Belt tensioner replacement DIY
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gsingh, Jul 26, 2020.
  1. Jul 2, 2024 at 11:01 AM
    bforsha78
    bforsha78 New Member
    barry
    tacoma
    I used 8mm e-torx and completed the install in 2 hrs start to finish. Thx for the help
  2. Jul 11, 2024 at 6:08 PM
    mrh2727
    mrh2727 Well-Known Member
    Mathew
    DFW
    2023 TRD off road Barcelona Red
    Great write up! Much appreciated.
  3. Jul 11, 2024 at 6:16 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Gates 070835 is what I've found listed for the truck.
  4. Jul 12, 2024 at 7:57 AM
    tiap
    tiap Active Member
    Alittle off topic
    What camera did you use for the pics?
    Very clear
  5. Aug 28, 2024 at 3:24 PM
    DakoTaco
    DakoTaco Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
    Great write up OP, helped me out a lot. For what it's worth, I had h*ll with holding the new tensioner in place & trying to start a bolt so I took a 3-4" length of 3/8" Ø (0.375") dowel rod, reduced about 1" of the end to 0.320-0.325", stuck it in the lower bolt hole in the motor, slid the tensioner assembly on and swung it up to align the upper bolt & E-8 thru the alternator bolt. After those were started, took out the dowel rod & put the lower bolt in it's place. You could probably use 5/16" Ø, it'd be a sloppier fit on the tensioner mounting hole is all. I used 3/8" because that's what I had on hand & used wood just in case the dam* thing broke, it'd be easy to remove. You could chuck up the dowel rod in a drill motor or drill press, hold some coarse sandpaper against it to reduce it, or like me, I have a small lathe, i just quickly turned it down. Just trying to add to OP's great write up and add something to the tribal knowledge file.TacoTool.jpg
  6. Aug 30, 2024 at 6:17 PM
    shinxxy
    shinxxy Member
    2016 Silver Tacoma TRD Sport
    Take off 12mm nut on the alternator stud. E8 torx bit socket for removal. Great write up. Took 30 minutes to replace tensioner.
    stealthmode likes this.
