Bent rear axle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ImWarren, Apr 29, 2013.
  1. May 1, 2013 at 5:25 AM
    #61
    dan33900
    dan33900 Well-Known Member
    Dan
    Maumelle, Arkansas
    2009 DCSB 4X4 MGM
    As a father to a son that went brain dead at 16, I recommend you tell your dad. My son did plenty of stupid things and always told me and we never lost our trust in each other. But I would get it checked as soon as possible.
  2. May 1, 2013 at 5:35 AM
    #62
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You are correct that a sheared center pin will not cause positive or negative camber. With that out of the way, we don't even know if he has a camber problem. He hasn't measured anything to see what the angle is. You really cannot tell much from the picture, it just doesn't look " right ". I just suggested he check it as that is a common failure mode when hitting a ditch as he did.
    Measurements do need to be taken and the results posted in order for us to assist him.
    OP. Don't try to scam the dealer to fix your screw-up as others have suggested, or lie to your dad.
    Be honest and man up to your mistakes and all will work out for the better in the long run. Messing up is a right of passage.
    Hint:
    Being honest when everyone is watching is one thing, being honest when nobody knows is quite another. The latter tells the true character of a person.
  3. May 1, 2013 at 5:50 AM
    #63
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    Get in the white Bronco and drive like hell.
  4. May 1, 2013 at 6:17 AM
    #64
    Kenobe
    Kenobe Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    :laugh::laugh::laugh:
    Tell Oz you're on the way and need someplace to crash. :canada:
  5. May 1, 2013 at 6:41 AM
    #65
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Dude tell your dad. This is 2013 and it's America, my father will kick my ass for thing like this and scream the shit out of his lungs for something like this. But that was 25 years ago and we didn't have social services.
    Believe me You will get in more trouble for lying.
    Here is an explanation about the social services quote :
    http://youtu.be/yVcePxjFujs
  6. May 1, 2013 at 8:22 AM
    #66
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    everyone asking for alignment numbers..i dont get it. the rears have no adjustments.
    and kid, tell your dad. dont be an idiot. so glad i dont have kids.
    "if" something is bent or broken, which i highly doubt from how you described the incident..this is a safety issue. you dont want some fatigued point to catastrophically fail because you were to chicken to talk to dad.
  7. May 1, 2013 at 8:24 AM
    #67
    aficianado
    back to bone stock.
    i just looked at the pics..the truck needs to sit on a flat surface.
    that suspect wheel is on an incline. your truck is fine. (i suspect)
  8. May 1, 2013 at 8:28 AM
    #68
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Not entirely true. The entire axle can rotate a few degrees forward and backward causing inverse toe issues (assuming a strait axle). Also there can be inverse camber readings if the centering pin sheered and the axle slid out from it's normal spot.
    Regardless, doing some quick alignment recon is the easiest way to find out what, if anything, is off. Throw on a digital level to get camber and use the paint/score method to find toe. Easy peasy.
  9. May 1, 2013 at 8:35 AM
    #69
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    OK, I'm not gonna debate the possibilities and what not but if you slam or jump enough to bend the axle and/or housing, how would it be bent with the top of the wheel out like it appears in OPs pics instead of the bottom of the wheel out like in the other guy's pics? Generally I would expect the top of the wheel to be further in the wheel well or the backside of the wheel further in the wheel well if it was hit with crazy force while driving.
  10. May 1, 2013 at 8:37 AM
    #70
    aficianado
    back to bone stock.
    not a bad point.
    if one side has a positive camber..the other side would be negative?
  11. May 1, 2013 at 8:39 AM
    #71
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yep, that's what I meant by inverse.
    Again...this assumes a completely strait axle.
    And to the OP, take a look at this. It's not as hard as you think. You can ignore the steps on caster, but camber and toe still apply to the rear of the truck.
    http://www.tacomaworld.com/forum/suspension/252256-how-do-alignment-home.html
  12. May 1, 2013 at 9:31 AM
    #72
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Beeecause maybe there's nothing wrong with his truck and we're all just talking out our asses :notsure:
  13. May 1, 2013 at 4:45 PM
    #73
    trooper12
    trooper12 Well-Known Member
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    maxtrac 4" lift spindles, wheelers 1.5" 3 leaf pack. nothin special...
    I think its fine. I hit a ditch on a dirt road going 65 and the hit was hard enough blow out a bilsetin 5100 on the rear. It hit really hard and it hurt, but everything is fine, except the shock.
  14. May 1, 2013 at 5:41 PM
    #74
    ImWarren
    ImWarren [OP] Well-Known Member
    Warren
    South Carolina
    2013 Double Cab manual
    Thanks for all the replies guys. I'm taking it to the shop on monday to get the bumper fixed and I'll have them look at it. The truck feels sluggish when moving and I have to brake harder to slow it down. And I did tell my dad that I hit a ditch but not because I was going off road. I told him I had swerve out of the way to avoid hitting a deer. I couldn't tell him I was going off road because he told me before that if he saw mud on my tires again, I won't be driving the truck anymore.
  15. May 1, 2013 at 5:42 PM
    #75
    ImWarren
    Warren
    South Carolina
    This makes me feel better. It's a brand new truck so I'm super careful about it. Also, I hit the ditch at an angle which explains the alignment issues.
  16. May 1, 2013 at 5:58 PM
    #76
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    What's your dad's email address. I'd love to tell him how honest of a son he has an link this thread.
  17. May 1, 2013 at 6:00 PM
    #77
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    :popcorn:
  18. May 1, 2013 at 6:03 PM
    #78
    BradyT88
    BradyT88 Well-Known Member
    Yeah... that was a bit of a stretch of the truth...
  19. May 1, 2013 at 6:13 PM
    #79
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Hard to say if it's real or placebo. The rear drum brakes are mounted on the axle flanges, so a bent axle can cause binding there, in theory.
    Sheared/mislocated leaf spring centering pin is also possible, especially with the low U-bolt torque on some trucks coming out of the factory.
    What are your camber numbers? If you didn't buy a $30 inclinometer yet, there are iPhone and Android apps that can accomplish the same thing with a smartphone.
    :facepalm: So your dad buys you a $35,000 truck? Must be nice...
  20. May 1, 2013 at 6:21 PM
    #80
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    No point in giving this kid anymore advice.
    This is gonna be like that James ins. Fraud thread that's in threads of legend.
