Before you replace the blower resistor ...
Discussion in '2nd Gen. Builds (2005-2015)' started by ibJAE, Aug 7, 2010.
  1. Sep 4, 2019 at 1:57 PM
    #101
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Thanks. Think I'll try that. About to leave for a trip in a few days and really don't wanna mess things up and be stuck without AC on a six hour drive through California. If this doesn't work I'll order a new resistor
  2. Sep 4, 2019 at 5:23 PM
    #102
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    You can do the plug and resistor in 10 mins.
  3. Sep 11, 2021 at 10:43 AM
    #103
    bababooey9
    bababooey9 Member
    Peterborough, ON
    '08 4 banger 4x4
    Thanks so much for this everyone! I swapped the resister, plug, and motor only to find that now each setting on my fan speed results in the blower on high!? any ideas?
  4. Oct 27, 2021 at 10:54 AM
    #104
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    No joke guys... I just tap the bottom of the connector when it goes out every 3/4 months and it goes back on. Haven't replaced anything yet.
  5. Oct 27, 2021 at 1:25 PM
    #105
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Same here... but I unplug the connector and scrape the tarnished contacts... maybe twice a year when it reverts to running only on the high fan setting. The pain (for me) is removing the glove box to get at it! Tall passengers (long legs) tend to bump the harness/ connector with their shoe toe, and that makes it only run on high, as well.
  6. Mar 23, 2022 at 9:42 PM
    #106
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    Old thread but I have to thank op. I had problems with mine a few years back but it was the connection at the back of the switch unit. Cleaned it up and no longer an issue. Today on my way home it only ran on high. Got home and tried the connector on the switch unit...no luck. So I tried op's trick and voila, back in business. I love this site. Thanks TW
    robssol, Torspd and dirtnsmores like this.
  7. Dec 30, 2023 at 6:25 PM
    #107
    worseisyet2come
    worseisyet2come Well-Known Member
    South Jersey
    2007 Tacoma TRD Off-Road DCSB
    Cooper S/T MAXX 265/75/R16 | Bilstein 5100s @ 1.75" | Warn m8000-s | US Offroad Winch Bumper | ProMaxx 4" Step Bars | TRD Exhaust | 4th Leaf via Rear TSB | CompuStar Remote Start
    I know this is an old thread but thanks to OP and all the other contributors on this one. Went a long way to helping make sense of my issue (about 50% of the time motor will only turn on when on High, until you tap the motor or resistor area). I've checked the motor connector (perfect shape), resistor connector (slightly brown in that one pin and wire is browned about an inch), and fan speed control connector (slightly brown in that one pin and wire is browned about an inch).
    Based on the comment here (or another thread?) about the motor being the initial culprit - due to higher draw/resistance as it goes bad - do I just go with a new motor and call it a day since everything else seems to be in good shape still with the exception of very mild browning? It makes sense that the motor is the sole cause here, as I can hear the motor having a tougher time and have already had it out once to clean and grease it a few years back. Or am I putting myself a risk of chasing my tail where the worn connector/wiring could start causing motor issues - and should really swap it all out? At that rate, given the new resistor and connector layout, wondering if at that point it's easier to just run a whole new wire harness between the fan control and the resistor. That way it's a fresh connector, new wires with thicker gauge, etc. But don't want to rip the dash apart if it's overkill. I hate the idea of splicing wires all over the place too, but ultimately I'll probably do whatever's the smart move long-term.
    Torspd likes this.
  8. Jan 3, 2024 at 10:43 PM
    #108
    BigToe56
    BigToe56 New Member
    BigToe
    2009 rusty,flaking pain,dented up Alaska tacoma
    Removed a portion of front bumper to accomodate the placement of the boulder by God.
    Is this a better quality than the original?
    I may solder a solid wire directly to each male terminal on the resistor insulate them and wire direct.
  9. Jan 10, 2024 at 9:29 PM
    #109
    The605taco
    The605taco Well-Known Member
    Sawyer
    2014 4X4 short bed
    6112(notch 3) 5160 icon AAL Baja fogs and Ditch lights Headwaters seat covers Off roam phone mount Diamond back cover
    I would work with moving around the wires a little bit. From my finding the wire isn’t held in the connector good enough so it is what causes the shorting/browning. This is made worse because it easily gets kicked in the foot well. When messing around with mine it completely fixed my issue from that day on.
