bed tie downs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by michigantacoowner, Jul 27, 2007.
  1. Jan 15, 2008 at 5:14 AM
    #41
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Because the bolts hold the d-ring tight. If you had a bolt that stopped, say, 1/4" before the head touched the bed then it could swivel. Then again, these bolts hold the bed down so if they aren't tight the bed would rattle and move a little.
  2. Mar 9, 2008 at 10:15 AM
    #42
    cycledrum
    cycledrum Well-Known Member
    Union City, CA
    88 4X4 Pickup xtra cab, SR5
    Or with a much heavier motorcycle in a short (5ft.) bed, was thinking to put a slab of plywood in bed out to end of tailgate (distribute load of heavy rear), then screw down a couple blocks of wood onto the plywood to chock a motorcycles front wheel ....
    all this and I don't even own a Tacoma. Gonna be at least 6 months or more before I take the plunge.
    Sounds like the movable cleats are ok for a sport bike.
  3. Mar 9, 2008 at 10:28 AM
    #43
    piercedtiger
    Jon
    Southern Tier, NY
    NO!!
    Ok, sorry to yell, but one guy did that and the cleat broke. Handle bar punched through the bed so not only did he have to replace the bed, but he also had to fix the bike.
    I just wouldn't do it! Use D-Rings so you don't risk damaging the bike AND truck.
  4. May 28, 2008 at 3:41 PM
    #44
    BLOCKADE
    BLOCKADE Well-Known Member
    TRD Off Road
    Weather Tech Floor Liners, Front Bed D-Rings...
    Maverick, what type of bed you have. I ordered the exact same tiedowns as you and am prepared to install them. When I went to measure for the holes I realized that, 1. I cant even get to the bottom of the bed on the drivers side, the fuel tank is in the way, and 2. the measurement on the passenger side won't work, the 1.25 inches is too far over and .25 is too far down. I have a double cab, short bed. I noticed you have an access cab and I assume its a long bed. Any info?
  5. May 28, 2008 at 5:31 PM
    #45
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Yeah, I have an access cab long bed. I actually didn't even think about the two bed configurations being different on the underside. Best guess would be to go with the mounting instructions that came with the tie-downs, and put them as low ans as forward as you can in the sides of the bed.
    Sorry for the confusion, and I'll edite the original post when I get a chance to avoid further confusion in the future.
  6. May 28, 2008 at 6:03 PM
    #46
    RCNG FAN
    RCNG FAN Active Member
    I tie down a KTM 300 dirt bike in the back of my Tacoma. I do not trust the cleats, so I got some extra Toyota D-rings and mounted them under the front bolts that hold the bed directly to the frame. Very secure. :cool:
  7. May 28, 2008 at 8:32 PM
    #47
    BLOCKADE
    TRD Off Road
    Don't worry about it, I just thought that I would make that fact known. I'm going to get up under there Friday, so I'll let you all know what I decide to do.
  8. May 28, 2008 at 8:51 PM
    #48
    BLOCKADE
    TRD Off Road
    I would, but I want the pivot ability, and I don't own a hex bit that big.
  9. May 28, 2008 at 9:13 PM
    #49
    budisit
    budisit Active Member
    Buddy
    white, long bed, TRD, dbl cab
    If you bolt the d-rings under the bed bolts they will not spin. So how do you decide which direction you want them to be since they will not turn.
    I'm going to bolt my d-ring under the bed bolts. And I'm thinking about pointing them about a 45 degree. Like from corner to corner.
    BUDDY
  10. May 28, 2008 at 9:14 PM
    #50
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^That's what I'm doing, about that same angle.
  11. May 28, 2008 at 10:12 PM
    #51
    RCNG FAN
    I only tie down one thing with those front rings....... motorcycles.
    Thus, I know how I want them. :)
  12. May 29, 2008 at 4:11 AM
    #52
    budisit
    Buddy
    Whoda thought U could have a 3 page chat about d-rings.....:D
  13. May 29, 2008 at 5:23 AM
    #53
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    12 DCSB TRD Off-Rd 4x4, Roof Rack, Tube Steps
    K&N drop-in air-filter, extra D-rings, Custom Console lock-box, Leather heated seats, Studly Driver
    That's what I did with mine. I've got another set that are going on the middle bed bolts. I've put several different bikes in the back with no problems. You can use the side rail D-rings but you can't tighten them very much before you start to see them bending toward the strap.
  14. May 29, 2008 at 6:03 AM
    #54
    piercedtiger
    Jon
    Southern Tier, NY
    The way mine are it doesn't really matter. I can still get a ratchet strap hook through them. I've never needed them to, or wish they could, swivel.
    th_DSCF0739_92da6bbd1f5197f6eb650ba9238e55197e31370f.jpgth_DSCF0742_99683ebff939d7e0556c87bb48daf37c6c6cf771.jpg
  15. May 29, 2008 at 10:15 AM
    #55
    BLOCKADE
    TRD Off Road
    RCNG FAN You didn't cut your washer like most people do, does the D-ring still swivel?
  16. May 29, 2008 at 3:08 PM
    #56
    BLOCKADE
    TRD Off Road
    I got up under there today and there is almost no way I can get to the Drivers side of the bed from underneath. I think my only option is to go with the suggested location on the wheel well. I don't have a T45, or T50 or whatever size that bed bolt is.
  17. May 29, 2008 at 4:15 PM
    #57
    piercedtiger
    Jon
    Southern Tier, NY
    I didn't have one either! :laugh: I just picked up a single bit for a socket wrench, and ended up putting it on my impact wrench to get them out. Bit was only a couple bucks at a tractor supply store IIRC.
  18. May 29, 2008 at 4:52 PM
    #58
    BLOCKADE
    TRD Off Road
    is it a t45 or t50?
  19. May 29, 2008 at 5:28 PM
    #59
    piercedtiger
    Jon
    Southern Tier, NY
  20. May 29, 2008 at 7:11 PM
    #60
    RCNG FAN
    That would take a VERY special Torx bolt that would tighten down BELOW the D-ring in order to allow the ring to swivel above it. I don't think anyone makes one for this specific purpose.
