Best $18 ever spent on my Tacoma ext cab.
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyTaco1992, Jan 19, 2011.
  1. Jan 19, 2011 at 7:47 PM
    ToyTaco1992
    ToyTaco1992 [OP] Member
    Land of Entrapment
    2003 Tacoma TRD
    All Stock As of now.........
    So I have had a bunch of issues with the way the back seat is set up. I have a german shepherd and there is no where for his 80 pound @*% to be. Every corner i hit he is bouncing around between the jump seats and the floor.:eek:
    Not any more. I found the perfect $18 dollar fix. :D
    Particle board. 2ft W 4ft L
    Roll of carpet ( colored to your liking) 2.5 ft w 4.5 L
    Last but not least a staple gun and a hammer to make the staples flush.
    You have to cut a little bit of the wood to compensate for the middle console and an inch off of one of the sides to make a perfect fit.
    make sure the wood piece fits perfectly into place. and then wrap carpet around and staple onto the bottom of board.
    I use a tool box and a couple of chairs and a shovel to even out the jump seats to the floor board. More cargo space and flatter back seat.:)
    My dog now has a perfect 2 by 4 platform to travel on. no more getting tossed around. I can just about lay down on it.:p
  2. Jan 19, 2011 at 7:49 PM
    ToyTaco1992
    Land of Entrapment
    2003 Tacoma TRD
    wow dude you are so smart you know that?
  3. Jan 19, 2011 at 7:59 PM
    CaptMorgan
    CaptMorgan Well-Known Member
    Tempe
    Lift, tires, aux-in, LED Taillights, Flowmaster
    Looks really clean! Might want to add some legs in the front and corners and center for stability, just a thought
  4. Jan 19, 2011 at 8:01 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    holy shit thats an amazing idea!
  5. Jan 19, 2011 at 8:02 PM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    Good idea! looks good.
  6. Jan 19, 2011 at 8:04 PM
    v1ndictiv3
    v1ndictiv3 Well-Known Member
    Bay Area, California
    '98 PreRunner Xtra Cab 2.7L
    Mostly stock: AFE Pro Dry S Filter, Bedrug, Leer Shell, 265/75/15 Goodyear Wrangler RT, Husky Liners, Wet Okole seat covers... Powertrax No-Slip in the near future =)
    Brilliant! I might try this someday. Thanks for idea.
  7. Jan 19, 2011 at 8:15 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    lolz
  8. Jan 19, 2011 at 9:25 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I did the same thing, but built some legs for it, rather than jamming crap under there haha. I'm gona build a new one with a hinge in the middle on the bottom so I can still get to my things :)
  9. Jan 19, 2011 at 9:31 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I bet your dog is one happy camper!! :cheers:
  10. Jan 20, 2011 at 2:56 PM
    ToyTaco1992
    Land of Entrapment
    2003 Tacoma TRD
    yeah definitely some legs would make it much sturdier, and that was my initial plan. When I put things that i frequently use underneath it as support I was satisfied. ..... or maybe i just got lazy. haha =)
  11. Jan 20, 2011 at 2:58 PM
    ToyTaco1992
    Land of Entrapment
    2003 Tacoma TRD
    That is a good idea! Mine is far from permanent. It only weighs like 8 lbs, so I figure I can just take it out when I need to get to things, or add some passengers other than my dog. haha
  12. Jan 20, 2011 at 2:59 PM
    Manwithoutaplan
    ID
    I love the sheep skin seat cover booo ya :)
  13. Jan 20, 2011 at 3:13 PM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    Looks nice, any pics of the dog on it?
  14. Jan 20, 2011 at 6:05 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
  15. Jan 20, 2011 at 6:14 PM
    NegroTundra
    Land of Enchantment
    BTW, where in NM are you?
  16. Jan 20, 2011 at 6:54 PM
    ToyTaco1992
    Land of Entrapment
    2003 Tacoma TRD
    My German Shepherd
  17. Jan 20, 2011 at 6:59 PM
    ToyTaco1992
    Land of Entrapment
    2003 Tacoma TRD
    at least my seats are protected.. haha Im in abq
  18. Jan 20, 2011 at 7:00 PM
    ToyTaco1992
    Land of Entrapment
    2003 Tacoma TRD
    i like to drive naked
  19. Jan 20, 2011 at 7:17 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    x2 ;)
    I've been thinking of doing something similar for my truck for when I need to pack for a trip...never fails that things slide off of the seats and make it impossible to get the seats forward and back without running into something. I have the 60/40 bench though so mine would be slightly different.
  20. Jan 20, 2011 at 7:17 PM
    BoostingMS6
    BoostingMS6 Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    Hahah I was looking for NegroTundra's original thread on it, but he beat me to posting the link.
