Ben's FX-R Retrofit-
Discussion in 'Lighting' started by BenJammn5, Oct 10, 2011.
  1. Oct 16, 2011 at 9:59 PM
    BenJammn5
    BenJammn5 [OP] RN
    San Francisco
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Bob, I will totally help you as I completely know how tedious this art project is! Stay tuned on this thread and you'll be able to watch the process. Half the battle is already in your hands as you're familiar with the wiring, how to remove the lights, etc. All you're going to do is cut and aim which is probably the hardest part.
  2. Oct 17, 2011 at 7:02 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    that sucks on the bulb, assuming that they are shipping you a new one. My order shipped today on the latest group buy......I am going to be baking my stock oems later this week and get to painting etc...
  3. Mar 6, 2012 at 10:10 PM
    BenJammn5
    BenJammn5 [OP] RN
    San Francisco
    Thought I'd update this dead thread lol
    Well, I finished it. But... theres always a 'but', the left projector is throwing a hotspot and I don't know why. Emailed TRS just waiting for response.
  4. Mar 6, 2012 at 10:28 PM
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    It could be the lense. I have a bad hot spot but it's because my lense was defective. I haven't had a chance to get back to Andrew(TRS) but I hope TI have it fixed soon.
  5. Mar 6, 2012 at 10:38 PM
    BenJammn5
    BenJammn5 [OP] RN
    San Francisco
    bitch isn't it? Never thought it could be the lense. The entire ordeal has been sort of a mess, I bought ebay lights, and ended up using my smoked 09 lenses w/ the black ebay bezel which sort of defeated the whole purpose. I had leaking issues w/ the ebay lights and decided to screw them and stick w/ the toyota part.
  6. Mar 7, 2012 at 6:12 AM
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    Looks sick Ben, your passenger side rotation looks a little off but nice work getting them done!
  7. Mar 7, 2012 at 6:09 PM
    BenJammn5
    BenJammn5 [OP] RN
    San Francisco
    Thanks friend. You are probably right that it's a hair length off, but it's pretty much spot on. I've adjusted the lights since that pic... just don't have updated ones. You know, it's probably my lens throwing that hotspot. My plug-n-play philips bulb burned inside the housing and smoked them from within, that could be a possible reason. The other is that one of my D2S bulbs were bad and burned inside the projector (I have great luck with lights). At this point I'm just like, 'screw it.' On the road you don't really notice the hotspot unless you pull up against a wall, otherwise it's fine.
  8. Mar 8, 2012 at 8:12 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Did your shrouds fit flosh to the reflector bowl?
    Do the 4 screw tabs of the projector touch the reflector bowl?
  9. Mar 8, 2012 at 8:26 AM
    BenJammn5
    BenJammn5 [OP] RN
    San Francisco
    They do not sit completely flush. To notice you'd have to stick your face right up to the light though...
  10. Mar 8, 2012 at 8:59 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Thats what I thought. I need to go and get some 1 in ss bolts. The 2 in bolts are a little long on one side.
    So far so good for me. I just need to take my time. I went with a 2 3/4 in hole saw to make the initial hole in the reflector. Seems to be working alright.
    I have a feeling that the final adjustment will be a PITA.
  11. Mar 8, 2012 at 10:00 AM
    BenJammn5
    BenJammn5 [OP] RN
    San Francisco
    Not sure what you made the hole in the reflector bowl with, but you can cut your 2 3/4 bolts with a dremel and cut off wheel. In fact, you'll need to cut them all the way down anyway so you can fully adjust the light with the stock adjustment tabs.
    The hole for the projector doesn't need to be exact, in fact it doesn't matter all that much. It's how you adjust the projector with the screws that matters more.
    Yes, take your time no rush here. To aim them go against a wall at night and adjust the screws and move the projector around. The projector should be aimed slightly downward. When you get to a desired position cold tack weld the projector with KB kwik weld. Only need a few dabs on the back. This is a tricky part as it's hard to reach behind the light to glue it. Let it dry and then remove the light. I used the lines in the reflector bowl to make sure it was horizontally straight. Eye ball that part... I need to show more pictures of my cut off, only thing is you'll see more of my annoying hotspot :( I think it's the lens.. need to change that out.
  12. May 22, 2012 at 2:53 PM
    TacoDaddy
    TacoDaddy Just call me Daddy
    Brian
    Costa Mesa, CA
    '11 Sport
    what did you use to cut the hole that big? I've been trying to use my dremel and its a huge pain in the ass!!!
  13. May 22, 2012 at 3:45 PM
    BenJammn5
    BenJammn5 [OP] RN
    San Francisco
    Just used the dremel.. cut with the drill bit not the cut off wheel.
  14. May 23, 2012 at 6:38 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I used a Milwaukee 2 3/4 in metal hole saw. I think a 3" hole saw will put the HID lamp and connector too close to the battery. Just take it easy and use very light pressure when drilling the hole. I did take off the two extrusion on the reflector prior to drilling the hole.
  15. Jun 27, 2013 at 8:55 PM
    #35
    Taco89
    Taco89 Well-Known Member
    Nik
    Charlotte, NC
    2013 4x4 Super White DBL Cab TRD Sport
    Is it required to drill 4 holes and screw the projector into the bowl??
  16. Jun 27, 2013 at 9:08 PM
    #36
    Taco89
    Nik
    Charlotte, NC
    Just answered my own question after looking at my projectors lol...what size screws do y'all recommend?
  17. Aug 13, 2013 at 12:51 PM
    #37
    fenderpicks
    fenderpicks Well-Known Member
    Hey Op I have some questions as I intend to do my own retrofit very soon
    For the FX R u have to mount it on the reflector bowl with 4 long screws with a washer and nut to hold it in place and jb weld it
    And for the aiming adjustment it is all made by moving the projector and adjusting the tightness of the 4 screws. (In other words, the factory bolt adjustment is useless after retrofitting?)
    Also while ur doing the aiming, the lights will be on the car and u have to adjust the projector and screws to the desire height then jb weld it to make it unmovable?
