Bent rear axle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ImWarren, Apr 29, 2013.
  1. Apr 30, 2013 at 6:05 PM
    #41
    Jetman1979
    Jetman1979 Well-Known Member
    Michael
    North Texas
    2009 tacoma 4X4
    Now you know why I never bought my son a new car.
  2. Apr 30, 2013 at 6:07 PM
    #42
    ImWarren
    ImWarren [OP] Well-Known Member
    Warren
    South Carolina
    2013 Double Cab manual
    I just took the truck out, no vibrations as far as I can tell, and I don't really see the tire wobbling around when driving because its on the passenger side. I did notice that my alignment is off though.
  3. Apr 30, 2013 at 6:12 PM
    #43
    BradyT88
    BradyT88 Well-Known Member
    Camber:
    These wheels are cambered a lot.
    These are both negative camber. Positive camber would be if the wheels were tipped in the other way. Basically the top is farther out from the vehicle than the bottom is.
  4. Apr 30, 2013 at 6:14 PM
    #44
    ImWarren
    Warren
    South Carolina
    Yeah, you're right. It sure is gonna be tough.
  5. Apr 30, 2013 at 6:16 PM
    #45
    ImWarren
    Warren
    South Carolina
    Wow this really helps, yes the wheel is negative camber.
  6. Apr 30, 2013 at 6:17 PM
    #46
    ImWarren
    Warren
    South Carolina
    Actually no, I meant positive camber
  7. Apr 30, 2013 at 6:19 PM
    #47
    ImWarren
    Warren
    South Carolina
    So, any thoughts on what's causing this? Bent axle, shaft, tube, rim? I want to prepare myself before I take it to the shop.
  8. Apr 30, 2013 at 6:20 PM
    #48
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    yeah listen to what others say and measure it with a level
  9. Apr 30, 2013 at 6:26 PM
    #49
    BradyT88
    If it stays positive I would guess a bent axle housing (what jberry posted on the other page) which should be somewhat visible to your eye if you look at the housing carefully.
    I would think if you bent the wheel or axle shaft then if would vibrate a lot because it would alternate between positive and negative camber when you drive.
  10. Apr 30, 2013 at 6:41 PM
    #50
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    Lawl
    I was gonna link to the James thread from TOL thread but I'm on my phone and cant
  11. Apr 30, 2013 at 6:46 PM
    #51
    ImWarren
    Warren
    South Carolina
    I'll have to check tomorrow, its too dark right now. I appreciate the advice.
  12. Apr 30, 2013 at 6:49 PM
    #52
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I think you are worrying over nothing. Your mudflap, does not, look straight but your axle Does. I think you just hit top of the ditch with mudflap and maybe bended cheap metal holding it to the bed.
    I would not worry. I understand after ditch fiasco you are oversensitive. I would just ignore it or get truck for wheel alignment.
  13. Apr 30, 2013 at 6:56 PM
    #53
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Imwarren.
    Im a dad.
    Trust me, tell your dad.
    Since its brand new, take it back to the dealer and have them look at it.
    If you ask nicely enough, and because its brand new they may take a look for free. Let us know how u make out. Good luck.
  14. Apr 30, 2013 at 7:20 PM
    #54
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    "Check the centering pin on the rear leaf springs, check to see if the axle slid on the leafs."
    Good Advise...
    OP, do you have a floor jack? or at least a friend with a floor jack?
    You can check the most obvious, ie, bent rim, bent axle flange, the dang truck is so new the undercarriage is super clean, any bending of the housing would show as "stretch marks" and should be easy to see...
    Jack the suspect side up lifting at the shock plate area close to the wheel, front wheels caulked both sides, put in neutral, parking brake off, spin wheel by hand, any obvious bendage/wobble in the wheel or axle flange you will see...
    My bet is you may have sheared the locator pin and jacked the housing a bit out of alignment from what sounds to be a pretty violent hit...check the clearance both left and right side from tire to mud flap, are they the same distance? All you need is a tape measure...you may just be able to look, if it is obvious you will see it....unless the housing bottomed or caught on something, it probably survived...
    You say the alignment is out, I figure if the rear hit the 'dip/ditch', your front end may have hit the same spot, unless the fronts made the turn and you caught the rear on the edge of a underground drain by turning to close to the edge of the road, that would cause all sorts of violent stuff to the rear end for sure.......just how hard was this hit???
    Anyway, I figure you wacked the front end too and more than likely sheared the locator pin on the rear....
    These things you can do on your own, but do it quickly, find out what's wrong, then fess up...
  15. Apr 30, 2013 at 7:27 PM
    #55
    Jetman1979
    Michael
    North Texas
    2009 tacoma 4X4
    Yea keep us posted. Here is another shade tree trick that is cheap get some white sidewalk chalk find a level piece of road or a parking lot. Next draw a one inch wide line across the tire thread and go about 100 ft and look at the line on your tire and see were it has rubbed off.
  16. Apr 30, 2013 at 7:46 PM
    #56
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    As a Dad I have to say it: Tell him the fucking truth! Did you think of that?
  17. Apr 30, 2013 at 8:14 PM
    #57
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Alignment. Numbers.
  18. Apr 30, 2013 at 11:44 PM
    #58
    elsenordave
    elsenordave HaoleBilt
    Dave Smith
    Blown 2013 NBM DCSB Sport
    AFE CAI TRD Exhaust TRD Supercharger 3" Cornfed Spacer 2" Toytec AAL
    We always advise our customers that if not a factory defect but rather what I politely call the "human element" then they are responsible or the diagnosis...:anonymous:
  19. May 1, 2013 at 1:40 AM
    #59
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Personally, I don't think you'll be able to tell from looking at the housing or eyeballing it. It's real hard to tell from pictures and I see what you're saying but if it is it's only bent a little. In my opinion, if it is bent you won't break a side gear you'll only slowly wear out tires, you'll notice it slowly wear down more on one side than the other. IMO shearing a center pin won't cause it to appear to have positive camber.
    The cheapest option you can do is to go to Harbor Freight and buy a digital angle finder. Park on a level surface and check it with your angle finder, if it's not level keep that in mind for your camber readings. Then put a straight edge from the lip of your wheel to the lip on the other side straight up and down and check to see what kind of angle you have. Should be DAMN near 0.0* Just like Jason said. If you listen to anyone in this thread, listen to Jason.
  20. May 1, 2013 at 5:08 AM
    #60
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    Maybe he's working on his future career as a politician.
