bed rail mounts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fire931, May 23, 2009.
  1. May 23, 2009 at 10:37 AM
    Fire931
    Fire931 [OP] Well-Known Member Vendor
    VA
    00 4Runner
    ok so i'll be honest. i saw a thread the other day about something like this someone made for themselves and it got me to thinking. i have the capabilites of doing this in numbers if there is enough interest.
    what i am looking for is how many people would honestly order a set of these mounts. they would slide into the factory bed rails and allow you to bolt something to them. the uses are endless, could be used for mounting hi lifts, bed bars, heck anything you can think of that you would want to bolt to the bed rails.
    its a simple design that would give you three tapped holes that accept a standard 3/8" bolt. i decided that three holes would be idea as it gives you a variety of mounting options, either using just the center hole, or using the two outer holes. it would be 2" long and machined to fit the channel of the bed rail. they would be made out of aluminum so no need to paint and no fear of rusting. the catch is that it requires enough machining that small quantities are economical. i would need atleast 25 people wanting to purchase a set (two mounts). they slide through the bed rail so you can position them anywhere you'd like. as of right now its just a design i have saved in cad so i dont actually have any pictures of them.
    so basically i am looking to see how many people would be interested and how much you would be willing to pay for such a thing.
  2. May 23, 2009 at 11:13 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Fire,
    well I am up for it, crap just for spit I will take 4. You never know when you will need one. I have these ones, but change is alway good.
    :threadjacked: any word on a new bumper? chomping on the bit here
  3. May 23, 2009 at 11:15 AM
    Fire931
    VA
    00 4Runner
    i'm working on it... well not at the moment, taking a break from playing ball with the little guy.. it is making progress though..
  4. May 23, 2009 at 11:23 AM
    longbow
    Bill
    Indiana
    Sweet
    family come first.
    If you get some time PM me a rough price on the bumper. Looking to buy before July is possible.
  5. May 23, 2009 at 11:29 AM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
  6. May 23, 2009 at 11:32 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
  7. May 23, 2009 at 12:24 PM
    Fire931
    VA
    00 4Runner
    no.. these would act as a "nut" inside the factory bed rail... thus allowing you to bolt something to the face of the bed rail. but they would be machined so that once the bolt is loosened they would slide freely inside the rail allowing you to move them back and forth. basically you could use them as the "nut" to bolt on things such as a cb antenna bracket, or put a tab off it to mount a hi lift jack, maybe a bracket to mount a light off of... ect.
    i've been trying to get my cad program to let me save a picture of it in 3D but its not cooperating right now.
  8. May 23, 2009 at 12:43 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Depending on price i might go for 2 or 3 sets.
  9. May 23, 2009 at 1:47 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    dittoramo x4 or 6
  10. May 23, 2009 at 1:52 PM
    BUZZ5
    BUZZ5 Well-Known Member
    S.Carolina
    07 Prerunner DC TRD Sport
    Many
    I made my own.1" flat bar drilled & tapped,4" long with 2 3/8" tapped holes.I just bought a 3' stick @ Lowes & made some different lengths.You can make them to fit your needs,simple if you got a drill,some good bits & taps.You can cut lengths w/ a hacksaw w/a good blade or as I did with a air powered die grinder w/cutoff disc.
  11. May 23, 2009 at 2:00 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    never used a tap...is this to put threads into the bar?
  12. May 23, 2009 at 2:31 PM
    SaltySteve
    SaltySteve Well-Known Member
    Denver
    2012 4runner
    Yeah. You have to drill your hole to a certain size for a certain tap.
    They're pretty easy to use as long as your hole is good to start with.
  13. May 23, 2009 at 3:17 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Subscribing. :)
  14. May 24, 2009 at 4:23 PM
    mneuls
    mneuls Well-Known Member
    Fort St John, British Columbia, Canada
    5100's and dakar leaf 3"lift, Satoshi grill,
    Bilstein 5100's front and back, dakar 3" leaf springs, Westin bull bar, piaa driving lights, piaa replacement bulbs, H/U, 2x10" mtx tt65 subs, 1000w clarion monoblock, Mtx surround speakers. green wire mod. Flowmaster 40, airaid intake. scanguage II.
    t&b already make them they are called spring nuts. they are cheap like borscht. they come in 1/4" 3/8" and 1/2", although the 1/2 one is pretty thick.
    the pic gives a decent idea of shape, they are about 1 1/2" long by 1" wide, and the 1/4" one is about 3/8" thick, the would have to be modified to fit, but very little would be necessary. the spring keeps them fairly tight against the front of the channel, so they don't move around while you bolt them up.
    http://www.supertruevalue.com/thomas-betts-za100-1-4-5pk-1-4--20-spring-nut.html
  15. May 24, 2009 at 4:32 PM
    SaltySteve
    Denver
    2012 4runner
  16. May 24, 2009 at 4:35 PM
    mneuls
    it's sposed to be behind the nut, in the back of the track.
  17. May 24, 2009 at 5:22 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Can't get enough info on these...even from the Thomas& Betts web site....
  18. May 24, 2009 at 5:56 PM
    mneuls
    what do you want to know? they are pretty simple things. I'll run to the shop tomorrow and grab a couple to show off. you can purchase them at pretty much any electrical wholesaler.
  19. May 24, 2009 at 6:21 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    How thick are they? Wide? Are they all the same base size with just different hole/thread sizes? I have seen a lot of stuff, but this is the first I have ever seen of these - what applications are they more typically used in?
    OK, these are basically a more complex version of stamped spring nuts.....here are some with bolts in them......they are called "Unistrut Spring Nuts" and appear to be designed to slide into some type of metal flange used in the electrical trade.
    http://store.eberliron.com/products/unistrut_parts/unistrut_stud_nuts
    Seems like these would work nicely if the base was thin enough to slide into the bedrail accessory channel.
    And here are the channels they are designed to fit into. If you can find a channel the same size as the one in the bed, they have Spring Nuts on this site to fit it perfectly:
    http://store.eberliron.com/search.php?q=P1000&search.x=0&search.y=0
  20. May 24, 2009 at 6:30 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I'd be in for a set or two... need to mount my bike mounts and cb antenna and... hhmmmm I could find other needs for them...
