'Bell' / 'ping' noise when put into reverse
Discussion in '1st Gen. Tacomas (1995-2004)' started by Noff, Feb 29, 2024.
  1. Feb 29, 2024 at 1:39 PM
    Noff
    Noff [OP] Member
    Recently I have been hearing a significant "bell" noise after I start my truck and then put it into gear - specifically reverse.
    Also my truck jolts slightly when coming to a stop. I press on the brakes, and just when I'm to a stop it jolts at me, like I'm being tapped from behind.
    Not sure if the two are related. The bell noise when putting the truck into gear seems to be a newer / more noticeable issue.
  2. Feb 29, 2024 at 1:48 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    The jolt coming to a stop is likely worn leaf springs causing axle wrap.
    the bell sound - I’d check your U joints on the driveline for play.
  3. Feb 29, 2024 at 9:47 PM
    hp415
    hp415 Well-Known Member
    Paul
    1999 excab taco v6 TRD 5spd
    Wulf likes this.
  4. Mar 1, 2024 at 9:40 AM
    Sklar
    Sklar Well-Known Member
    Skylar
    2003 Tacoma Double Cab 3.4L
    200K and counting.
    I has this happen especially in REV. The solution was to replace my U-joints.
  5. Mar 1, 2024 at 9:42 AM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    I third the U joints. After I greased all the zerks the reverse ping and the clunking sometimes nearing a stop went away, as well as some cruising vibration!
