Best after market headlights (‘04)
Discussion in '1st Gen. Tacomas (1995-2004)' started by rth1146, Nov 11, 2020.
  1. Nov 11, 2020 at 9:55 PM
    rth1146
    rth1146 [OP] Active Member
    My truck has some pretty cheap feeling after market headlights. One of them even rattles / moves to the touch. The look is pretty basic so I don’t mind the look, but I’d prefer something with a more quality look. What are your suggestions? May go OEM but would prefer something a bit less than $400
  2. Nov 11, 2020 at 10:08 PM
    99greentaco4x4
    99greentaco4x4 Member
    1999 Tacoma 3.4l 4x4 TRD
    I put Spyder halogens on my 99. I don't recommend. One of the Halos didn't work out of the box and I couldn't return because once you splice/cut wires it voids warranty. They also stick out about an inch more than the stock ones and doesn't look flush with the grill.
  3. Nov 12, 2020 at 6:38 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    07 Lexus GX470
    If you're not wanting to go OEM which is the best option for quality and longevity then get TYC CAPA certified.
    TacoTaco02 and jbrandt like this.
  4. Nov 12, 2020 at 9:34 AM
    OMT Tacoma
    OMT Tacoma Member
    F'burg VA
    2001 Regular Cab 4x4 5spd, 1999 Ext. Cab 5-lug 5spd
    OME 2881 Coils front, Wheeler's 5 leaf spring rear, OME Nitrocharger Sports on all four corners, SCS F5 Wheels - 16x8 3.5" BS, 265/75R16 Goodyear Wrangler Authority Tires, Rear diff breather extension.
    I replaced my headlights almost two years ago due to them being extremely hazed. I went with the following TYC brand headlamps from Amazon (NSF certified version):
    https://www.amazon.com/dp/B00NXTU7Z8?psc=1&ref=ppx_pop_dt_b_product_details
    Headlamps fit in and aligned just fine. I seem to remember that one of the mounting brackets on the new head lamps was cracked, most likely because of poor packaging; however, I was able to reuse the bracket off the old headlamp without any issue.
    I also used Xpel protective film:
    https://www.summitracing.com/parts/xtc-h0125/year/2001/make/toyota/model/tacoma
    The truck has been outside with minimal shade for the past two years and the head lights still look new.
  5. Nov 12, 2020 at 9:59 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Spyders don't exactly have a great reputation, quality wise. Almost all of these aftermarket light brands are way more concerned with how cool their housings look, and don't put a lot into the light beam pattern and general quality.
    For an '04, the best "aftermarket" lights are going to be the CAPA certified TYC's from rock auto, or actual OEM. The CAPA housings are indistinguishable from OEM.
    There are many threads, but search for the "ultimate upgrade". New OEM or CAPA housings, bright OSRAM bulbs (although those are hard to come by now), and an upgraded wire harness (larger gauge wiring, direct to battery connection, relays, etc...)
    aAnother option, but generally way more expensive is an HID retrofit.
    But do NOT throw cool LEDs in ANY conventional halogen housing.
    rth1146[OP] likes this.
  6. Nov 12, 2020 at 10:31 PM
    whitetaco01
    whitetaco01 Well-Known Member
    So Cal
    01 Prerunner
    Mid Travel Stuff
    I've had pretty good luck with DEPO. Haven't leaked and the lenses seam to hold up, I do put some UV inhibitor on them though
  7. Nov 13, 2020 at 6:22 AM
    TacoTaco02
    TacoTaco02 Well-Known Member
    Illinois
    02 Ext Cab SR5 TRD 4x4 V6
    I bought a set of the TYC Capa certified headlights on Rockauto for about $29 a piece. The light output/balance is definitely more scattered than OEM but for the cost I think they are great. The fit was perfect and i had 0 issues installing. Highly recommend.
  8. Nov 13, 2020 at 7:17 AM
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    the DEPOs on my 2nd gen are horrid; the 'bright spot' / 'hot spot' of the bulbs is no more than about 20 feet in front of the truck. It's like driving only with factor driving/fog lights. Worst headlights i've had in a car ever.
  9. Nov 13, 2020 at 7:20 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    same, my DEPO look good but the beam pattern was "off" and the blank/hot spots were not correct. OEM are definitely the best for halogen bulbs. I finally got my retrofit done and am much more happy.
  10. Nov 13, 2020 at 7:28 AM
    DetroitDarin
    York County PA
    so - you had OEM reflectors installed into the depo housings? Is that what that means?
  11. Nov 13, 2020 at 11:39 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    mmm no. I had OEM that became hazed and dim so replaced with DEPO versions. used them for over a year and definitely noticed the difference in light pattern.
    I got my TRS retrofit last year during BF and finally put that into the housings this year.
    DetroitDarin[QUOTED] likes this.
  12. Nov 13, 2020 at 12:48 PM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    kingdeaverBAMF33s
    What kind of promotion did TRS do last year?
  13. Nov 13, 2020 at 1:21 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    Seconded CAPA certified from rockauto
  14. Nov 13, 2020 at 1:56 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    been awhile but I think I used the default % off TW discount. Their BF was less % so I waited until then to see if it was better or not. then just ordered with the TW code. It's in their vendor page here on TW.
  15. Nov 13, 2020 at 6:50 PM
    jbrandt
    Justin
    The CAPA housings are every bit as good as OEM. We're talking early 2000's light technology. They don't compare to my '14 Corolla or '17 4Runner, but neither did my original '04 Tacoma lights, even when it was new.
    DashMaple likes this.
