Beefing up stock front shocks
Discussion in 'Suspension' started by TastyHuman, Dec 19, 2011.
  1. Dec 19, 2011 at 7:57 PM
    TastyHuman
    TastyHuman [OP] Oh. Bummer.
    In 85k miles my 2007 Tacoma Access Cab 4x4 is on it's 5th set of front shocks. The originals, three sets of KYBs, and now Bilsteins. I drive about 10 miles/day on a rough gravel logging road and the shocks just don't seem to last. The rest of the time it lives on smooth pavement, no off roading.
    If/when the Bilsteins blow out what are some good options for beefing up the stock front end while maintaining the same ride height?
  2. Dec 20, 2011 at 10:09 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    sounds like you need a good set of monotubes or even a set with an external body? Monotubes offer more nitrogen pressure, better cooling and a bigger valve. Perfect for roads that will not allow the shocks to cool off.
  3. Dec 20, 2011 at 10:29 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Yep, if I was going through shocks like that I would want something rebuildable.
    King would be another one.
    Downsouthmotorsports would be a good place to shop them.
  4. Dec 20, 2011 at 11:16 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Do you have any kind of lift on your truck?
    A Monotube like the 5100s is certainly a good choice.
    You may need to look into a larger shock though if the roads are really rough, and you are going along at a good clip for long distances.
    A set of Icon Coilovers, and Rear Icon shocks should do the trick, but if that is not in the budget, then the 5100s are probably one of the best options.
  5. Dec 20, 2011 at 11:49 AM
    TastyHuman
    No lift on the truck. The KYBs were monotube (Gas-A-Just model) and the Bilsteins are monotube 5100s. Hopefully the Bilsteins will last but, if not, it looks like the next time it will be coilovers. All of these have lifetime warranties but it's a pain to change them out that often.
    Thanks for all the input!
