Beep Alarm with Tire Rubbing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by avengedkevinfold, Feb 18, 2011.
  1. Feb 18, 2011 at 1:33 PM
    avengedkevinfold
    avengedkevinfold [OP] Well-Known Member
    Kevin
    Socal - OC - Huntington Beach
    bilstien 5100s all the way around, ICON progressive 3 leaf kit, Illegal tint, snuglid SL, seatbelt chime mod. light racing UCAs
    I was driving up a freeway onramp the other day and took the turn a bit too fast. It was a right turn and I heard the drivers side front tire rubbing. I'm assuming it's the front tire rubbing on the front bumber plastic near the lower front bumper. Sound right?
    My caster is at 1.7 and 2.4.
    Anyways, what exactly is this beeping sound mean? I know its some sort of indicator but wanted to know what exactly its telling me.
  2. Feb 18, 2011 at 1:34 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    VSC...tells ya to not drive like a jackass. as for the rubbing, it could be front or back...more than likely it's the back. what wheels/tires are you running? any lift?
  3. Feb 18, 2011 at 1:44 PM
    avengedkevinfold
    Kevin
    BFG AT 265 70 17
    2.5 inch lift with billstiens
  4. Feb 18, 2011 at 2:03 PM
    The_Hodge
    SC
    i wouldnt be worried about it. just make sure to be more careful next time.
  5. Feb 18, 2011 at 3:22 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    tires where probably slipping, not rubbing
    hense the cause for the beeping
  6. Mar 6, 2011 at 9:53 PM
    ttime4four
    ttime4four Well-Known Member
    West Linn, OR
    10 Tacoma 4x4 SR5 DCSB
    Couple of days ago, I was turning a corner and my left rear tire kissed the edge of the curb - I heard a beep. Assume this is what you are referring to - is this some kind of slip warning signal?
  7. Mar 6, 2011 at 11:23 PM
    skistoy
    Western New York
    Kind of
    the beeping is telling you the traction control was activated.
    when a tire starts to spin freely, like on ice, or loses contact with the road
    the traction control applys the brake to that wheel
    and the beeping sounds
