Belts makin noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by stucksucksnayota, Nov 29, 2007.
  1. Nov 29, 2007 at 8:24 PM
    stucksucksnayota
    stucksucksnayota [OP] Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    This is probably an easy fix just wanted to ask and see if anyone has had there toyota do this before.
    Im thinking my have my belt or belts 2 tight because when my truck is idling the belts squick and make a little bit of noise its not bad sounding just dosent sound like a toyota should
    do i need to loose them? replace them?
  2. Nov 29, 2007 at 8:29 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I have heard that putting some talcum powder on them helps.
  3. Nov 30, 2007 at 6:46 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When belts squeek like that - normally means they're not tight enough.
    They're slipping on the pully's and causing the squeek.
    Get under the hood and look at the belts and the pulleys. Look for obvious wear ...if you see nylon threads, gouges, rips, etc - time to replace them. Look at the pulley's - they should be consistantly smooth all around (no rough spots, etc).
    Also - find a good length of belt where it's straight and flat and away from the pulley's. Grab the edges of the belt with your finger & thumb. Twist the belt. If you can twist the belt PAST the perpendicular point.....then the belt is too loose. You have 3 belts on the 1st gens - check all 3 belts for tightness.
    I can't remember exactly - each 'accessory' (A/C, Alternator, Power steering pump) should have an adjustment point to tighten each belt. I can't remember exactly how the adjustment - but normally there will be a bolt that holds the adjustment and a threaded rod that makes the adjustment. It's been a good 4 years since I owned my 96....
    Good Luck!
  4. Nov 30, 2007 at 6:01 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Janster seemed to cover the issue pretty damn well, but not to be stupid, when checking the belts be sure the truck is OFF. :lalala:
  5. Nov 30, 2007 at 6:17 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    The adjuster bolt for the ac compressor belt is at the bottom of the engine compartment behind an idler pulley. Take off the skid plates and it's easily accessible. The adjuster for the power steering and fan belt is below and behind the power steering reservoir. I think, but I'm not 100% sure that you adjust the alternator belt by adjusting the alternator itself.
  6. Nov 30, 2007 at 10:28 PM
    debuhr
    debuhr Active Member
    Illinois
    2006 Toyota Tacoma 4X4 TRD SR5 Double Cab
    my belts are squeeking reallllllly bad. it just started like 2 days ago. i might have to try what you guys said.
  7. Dec 3, 2007 at 8:24 PM
    stucksucksnayota
    Barry
    Ya I havent had a chance to go out and check them yet but I figured that was what was going on with it thanks alot for the help
  8. Nov 23, 2009 at 2:08 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
  9. Nov 23, 2009 at 2:10 PM
    drew02a
    San Antonio, TX
    wow I'm a noob
  10. Nov 23, 2009 at 5:02 PM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    Great, why did you post that? When I see stuff like that, I have to try it myself. Now, since I don't have an old VW Bug with a loose belt, I'll have to look for something else to try it on...... Well, it's been nice living for 46 years with 10 fingers....:rolleyes:
  11. Jan 28, 2010 at 5:02 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    My truck was doing the same thing go down to your local auto parts store buy some belt dressing and spray that on their while the truck is ideling goes right away.
  12. Jan 28, 2010 at 6:28 PM
    ywen
    ywen Well-Known Member
    belt dressing will only fix it temporarily.. might as well just replace all your drive belts... I had the same issue.. got real annoyed by it and went to my mechanic and got all 3 drive belts changed for $120
  13. Jan 29, 2010 at 4:59 PM
    tacomakid96
    Phil
    Out n' about
    How temporarily are you talking about? I have gone 3k miles and the belts still dont squeek maybe the condition of the belts were different but it was a pritty solid fix for my truck.;)
  14. Jan 29, 2010 at 5:05 PM
    ywen
    Ha for me, it was 1 hour...
    Then again, I just sprayed on the bottom open span that I could see from the top of the engine bay.. wasn't a thorough application..
  15. Aug 3, 2012 at 2:08 PM
    justin808
    justin808 Well-Known Member
    Bay Area, CA
    2017 TRD OR 4x4 DCSB
    Kings, Icon UCA, 275/70 K02s
    jus took my truck down to a mechanic after having the same squeaking sound upon cold start ups. just had all of my belts replaced too. he told me my belts were lose and it would be $50 to tighten them, $50 to turn a wrench? :eek:
    ha does anyone know the exact locations, maybe some pics of where the adjusting knobs are for my 02 3.4L? would be a BIG help!
  16. Aug 3, 2012 at 4:34 PM
    BrianLV
    BrianLV Well-Known Member
    Las Vegas
    04 Prerunner SR5
    go to the DIY section on the top of the forum. Watch the video. For some of the people in this thread, watch the video 6 or 7 times.
