beeps while truck is rocking?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by maju, May 6, 2010.
  1. May 6, 2010 at 5:42 PM
    maju
    maju [OP] Well-Known Member
    Davenport Fl
    2010 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
    Ok so here's whats happening, the turn into the road i live on (I am the only house on it, it is a access road to a reservoir) has a 2 foot wide rain channel so its like I drive over 2 speed bumps when I make the turn.
    When I go over it (I am turning) the truck bounces from side to side. If I am going above 15 MPH I get a series of beeps (beep, beep, beep).
    Since the wheel is turned I cannot see if any lights come on.
    any ideas?
  2. May 6, 2010 at 5:58 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    The traction control is kicking in, one of your tires is loosing traction and spinning
    once it starts to spin the traction control kicks in, and you get to enjoy the beeping!
  3. May 6, 2010 at 5:59 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
  4. May 6, 2010 at 6:01 PM
    James3492
    James3492 Well-Known Member
    James
    EAST COUNTY
    Black-out Tail lights Painted Rims & Hood Scoop
    I think its the traction control thats telling you to slow down but yeah if its a everyday thing :/ sorry bud
  5. May 6, 2010 at 6:58 PM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    Beeping is the VSC stability (not traction control) function.
  6. May 6, 2010 at 7:13 PM
    maju
    Davenport Fl
    hmm... Thanks for the input, that is what I thought it was.
    Would getting the TSB done for the rear end help reduce the rocking, and thus allowing me to make this trun at a normal speed?
    The speed on the both roads are 45 (I know I need to reduce speed below 45 to make the turn, but dropping to below 15 seems a bit much).
    Would I need to anything more like upgrade the shocks or something to amke things a bit stiffer?
  7. May 6, 2010 at 7:25 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It beeps and a light flashes to let you know the VSC is doing what it can to keep you from spinning off the road and rolling over! IT WORKS, but it beeps to let you know to say 'thank you' for saving you and your truck! LOL
    When you do some more serious off roading in sand or mud and fishtail a lot, it will really be beeping you to death... If you don't need the enhanced traction of TRAC to keep from getting stuck, then STOP and HOLD down the VSC OFF switch for 3+ seconds until you get the VSC OFF indicator light... You now will be in good old fashion open differential mode... VSC stays off, unless you do something that could cause the truck to go out of control... then it will come on to save you!
  8. May 6, 2010 at 7:26 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    If anything the TSB would make the rear end more rigid thus hop easier. The problem isn't as much the rocking, but rather the combination of a light rear end and an unboxed ladder frame.
  9. May 6, 2010 at 7:50 PM
    maju
    Davenport Fl
    I think I will try adding some weight to the rear, see if that helps.
    starting with 100lbs and go up or down from there depending on the affect.
  10. May 16, 2010 at 8:40 PM
    225nontypical
    225nontypical ????????????
    backwoods
    11 tundra DC TRD OffRoad
    bilstein 5100's weather tech floor mats katskinz leather heated seats
    so my truck is doing the beeping thing bad! also i get a grinding feeling sometimes from the right front (at least that is what it feels like) anyway i held down the button that shows a truck sliding and the light on the dash came on. i drove all the way to the coast (crappy road) no problem then i had to turn on a steep hill as so i was at an awkward angle anyway it beeped and i got the grinding sound and feeling anyway so it that normal even with it off or are there two different things going on?
  11. May 16, 2010 at 8:49 PM
    billas333
    billas333 They Still Love To Hate Me! - T.O.
    Joel
    NorCal
    2008 4x4 Tacoma Sport
    Mods so far: Tube steps from toyota, Bed extender from toyota, Spare Tire lock, Sound System Makeover, Tacoma All-Weather heavy duty rubber floor mats. Rear TSB, Icon Coilovers w/ TC UCA's and 3inch rear block with rear 5100 bilstein shocks, Black Headlights, Grillcraft black grill, Devil Horns from Andres, Black Headlights, Chrome Liquid Metal Gatlins Wheels, 285/70R17 Nitto Tera Grapplers, Wet Okole Seat Covers! Seat Belt Chime Mod, Flowmaster 50 series dual exhaust, Debadged tailgate, TRD Decals, HID hi/low + fogs.
    Yea similar thing happened to me. I was in the snow a few weeks ago and was driving down a pretty steep grade driveway and the beeps came on out of no where until I got off the incline then it stopped.
  12. May 16, 2010 at 9:21 PM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    I find the VSC is WAY too sensitive. I often have it kick in just pulling into the driveway when it's icy outside, or going around corners on wet pavement at speeds where it SHOULDN'T kick in. Weight in the bed helps, but it's still too sensitive in my opinion.
  13. May 16, 2010 at 9:28 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Mine kicked in today on dry pavement with my wife at the helm , I agree , way too sensitive .
    OZ
  14. May 16, 2010 at 9:31 PM
    225nontypical
    backwoods
    nothing but dry pavement here right now and it keeps going off i am about to go nuts. what is with the grinding noise and feeling up front???????? the beep i could live with, but this other crap!!!!
  15. May 16, 2010 at 9:36 PM
    gtrotter
    gtrotter Well-Known Member
    Interlake, Indiana
    2009 Regular cab 4x4, ARB's, 4.88's, bumpers, 2017 DCSB SR5 stock,2008 Reg. Cab 4x4
    locker,mud tires, lifted, toolbox
    and you guys know the fix for it, right? Pull the 30 amp fuse for it. I think the fuse may say ABS on it or something, it will be a pink fuse. I did it and it completely disables all traction control and ABS, etc.
  16. May 16, 2010 at 9:45 PM
    OZ-T
    Peter North
    British Columbia
    The grinding noise / feeling is the brakes being applied , that's how the system works , it applies braking to the tire it deems to be over - rotating in an effort to straighten out the truck . It is actually coming from the rear but you may feel it in your feet through the pedals .
    You might find some help here , http://www.tacomaworld.com/forum/suspension/41215-lift-vsc-answer.html , you can get the skid control ecu re-calibrated or zeroed post lift , it has helped many members .
    OZ
  17. May 16, 2010 at 10:08 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    This only makes sense if you want to disable ABS and you're off-roading. It would be ill-advised for street/highway driving.
    The snow will make your tires skid sideways and VSC will activate. I'd recommend turning off VSC when driving in snow or drive slower.
    If you corner hard, VSC will activate, especially if you drive aggressively. If you drive conservativly and its going off then you need to visit the dealer for a VSC recalibration.
    Drive slower around the corners and VSC will not activate. Also, you can disable it each time you start your vehicle using the procedure whippersnapper02 stated in his post. He was correct.
    If you drive on the highway you should have VSC on. It can save your life in the event of an emergency.
    If anyone had done anything to their truck to warrant a front alignment adjustment, then recalibrating VSC would be in order.
  18. May 16, 2010 at 10:28 PM
    billas333
    Joel
    NorCal
    thnx but i dont have vsc
  19. May 17, 2010 at 8:19 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Interesting. I know that if my truck is on an incline with the nose in the air and it's stopped and I let off the brake and don't push the accelerator and the truck begins to roll backwards, the VSC buzzer will sound (even though its not VSC being activated).
    With regards to beeping, the only other thing I can think of right now is if the truck was trying to shift into 4L and the truck was not in neutral or something.
    Did you ever figure out what it was?
  20. May 17, 2010 at 9:55 AM
    gtrotter
    Interlake, Indiana
    It makes sense if you don't little electronic nannies intruding upon your driving. For those that can actually drive a vehicle, the nannies are actually more of a hindrance. It wouldn't hurt anything on the street to not have it ifffff people would drive within their limits.
    On another note, if you drive gravel roads alot the nannies can actually be dangerous. There has been more than one time that it has thought I was sliding in danger. In all actuality, I was taking curve on a normal gravel road at normal speeds. The way it works, it would send me straight toward the ditch. Yeah, that just isn't safe.
