Bed underside rust
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1stgenDrew, Nov 1, 2019.
  1. Nov 8, 2019 at 6:10 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    Oh, tacoma beds always rust through right there, on the seam between the bed side sheet metal and the bed floor.
    I think it's because the wheels do throw rocks at the bed, eventually cracking the kind of bedliner layer that is on the bottom face of the bed, allowing moisture in and making the seam rot from within
    Unfortunately, the only thing you can do is cut what is bad and weld a new plate in
    Here's what I did to fix mine:
    [​IMG] [​IMG]
    I used L-flashing angle, the type you use for roofs, to patch my bed. It's pretty much the same thickness as the wheel well section but it's also a tad thinner than the corrugated bed floor
  2. Nov 8, 2019 at 9:49 PM
    joe25rs
    joe25rs Well-Known Member
    Joe
    Mrr’land
    2004 Black TRD
    Damn dude, nice job ^
  3. Nov 9, 2019 at 8:47 AM
    Thad
    Thad Well-Known Member
    Thad
    Pittsburgh
    2004 Tacoma
    Mine rusted in that exact spot also
  4. Nov 9, 2019 at 6:01 PM
    testelle
    testelle Well-Known Member
    Todd
    Oley, PA
    2003 Red 3.4L 4WD DCSB
    I was going to say almost precisely the thing that Onakat already mentioned if he didn't already mention it. Yes, from my experience having just replaced my bed entirely I would attest that the seam of metal between the wheel well and the center portion of the bed that runs front to back all the way down the bed is what rots out. I guess the factory seam sealing material just eventually corrodes and falls out and you're left with a place that water can get it up in there and cause rust. I resealed that whole seam on the bed I was refurbishing before then painting over it and lastly undercoating it before mounting.
    GQ7227[QUOTED] likes this.
  5. Nov 9, 2019 at 6:11 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    dudette! for lack of a better word i cannot think of right now
    onakat likes this.
  6. Nov 9, 2019 at 6:27 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Some fine looking work and clear explanation of what's going on
    That's exactly what's going on
    GQ7227 likes this.
  7. Jun 30, 2021 at 8:24 PM
    Dylwhit
    Dylwhit Well-Known Member
    Dylan
    2004 2.7l extcab
    Anyone ever paint the underside of their bed? Ive got a bit of rust down there and Im thinking anout hitting it with left over POR15 ive got from painting the frame.
