Bed Stiffener Alternative Solution???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoma_JT, Dec 4, 2020.
  1. Dec 4, 2020 at 2:01 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I would just watch how much weight is on the bedsides. Other then that, just enjoy your truck. Things happen and you can prevent it as much as possible but really the only way to keep it new is not to drive it. So might as well enjoy.
    This is my bed, it split. Second pic shows how the bed stiffeners didn’t help as the bedside pulled away from the support.
    can see the total chaos bed stiffener is in the right place, but the sheet metal is what pulled away.
    BillsSR5, tacoma_JT[OP] and YF_Ryan like this.
  2. Dec 4, 2020 at 2:01 PM
    tacoma_JT
    tacoma_JT [OP] Well-Known Member
    2021 Tacoma DCSB TRD OR
    That's one of the reasons I am leaning toward the overland bars, keeps the weight down lower. I thought about just putting the tent over the cab and not worrying about it at all. But not sure I'd like the way that looked. Thanks for the information!
  3. Dec 4, 2020 at 2:02 PM
    tacoma_JT
    Good approach. Thanks!
    Kovaci[QUOTED] likes this.
  4. Dec 4, 2020 at 2:05 PM
    tacoma_JT
    I am good with not having a project if I don't have too :)
    But I may go ahead and do it.
    What you're describing sounds a lot like what I have heard people say about hiking boots and the way they turn what would have been a twisted ankle into a twisted knee.
  5. Dec 4, 2020 at 2:06 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Wow... that's interesting. Thanks for sharing the pic!
  6. Dec 4, 2020 at 2:09 PM
    tacoma_JT
    Oh wow... sounds like what JdevTac was saying about creating a new point of failure.
    But you bring up a good point about just enjoying the truck. That's probably what I need to do instead of worrying about this :)
    Thanks for the advice!
  7. Dec 4, 2020 at 2:13 PM
    projghost
    projghost Well-Known Member
    Joey
    Portland OR
    2019 TRD OR DCLB
    Bilstein 5100's +2" front Rear Wheeler AAL +1.5" Rear Dirt King Balljoint UCA's Method 701 Wheels BFG K02 C4 Hybrid Front Bumper RCI Skid Plate Baja Designs S2 Sport Ditch Lights Baja Designs Squadron Sport Fog Lights Cali Raised DItch Light Brackets CVT Mt Bachelor RTT CBI Overland Bars Cali Raised Rock Sliders Prinsu Cab Rack TheTacoGarage TRD pro grill + raptor lights CBI/prinsu Maxtrax and Rotopax mounts Victory 4x4 Bed Stiffeners ActionTrax boards 2g Rotopax (Gas/Water) Ironman 4x4 Compressor Agency 6 Recovery Hitch Blacked out Emblems
    Do the bars. very versatile and well priced. plus having the tent on the cab is pain to open/close. It'll save your fuel economy too
    tacoma_JT[QUOTED][OP] likes this.
  8. Dec 4, 2020 at 2:13 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    No worries.
    I was loaded with what I thought was normal. Contractor cap, rtt, rack, some tools in the tool box of the cap. Setup looked like a lot of others setups around here. Whether it was my truck or the way I wheeled or something it happened. So my words of wisdom are try to keep the weight of the rails as much as possible. Rtt and a light cap probably is fine. I had a heavy roof rack, and tools in the side boxes. Thought it was normal but meh. It is what it is.
  9. Dec 4, 2020 at 2:14 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  10. Dec 4, 2020 at 2:14 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    The bars are going to tie the bed sides together very well, so bowing out is probably not something that will happen until you have so much weight that the rack/bars/joints are stressed to the point of yield. The one piece welded tube type racks (All-Pro bed bars for example) are probably better for this type of strength, but any should help. The weight on the bars, when cornering or bouncing around will try to move the weight and the rack from side to side, flexing both bed sides with it. Your crossed ratchet strap setup will certainly help, but only on one strap at a time because you cant push a strap, and over tensioning them may induce inward flex on the bed sides that could hurt more than it helps, so be mindful of how much tension you set them up with.
  11. Dec 4, 2020 at 2:19 PM
    tacoma_JT
    Agree with all of that! Plus they are super easy to remove if I need the whole bed for something.
  12. Dec 4, 2020 at 2:23 PM
    EnBoo
    EnBoo Well-Known Member
    Nathan
    Denver, CO
    2018 DCSB Quicksand Sellout
    I've had bars. They don't necessarily keep the bed together. Sometimes the bumps and rough terrain will push it out. I noticed my bed was way out of shape so I did the ratchet strap thing too. But bed stiffeners are just a way better solution. You never have to think about it again..
  13. Dec 4, 2020 at 2:23 PM
    tacoma_JT
    Good stuff here! Thank you! I am thinking to check the tailgate on both sides after installing the straps to make sure the gaps remain unchanged.
  14. Dec 4, 2020 at 2:24 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    That would only be the case if the strap was from bed rail to bed rail creating a square structure from a C structure. His straps are rail to floor, which creates two triangle structures, which is stable. The only issue with this would be a strap is tension only, so it only prevents rolling the bed rail outward, vice a gusset that supports inward and outward.
    tacoma_JT[OP] likes this.
  15. Dec 4, 2020 at 2:26 PM
    #35
    tacoma_JT
    Makes me feel better that someone else has at least tried this. I hear what you are saying about the stiffeners being a better solution. Definitely wouldn't forget to do them as I know I would at some point with the straps.
  16. Dec 4, 2020 at 2:28 PM
    #36
    tacoma_JT
    Do you think the overland bars along with the straps will help keep the bed from rolling inward? Seems like with the overland bars in place, one strap keeps both sides from moving one way, and the other strap keeps them from moving the other way. Does that make sense?
  17. Dec 4, 2020 at 2:36 PM
    #37
    tacoma_JT
    You sound like my wife :) I might have been accused in the past of over analyzing things! Thanks for the reminder to just enjoy it!
  18. Dec 4, 2020 at 2:36 PM
    #38
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Yep, that makes sense. The rack functions to close the C structure into a square, preventing them from inward movement. The straps keep each side from outward movement, and one moving inward while the outward.
  19. Dec 4, 2020 at 2:38 PM
    #39
    tacoma_JT
    Yeah... I know. But just got to thinking about this. And thought I'd get some feedback. May end up installing some of the stiffeners like these.
  20. Dec 4, 2020 at 2:41 PM
    #40
    tacoma_JT
    Thanks for the welcome! I'm neither of those things either :) And you're right, $100-$160 is not a lot of money and I may go that route. Thanks for responding. Maybe this is an ok solution for a little while.
