your cargo may not be flush against the back wall.
    PRICE INFORMATION
    STYLE “36BLUE
    $55 – One (1) BLUE 36” steel bar, Two (2) “L” shaped BLUE brackets, six (6) bolts, six (6) nuts and six (6) washers.
    STYLE "36BLACK"
    $70* - One (1) BLACK 36" steel bar, Two (2) "L" shaped BLACK brackets, six (6) bolts, six (6) nuts and six (6) washers.
    *Please note that the bars and "L" brackets have a finished blue powder coat on them. If you want them in black, I will need to sand down, spray paint in black and then finish it off with a rubberized spray.
    STYLE “54BLUE
    *$80 – Two (2) BLUE 27” steel bars, Three (3) “L” shaped BLUE brackets, ten (10) bolts, ten (10) nuts and ten (10) washers.
    *This particular item is VERY limited in quantities and will be offered to those who have paid first in order of appearance on this thread. I don’t expect to have any left after the group buy is over. On another note, I have pictured BLACK "L" brackets on this photo, but you will be receiving BLUE brackets instead. Thank you.
    STYLE “54BLACK”
    *$95 – Two (2) BLUE 27” steel bars, Three (3) “L” shaped BLUE brackets, ten (10) bolts, ten (10) nuts and ten (10) washers.
    Additional "L" Brackets
    For whatever the use, you can purchase brackets for an additional $15 each (blue) shipped or $10 with your combined order. This will come with two (2) bolts, two (2) nuts and two (2) washers. Here is an example of such a use. Remember you can turn the "L" bracket around and use the other side. Customize it however you want. Make it unique. Make it your own.
    INSTRUCTIONS FOR ORDERING
    1) All you need to say is that you want to purchase one.
    I'll put your name on the purchase list which will be updated with information such as waiting for payment, paid or shipped.
    2) Please state which style you'd like.
    I'll PM you back with the information you'll need for payment.
    PAYMENT
    Payment will be through PayPal.
    Exception: Locals can pay by cash. Price will remain the same. Free install.
    SHIPPING
    It's included in the price.
    Expect the parts to arrive within 10 days after payment has been received. Shipping will be through FedEx.
    ABOUT THE PARTS
    “L” BRACKET
    Made with cut corners on the bottom side and a square top.
    BAR
    Be advised that each bar has five holes available on each end for mounting purposes. You can completely customize this bar by drilling additional holes in the middle and anywhere in between.
    PRODUCTS USED
    If you want them in black, I will need to sand down, spray paint in black and then finish it off with a rubberized spray. These will be the products I'm using in the event you need to touch up.
    My Two Cents...
    I personally would go with the blue and try to customize it to your color truck. For example, I would still paint the "L" brackets black and then color match the bar to the color of your truck as an added flare or personal touch. None of the lights pictured are included with the bed rail bar.
    I really hope to earn your business. I've tried to include all the information possible as I do NOT want to edit this post.
    Thank you!
  2. Feb 21, 2010 at 8:37 PM
    w8n4mud
    Albert
    Chula Vista, CA
    Corrections to the post above...
    1) SHIPPING: Only to the lower 48 States
    For Integrity purposes, Post #1 has not been modified. Any and all updates will be posted here.
    SALE​
    So after doing some additional research on these bars, I'm not going to pursue this avenue as a business opportunity. Frankly, it's too expensive for starting up and I don't anticipate selling enough to keep it afloat. I want to go through the stock I have on hand now. In order to do this, I need to have a "Sale." So here it is...
    BUY ONE FOR $50 - $5 OFF.
    Applies to the 36 Blue Bed Light Bar.
    I need to move what I've got TW. PM me and let me know that you want one. :D
    BUY 2, GET THE 3RD HALF OFF.
    Shipping of all 3 must be to one destination. This applies to the 36" Blue only
    Payment for three will be done in one transaction.
    Either convince 2 of your friends to get one at the price of $55 each and you only pay $27.50
    OR each of you pay $45.83/$45.83/$45.84 to equal $137.50 for all 3 instead of $165. That's a savings of $27.50. :D
    BUY 4 AND SAVE $15 ON EACH ONE
    Shipping of all 4 must be to one destination. This applies to the 36" Blue only
    This makes each light bar $40. Payment for all 4 must be in one transaction. This is a savings of $60 for 4.
    The "L" brackets are not on sale.
    I don't know what the demand will be with this sale. It will be on a first come, first serve basis. I still have 30 of the 36" Light bars left. If you are looking to get them in black, may I please offer the suggestion of sanding them down yourself and then either having them powder coated in black or having them Line-X'd/Rhino lined. I had this done on mine and the finish is much nicer. Easy to touch up as well. If you have any questions, please feel free to PM me. If you've been on the fence for a while about ordering, well now you have an incentive to get one along with someone else. Perhaps someone should start a new thread about buying some Light Bars based upon your living area or just say that you're interested so others can see.
    Purchase list...
    36BLUE
    1) 08ARMYTACO - Shipped
    2) ToucanV13: - Paid & Picked-Up
    3) Jon916996748 - Shipped
    4) GerhartCss - Shipped
    5) 0801 - Paid & Picked-up*
    6) Nolanspawn - Shipped
    7) Lilhank - Shipped
    8) James3492 - shipped
    9) Rydndurty - Shipped
    10) 06SoCalTaco + 2 Brackets - Shipped
    11) Grizzbear - Shipped
    12) yotanator - Shipped
    36BLACK
    1) ToughTaco - Shipped
    2) YOSHIHIROKUN - Shipped
    3) MDBigRed - Shipped
    4) DBoyTRD08 - Shipped
    5) 2ndtaco07 - Shipped
    6) GUNZ213 - Paid & Picked-up
    7) BRANDON - Paid & Picked up
    8) Jefferson - Local & Installed
    9) Clarkie152 - Shipped
    10) DblD - Shipped
    11) iForceTUNDRA - Shipped
    12) Jadams - Line-X'd Shipped
    54BLUE
    1) OSWEGO - Shipped - two extra brackets
    2) Erikj83 - Shipped one extra bracket
    SOLD OUT!
    54BLACK
    1) 4X4_TRD - PAID & INSTALLED. First Customer! Thank you Justin.
    2) bluetaco80 - Shipped
    3) Spectre - Shipped
    4) Mountainman - Shipped
    5) MHS2846bg8 - Shipped
    6) Keynote22 - Shipped
    7) jrgutierr - Shipped
    SOLD OUT!
    "L" BRACKETS ONLY
    1) Digitalricepape - 1 BLACK Shipped
    2) sntckr - 2 BLUE Shipped
    3) LilManny - 1 BLUE Paid and Picked Up
    4) A_Bugs_Life - 1 Blue Shipped
    5) 1BlkT - 2 Blue Shipped
    6) SManZ - 2 Black Shipped
    7) c2theGreat - 1 Blue Shipped
    8) wareagle5693 - 1 Blue Shipped
    9) rolltide3705 1 - Black Shipped
    10) taco11 - Black Shipped
    11) Iaryks - 4 Blue Shipped
    Installation & Instructions
    First off, thank you for your purchase. All your packages will be arriving in a FedEx Express Tube Package (doesn't mean it's coming Express). For those of you ordering the 36BLUE or 36BLACK, they will arrived to you assembled. Should you be one of the few ordering the 54BLUE or 54BLACK, one bracket will be attached to one bar and the other bar will have two brackets attached. I've done this to avoid ruining the finish of either the powder coated blue or rubberized black.
    Remove the black cap at the end of your bed rail bar.
    remove the bolts from the L brackets and slide those bolts with the washer into the bed rail system. The only thing exposed should only be the bolt.
    Align the bolts through the holes of the bracket and tighten to your desired location. It's my opinion, but avoid the sections of the bed rail system that have the slots for the cleats. The purpose it allow the use of the cleats while still using the bed rail/light bar.
    Here are the tools that you'll need. Grab a flat screwdriver and a 9/16 socket wrench.
    Using the screwdriver, place it behind the bolt in order to prevent it from spinning while simultaneously tightening the nut.
    *Please note that the black bars will have an extra washer that needs to be placed between the nut and the bracket. This is done to protect the finish and not expose any blue behind the black.
    Finished look with the "L" bracket installed. Do this as many times as you have "L" brackets, but before you tighten make sure your holes from the bars on top are aligned to your desired location.
    Pictures of other members light bars
    1st Generation Tacoma
  3. Feb 21, 2010 at 8:37 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    reserved for late...
    touch my body!
  4. Feb 21, 2010 at 8:38 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    1.ToucanV13: 54 Blue and L Bracket
    2.
    3.
    4.
    5.
  5. Feb 21, 2010 at 9:04 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    I'm a bit lost on the Note section. It says for $70 its a black bar, but in your notes, the L brackets are actually blue?
  6. Feb 21, 2010 at 9:10 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    Purchase list...
    36BLUE
    1) Hedlesbrmstkbass
    2)
    3)
    36BLACK
    1)
    2)
    3)
    54BLUE
    1) ToucanV13: 54 Blue and L Bracket
    2)
    3)
    54BLACK
    1)
    2)
    3)
  7. Feb 21, 2010 at 9:27 PM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    i would like to purchase a 56blue, i still need to get pics of the tonneau cover, before i commit... and its been snowing for 4 days straight here... ill try to get them this week...
  8. Feb 21, 2010 at 9:35 PM
    w8n4mud
    Albert
    Chula Vista, CA
    They came BLUE from the factory. I personally would have to sand them down and prep them for painting. That is why I'm charging more (supplies and labor). The blue ones are ready now.
  9. Feb 21, 2010 at 10:17 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    aahh gotchaa! They look amazing - great job
  10. Feb 21, 2010 at 10:28 PM
    w8n4mud
    Albert
    Chula Vista, CA
    :D Haha. So it that a yes? Want me to spray one in red for you Jeff? :p
  11. Feb 21, 2010 at 10:31 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    SOON. my other car is sucking me dry right now :cool:
  12. Feb 21, 2010 at 10:39 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    anyone can reccomend good lights for this thing? idk offroad products that well lol...
  13. Feb 22, 2010 at 8:31 AM
    w8n4mud
    Albert
    Chula Vista, CA
    LOL. I've got nothing special on mine. It's a good (sealed) and cheap ($6) light thats bright and serves the purpose of letting other tacomians know where I'm at when off-roading in the mtns or desert. I'm sure your WalMart should have a decent selection. You could always put some real sweet lights back there too.
    try www.offroadwarehouse.com just to see what's out there. Ebay for sure!
  14. Feb 22, 2010 at 8:38 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Seen these in person and they are great! Goodluck with your GB Albert!
  15. Feb 22, 2010 at 8:45 AM
    w8n4mud
    Albert
    Chula Vista, CA
    Thanks Matt. We'll see you soon.
  16. Feb 22, 2010 at 12:52 PM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Purchase list...
    36BLUE
    1) Hedlesbrmstkbass
    2) 08armytaco
    3)
    36BLACK
    1)
    2)
    3)
    54BLUE
    2)
    3)
    54BLACK
    1)
    2)
    3)
  17. Feb 22, 2010 at 3:25 PM
    w8n4mud
    Albert
    Chula Vista, CA
    FIRST CUSTOMER, 4X4_TRD purchased the 54BLACK
  18. Feb 22, 2010 at 3:36 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Looks great!!
  19. Feb 22, 2010 at 3:41 PM
    w8n4mud
    Albert
    Chula Vista, CA
    I'm stoked. Thanks Jeff. I know one is calling your name. Want it in red? Haha.
    :bananadance::bananadance::bananadance:
  20. Feb 22, 2010 at 6:29 PM
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    I can't wait to get it installed with some sick lights and a 4' firestik, PM sent.
