beeping coming from front Diff?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ez_money08, Jan 29, 2010.
  1. Jan 29, 2010 at 11:20 PM
    ez_money08
    ez_money08 [OP] EZ's Black Taco
    San Diego
    Blacked out '08 Tacoma SR5 4X4 4.0L
    3 1/2" Icon coilovers, wheelers 2" AAL's, Total Chaos UCA's, diff drop, carrier bearing drop, TRD Cai, Magnaflow exhaust, halo projector headlights, L.E.D tail lights, Blue gauge light mod, Satoshi grille, Hella 700's with H.I.D conversion behind grille, herculiner on rockers and rear bumper, lighted buggy whip mount in bed
    So I have a 4x4 and my 4 wheel drive has been acting up lately. starting the truck in 2 high, the 4X indicator light flashes and continues to flash, but 4x doesn't engage. try to put it into 4 wheel and it won't engage. Now I can hear a faint beeping coming from somewhere near the front diff. The stealership told me the ecu was having trouble recognizing the tire size due to irregular tire pressure, thus confusing the ecu. they old me to run my 33's at 42 pounds. tried that and they're full of shit, it didn't work.:mad: Anyone have any ideas on what's going on?
  2. Jan 30, 2010 at 7:43 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    As far as I know (from all i have read) there is no beeper / speaker anywhere on the front diff. There should be a loud beeping coming from the dash when 4 LO fails to engage.
  3. Jan 30, 2010 at 7:49 AM
    Nowhereman04
    Nowhereman04 Well-Known Member
    Tar Hill Blue NC
    Silver 04 DC 4x4 SR5 TRD OFF ROAD
    Bilstein 5100's front, Bilstein 5125's rear
    why can't they just go back to the manual locking hubs. no worries with em'.
    OffroadToy and Key-Rei like this.
  4. Jan 30, 2010 at 7:50 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    x2.hmmmmmmm
  5. Jan 30, 2010 at 10:05 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    They are more durable, but then you have 99.9% of the Tacoma owners bitchin' that they have to get out and twist the hubs. There is enough whining now about lack of heated seats, heated mirrors, courtesy light, no illumination on 4x4 switch, etc that I doubt they'll want to get out and twist some hubs once their stuck it snow/mud.
    Good idea and I agree, but I think 99.9% of Tacoma owners will give Toyota grief over it for sure.
  6. Jan 30, 2010 at 10:42 AM
    ez_money08
    San Diego
    the beeping is coming from underneath somewhere near the front diff. no idea exactly what's beeping. I'd rather have the manual shifter. seems like the more electrical stuff trucks have, the more can go wrong. They need to keep things more mechanical
  7. Jan 30, 2010 at 11:04 AM
    Fortech
    CANADA
    Is it like an electronic beeping from an actual beeper or a whistle or whining noise from something electric or mechanical?
    There should be vacuum lines that run to the front diff for engagement. Maybe one of them is leaking?
  8. Jan 30, 2010 at 11:38 AM
    ez_money08
    San Diego
    it's like an electronic beeping
  9. Jan 30, 2010 at 11:41 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Video/Audio from IN CAB and UNDER the truck please!!
  10. Aug 19, 2022 at 4:46 PM
    B.Root
    B.Root IG: root_overland
    Bryan
    Dry Ridge, Ky
    2012 Tacoma TX Pro
    What was the issue. I am having same problem. Aftermarket dorman actuator just installed. Now it’s beeping and 4wd hi light flashing
  11. Aug 19, 2022 at 4:48 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    your issue is the dorman unit, it’s junk right out of the box.
    Dm93, TnShooter and AJKlug1 like this.
  12. Aug 19, 2022 at 4:51 PM
    B.Root
    Bryan
    Dry Ridge, Ky
    2012 Tacoma TX Pro
    The 4wd engages and dis engages fine but the 4x4 light flashing green. It was flashing green and 4wd wasnt working and my actuator was full of water so I installed this one. Tried leaving battery unplugged a bit to see if it would reset. But no luck.
  13. Aug 19, 2022 at 7:06 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    unplugging the battery will do nothing for the 4wd ECU, it doesn’t have any kind of “memory” or store codes.
    B.Root[QUOTED] and Dm93 like this.
  14. Aug 19, 2022 at 7:34 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check your limit switch voltages as outlined in the thread below, I'll bet you find one of them isn't working properly or you have the Transfer Case Actuator mis-timed.
    https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/
    B.Root[QUOTED] likes this.
  15. Aug 19, 2022 at 7:51 PM
    B.Root
    Bryan
    Dry Ridge, Ky
    2012 Tacoma TX Pro
    Thanks! I’ll check it out tomorrow. I was just looking to see if I could rest the 4wd ecu. The original problem was the green light was flashing so I removed the stock actuator and opened it up and greased the gears and soldered the connections. I had a small amount of water in it. Found hole in top vent line. Replaced hose. Reinstalled and everything worked great for about a month. Then 4x4 light started flashing. Would not engage in 4wd. However if I switched to 4hi when truck was off and then turned the key on, it would go into 4hi. Then 4lo and back to 2wd. Then about a week later it stopped working all together. I order a new dorman actuator and installed today. Opened up the old one and full of water. Found crack in lower hose.
    installed actuator and drained and refilled diff. Tested and green light flashing but 4hi and 4lo work and lights stay solid like they are supposed to. Then back to 2wd and goes into 2wd but light flashing. And the new actuator is beeping. I’m lost lol.
  16. Aug 20, 2022 at 6:06 AM
    B.Root
    Bryan
    Dry Ridge, Ky
    2012 Tacoma TX Pro
    Woke up this morning and started the truck to drive it down to the garage and the 4wd light not flashing now. Everything works as normal. I’m lost lol. I have no idea. Will see if it stays this way. Only time will tell.
  17. Dec 15, 2022 at 6:35 PM
    B.Root
    Bryan
    Dry Ridge, Ky
    2012 Tacoma TX Pro
    Update: All is working as normal. Still no issues. Hasn’t beeped again and have used the 4WD many many times. Guess it was programming itself. I contacted Dorman when it was happening and the guy didn’t have a clue about it.
