Best air compressor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma08brandon87, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Sep 2, 2018 at 11:54 AM
    tacoma08brandon87
    tacoma08brandon87 [OP] Well-Known Member
    brandon
    El Paso Texas
    TRD
    To air back up after the trail what you guys have. Also looking for a Deflator kit. Hate using my keys than going one tire at a time
    Qny TW discounts would be great
    3_TACOS_NEVER_ENOUGH and Manfred like this.
  2. Sep 2, 2018 at 12:00 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Top 3 options are:
    ARB or VIAIR
    Or CO2 tank setup (diy kit or from a company)
    CO2 will air you up extremely fast and can run air tools very well. Con is finding a place local to fill your tank. Some areas only have companies that will fill commercially or their own tanks only. The other con is with a CO2 tank you likely aren’t hauling it around on a regular basis, whereas with a compressor you can hardware it and keep it on board which would be nice for local travel or instances where you aren’t bringing your CO2 tank.
    On board compressor setups will leave you sitting for a couple minutes (per tire) or more depending on the compressor.
    Lots of people are springing for the ARB stuff but it comes at a premium price, for compact size and performance.
  3. Sep 2, 2018 at 12:01 PM
    tcjacado
    tcjacado Well-Known Member
  4. Sep 2, 2018 at 12:16 PM
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
    Looking at getting ARB one
  5. Sep 2, 2018 at 12:52 PM
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    I have a Viair 88P and it will take four tires from 20 to 34psi in about 1.5min per tire, with no down time. For deflating I like the screw on type that you can preset to whatever psi you want. I like to be able to do all four tires at once. I have found that the gauge on the 88p is not accurate consistently reading 4-5 lbs. over what it really is. Other than that its a solid little unit.
    Relaxinslax and REDdawn6 like this.
  6. Sep 2, 2018 at 12:55 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
  7. Sep 2, 2018 at 1:02 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    +1 for Viair
  8. Sep 2, 2018 at 1:04 PM
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
    I want something that i can mount in the engine bay
  9. Sep 2, 2018 at 1:08 PM
    m603holden
    Marteeen
    New England
    Just a consideration. If you'll be doing airlockers you'll need to get an air compressor designed for it. If you're just looking to do your tires, you might want a stand alone. If you're ever out with other people who could benefit from airing down but don't have a compressor, it's easier to just grab the bag and walk it over.
  10. Sep 2, 2018 at 1:18 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    If you don't care about onboard options you can get a pancake compressor from Harbor Freight for less than a hundred bucks that will power off of the outlet in the bed. With one of the 20% off coupons I think they're about 70 or 80 bucks. If you were in the Northern Colorado area I have one that's only been used a couple of times that I'd let you have for less than that. I actually have two of them and for that purpose they work very well.
  11. Sep 2, 2018 at 1:27 PM
    Pigpen
    Dan
    Northwest Montana
    I love my ARB compressor. I have the bigger single compressor. It airs up in plenty if time for me. I like my ARB deflator too.
  12. Sep 2, 2018 at 1:33 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    ARB twin...have put in a few rigs, works great!! I bought a shops inventory that was going out of business.
    Still have a few.
    Going to put one in wife’s 2018 Rubicon.
    They are fast and reliable .
    Lelouch likes this.
  13. Sep 2, 2018 at 1:42 PM
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
  14. Sep 2, 2018 at 1:52 PM
    Track
    Track Well-Known Member
    Tuck
    Florida
    2017 TRD offroad
    MobTown bed racks MobTown sliders and skid ARB onboard air
    Then you’ll probably want the ARB. I have the single compressor mounted under the hood (3rd gen) on the left side firewall. Pretty easy to install, esp. when you use a tray. Wiring is easy but the supplied switch does not fit in the dash. Had to order a Tacoma specific push on.
  15. Jan 21, 2019 at 5:25 PM
    3_TACOS_NEVER_ENOUGH Well-Known Member
    Various Locations: TX, CA, NC, AL, MS, and FL
  16. Jan 21, 2019 at 6:32 PM
    Mjhendo
    Mjhendo Member
    2014 silver Tacoma TRD Off Road
    Stock
    I keep a VIAIR400P behind my seat. Very happy with it so far.
  17. Sep 3, 2019 at 12:01 PM
    Sweston
    Sweston Well-Known Member
    Sam
    Houston, Tx
    '15 Super White TRD OR DCSB
    Cosmetic: Mud flap trim Console Organizer Tow plug bumper relocation Utility: Rear Diff Breather
    I have this one and had to use it on a road trip due to a slow leak. Each time I used it my fuse in the truck blew and had to be replaced. I had to use it about 6 times, each time replacing a fuse. It claimed to draw less amps than the fuse was rated for. I made sure to check what else was on the circuit and remove anything else that may be using power. From that I determined 100% the inflator was at fault. Mine was pretty old (several years) but nothing happened to it that would cause it to break
  18. Sep 3, 2019 at 12:14 PM
    Darth ToyTaco
    Darth ToyTaco Well-Known Member
    New Mexico
    2010 Offroad Short
    Stuff
    I have this same compressor. With 265/75R16s it will go from 25 psi to 45psi in about 2 minutes per tire. It's a large compressor so you probably won't want it under the hood (I like being able to carry it in any vehicle) and the gauge on the compressor isn't great so factor in buying something more accurate.
  19. Sep 3, 2019 at 2:34 PM
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Yep my gauge doesn’t appear to work at all anymore but the compressor itself still works great.
Thread Status:
