Before you replace the blower resistor ...
Discussion in '2nd Gen. Builds (2005-2015)' started by ibJAE, Aug 7, 2010.
  1. Feb 23, 2015 at 10:24 AM
    #41
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
  2. Apr 22, 2015 at 5:18 PM
    #42
    CBRN
    CBRN Member
    Joe
    Fort Hood, TX
    Taco SR5 PreRunner
    I have my blower motor on the bench and is drawing more than 12 amps, this seems a bit excessive. I need to know the OEM requirements for this motor, does anyone know?
    Thanks,
    Joe
    WiredPig likes this.
  3. Aug 1, 2015 at 8:46 AM
    #43
    Hoakster
    Hoakster Active Member
    2022 TRD Sport
    Had the same issue with the blower working intermittently on first three speeds, yet always on high....found this thread. Purchased OEM pigtail and resistor in brand new OEM packaging on EBAY for about $45 shipped. Just replaced today and just as pictured in previous posts, the "C" terminal was burnt. Cut off old pigtail, soldered new pigtail on...wait for it.....wait for it.....Voilà! Functions perfect now. NICE! Thanks Tacoma World Team!
    Last year I completed the overhead compass/temp guage repair...This site has paid for itself already. Wait, its free, perfect!
    #43
  4. Aug 26, 2015 at 6:51 PM
    #44
    tw909
    tw909 New Member
    Tim
    '06 2.7L Taco
    Just gave the "prongs" on the resistor a slight kink with some pliers and I was back in business at all fan speeds instead of just high.
    2WD likes this.
  5. Sep 2, 2015 at 1:54 PM
    #45
    AfrknMgk
    AfrknMgk Member
    2014 Spruce Mica Toyota Tacoma TRD Off-Road
    Flowmaster Super 44 Muffler Westin Chrome Bull Bar KC Spotlights Gentex-453 Thermometer/Compass/Homelink Mirror
    A buddy of mine is basically having the exact same problem with his '07 Tacoma. He is not so much having the issue of the blower motor only working on high, but instead it will not work at all sometimes. He will smack under the glove box a few times and it usually starts working again. We already looked at this, and replaced the resistor, but he is still having the problem. I do not remember noticing the connector appearing burned, but I will have to have him look at it again. Unfortunately, it's really hard to troubleshoot since the problem is so intermittent, and will either work or not work for no apparent reason. Besides the connection at the resistor, is there any other connections to check? I know he would really like to avoid replacing the blower motor if that is not the cause of the problem.
  6. Sep 2, 2015 at 2:18 PM
    #46
    JRzdcsb4x4
    JRzdcsb4x4 Active Member
    Winston Salem, NC
    14 Tacoma Sport
    My 14 was back to the dealership three times and all 3 times they replaced the resistor board when it was under warranty. My harness does not show a burn mark, but the terminal is bad. I have a small sponge under the harness connector that I used for a quick fix on a hot day, and its been working ever since!
    AfrknMgk likes this.
  7. Sep 3, 2015 at 1:36 PM
    #47
    AfrknMgk
    AfrknMgk Member
    I just talked with my buddy again today, and he said he has tried moving the connector going into the resistor board when the A/C was not working, and it did not make a difference. The only thing which seems to get it running is bumping under the glove box like he has been doing. This makes me think even more it could be the blower motor itself causing the problem.
  8. Sep 3, 2015 at 6:50 PM
    #48
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I'd pull the motor and check it manually. Might try taking the fan off and cleaning it and the motor.
    AfrknMgk[QUOTED] likes this.
  9. Sep 4, 2015 at 12:56 PM
    #49
    AfrknMgk
    AfrknMgk Member
    Thanks, Sandman614. I'll see if he wants to give that a shot. I think that would probably be a good idea that way we do not replace it if it is not necessary.
  10. Sep 30, 2015 at 6:50 AM
    #50
    Sandman614
    Tim
    '06 SR5 Off Road
    Wonder if this has caused a fire yet. Seems like it would take that for Toyota to recognize that there is a real problem.
  11. Oct 6, 2015 at 4:06 PM
    #51
    shantelleclarke
    shantelleclarke New Member
    Shantelle
    2005 Blue Toyota Tacoma
    Mine looked like all the other photos posted, black and burnt! I wanted to replace all the parts but it was hard to find them at one place. I ended up purchasing the male connector from Mouser (pn: 829-12129565-B for $1.93) and the resistor from RockAuto (pn:4P1650 (JA1772) for $21.79).
  12. Oct 19, 2015 at 1:51 PM
    #52
    Alby22
    Alby22 Well-Known Member
    Ashville, Ohio
    Cement 2020 Toyota Tacoma TRD Sport 4x4 Double Cab, Long Bed
    My 2007 Double Cab is doing the same as your buddy's Tacoma. A little bump under the fan, or just slightly moving the fan itself, gets it going. I'm taking the fan out, and cleaning it now.... I'll keep you updated
  13. Oct 20, 2015 at 6:40 AM
    #53
    Alby22
    Ashville, Ohio
    I used the information in this link http://ncexped.com/tacoma-fan-switch-not-working/ to help with cleaning the fan motor in my truck. As the link explains, TAKE EXTREME CAUTION taking the motor housing off, being careful not to damage the brushes in the housing. With that being said, it's not a difficult task, just take your time and use common sense. My fan motor was filthy with copper/metal dust. I cleaned and reassembled the fan motor, and so far everything works like new. I'll post updates after awhile to let you know if anything changes. Thanks for sharing info everyone
  14. Oct 20, 2015 at 5:00 PM
    #54
    shantelleclarke
    Shantelle
    So as mentioned above, I replaced the resistor and the burnt pigtail. I plugged it in without bolting it in its spot to make sure it worked and voila! However, once I bolted it back into it's home it stopped working and now I can't get it going again. I've checked fuses, wiggled wires... nothing. Any ideas?
  15. Oct 21, 2015 at 9:11 AM
    #55
    Alby22
    Ashville, Ohio
    I'd try tapping the bottom of the motor housing. If the fan starts moving with a little tap, then you need to clean the fan motor like I did.
  16. Oct 27, 2015 at 1:52 PM
    #56
    AfrknMgk
    AfrknMgk Member
    Alby22, thanks for posting the link to this article. Has your blower motor continued to work?
  17. Nov 4, 2015 at 5:41 AM
    #57
    Alby22
    Ashville, Ohio
    Yes, so far, all speeds are working fine. Since I fixed mine, I did the same to a friends 2008 Tacoma, and his is working also
  18. Nov 19, 2015 at 7:39 PM
    #58
    AfrknMgk
    AfrknMgk Member
    My buddy and I still haven't had the chance to pull his blower motor apart, he has a much busier schedule than I, but I do feel confident the problem lies within the motor. He has started having this problem more consistently, and I have purposely tapped on the motor itself, not the glove box, and it starts up. I also noticed it made a grinding noise when it first started up.
  19. Nov 20, 2015 at 3:48 AM
    #59
    Alby22
    Ashville, Ohio
    cleaning the motor is definitely your next move
  20. Jan 6, 2016 at 2:33 PM
    #60
    lionsm13
    lionsm13 Well-Known Member
    Black Hills SD
    07 Tacoma SR5
    Mine07 (DC-LB) quit working on the other 3 speeds this AM and would only run on High.
    Made an appointment with local neighborhood wrench who was going to fix it this Friday, but went out and jiggled it and "lo and behold" it came back on all 3 speeds plus High!! Don't know if someone had touched it with their foot or.....???
    Anyway it is back on for the time being.
    Thanx TC!!
    Ya'll rock!!
